Re: New 15x7 Rallye Trim Rings
[Re: RUNCHARGER]
#483625
10/02/09 03:10 PM
10/02/09 03:10 PM
Posts: 4,799 ILL
MLR426
ILL
I think the brushed 15X7 rings went onto AAR's as well.
Sheldon
No brushed on aar or ta
logan426
[Re: MLR426]
#483626
10/02/09 05:56 PM
10/02/09 05:56 PM
Posts: 18,160 Mass
DAYCLONA
Mass
Sheldon
logan426
That's allways been a source of debate amongst the Trans Am crowd, If I recall even Galen finally gave in to that debate, and agreed that some T/A's/AAR's had brushed rings, IIRC
Mike
[Re: DAYCLONA]
#483627
10/02/09 09:46 PM
10/02/09 09:46 PM
Posts: 27,486 So Cal
autoxcuda
So Cal
Sheldon
logan426
Mike
And don't forget you could get T/A's with dog dish AND trim rings. Do the rallye trim ring rules apply to a dog dish car?? Also, in that case the rim is black instead of body color.
[Re: sixpackbee]
#483628
10/02/09 11:13 PM
10/02/09 11:13 PM
Posts: 308 Turneffe
BJohnson
Turneffe
Not to hijack the thread but what were the brushed style 15 x 7 rings put on?
Brushed trim rings were released in Jan. of 1970 for use on B Body's and later on some of the T/A's.
Now back to the original question.
Original rings were polished, but Chrysler chromed the new "P" rings because that was the description that was called out in the parts book.
[Re: BJohnson]
#483629
10/02/09 11:49 PM
10/02/09 11:49 PM
autoxcuda
So Cal
Have you confirmed since your original post the new P rings are in fact chromed?
Someone should be able to tell up close and in person if it's chromed vs polished bare stainless.
[Re: autoxcuda]
#483630
10/03/09 11:00 PM
10/03/09 11:00 PM
Posts: 308 Turneffe
BJohnson
Turneffe
Bare metal exposed when the chrome was polished.
[Re: BJohnson]
#483631
10/04/09 01:24 AM
10/04/09 01:24 AM
autoxcuda
So Cal
Is the bare metal steel (magnetic) or stainless steel.
I thought someone gave MP originals to sample from when they were making them??
[Re: Hoof Hearted]
#483634
10/04/09 02:29 PM
10/04/09 02:29 PM
autoxcuda
So Cal
Slightly magnetic.
Now we're getting somewhere.
Ususally chrome over regular steel trim rings are cheaper than fully stainless rings.
[Re: autoxcuda]
#483635
10/04/09 02:44 PM
10/04/09 02:44 PM
Posts: 8,850 Central Coast, Calif.
Snoopy
Not all stainless steel is non-magnetic. From: WiseGeek Is Stainless Steel Magnetic? When it comes to classifying stainless steel as having magnetic properties, there is not a simple yes and no answer. Instead, the proper response would be to state that it depends. Here is some information about stainless steel that will help to identify situations in which this alloy exhibits magnetic properties, and when it does not. It is important to understand that stainless steel is not a pure magnetic metal. In fact, stainless steel is really a collective name for a steel alloy that is mixed with other metals in order to give it the properties that make the metal compound so desirable. For instance, the typical stainless steel contains just over ten percent of chromium. In fact, it is the presence of the chromium that provides stainless steel with the ability to repel permanent stains and keep looking fresh and clean over long periods of time. The chromium essentially creates a protective layer on the alloy that prevents rusting and makes the metal resistant to any real damage. Any scratches to the surface are simply filled in by this protective layer, making it possible to prevent corrosion to occur. It is the introduction of chromium into the mix that we refer to as stainless steel that makes it possible for the alloy to exhibit magnetic properties. It is important to note that other metals may be introduced into the steel compound as well as the chromium. One of these metals is nickel. Essentially, the addition of nickel to the stainless steel compound helps to strengthen the protective qualities of the chromium. Generally referred to as a 300 series, stainless steel that contains nickel is not magnetic at all. The reason is that the presence of the nickel alters the physical structure of the stainless steel and removes or inhibits any magnetic qualities. However, magnetic stainless steel does exist. The 400 series, which contains steel and chromium, but without the presence of nickel, does in fact exhibit magnetic qualities. While the degree of magnetic attraction may vary, it is not unusual for items made with the 400 series stainless steel to provide enough attraction to interact with magnets, and in some cases to allow small metal items to adhere to the stainless steel surface. However, magnetic stainless steel in consumer products does not tend to carry a strong magnetic charge, so there are not any practical home uses involving magnetic attraction.
[Re: HemiGreg]
#483637
10/04/09 03:38 PM
10/04/09 03:38 PM
Snoopy
someones got to sand down a new trim ring and see if a boundry line appears if it is chromed.
I think the picture that BJohnson posted shows the boundry line your talking about.
Greg, What is the production date on the new ring?
