Have the Repro Mopar Batteries gotten any better?
#48113
11/17/07 05:27 PM
11/17/07 05:27 PM
i need 3 maintenence free mopar batteries, 1 group 24 with yellow tops and 2 group 27 red tops. does anyone know if they have gotten any better or do they still stink, i cant keep buying these things. i just bought a Napa battery for a 1/3 of the price 1125 CCAMPS at 32 degrees.
Re: Have the Repro Mopar Batteries gotten any better?
[Re: 70challrtse]
#48120
11/18/07 09:04 AM
11/18/07 09:04 AM
i want a battery to last 5 years or more, am i dreaming?
#48121
11/18/07 10:12 AM
11/18/07 10:12 AM
Posts: 6,446 NJ-USA
HPMike
NJ-USA
Chris
Yes, you are dreaming.
Seriously, here is the deal. The old damp dry batteries had numerous problems. They gassed out, they prematurely failed, etc. The new sealed batteries are definitely an improvement. The problem is two fold, we are asking a battery to last a long time when they stay stagnant for months at a time. I know that some use battery tenders and trickle chargers which work fine, I just don't think that it takes the place of discharging and recharging the car constantly as you would with your daily driver. Another issue that I have always thought was problematic is the fact that many of these cars have old wiring that is loaded with resistance, especially in the ground circuit. This causes the battery/alternator to have to work extra hard. Maybe if a more prominent battery mfg. made them they could be improved, but??
Till then, I guess we just have to look at it as one of the costs of ownership.
Mike
[Re: HPMike]
#48122
11/18/07 11:29 AM
11/18/07 11:29 AM
Posts: 6,585 SE Pa.
LimeliteAero
SE Pa.
Chris
Mike
we dont use the cars enough for the system to work as designed to go along with the aging wires.
[Re: RUNCHARGER]
#48125
11/18/07 04:17 PM
11/18/07 04:17 PM
Posts: 6,585 SE Pa.
LimeliteAero
SE Pa.
Sorry: I don't buy that. I use non-restoration batteries in my cars and they last typically 6 or 7 years. I try to drive my cars as much as I can but my Hemi car had been sitting for 7 weeks until I started it up yesterday. I know our collector car usage is harder on the batteries but the typical auto-store batteries seem to last okay.
Sheldon
I think you are making an argument for the oposistion.
[Re: RUNCHARGER]
#48127
11/18/07 06:58 PM
11/18/07 06:58 PM
why cant they get it right? its getting real old having to buy these batteries for the correct look and i do drive my cars,especially the a990 hemi coronet and the 68 hemi roadrunner, so they really arent sitting that long.
[Re: 1MYTGTX]
#48130
11/19/07 09:39 AM
11/19/07 09:39 AM
Posts: 3,967 S.I. N.Y.
1MYTGTX
S.I. N.Y.
Cranks over my 9.5:1 440 with no problems....hot or cold. Shaved 23lbs off the front of the car as well, no acid to spill, no need to trickle charge. I will admit it was the messiest, time consuming thing but was worth it in the end.... I dare you to tell that there is a different battery inside
1MYTGTX
[Re: 1MYTGTX]
#48131
11/19/07 06:45 PM
11/19/07 06:45 PM
how is that odyssey battery held in place, i am going to try it this weekend, i have 3 batteries to do.
[Re: 1MYTGTX]
#48132
11/19/07 06:58 PM
11/19/07 06:58 PM
Does the tech archive have the post about gutting the old repo, and installing a smaller batt into the shell?
I got 6 years 8 months out of my lead acid resto battery and it was still going (although it started dying if I didn't use the car for a week..thats why I did this....)
I checked the archives, and still couldn't find the new battery into old shell trick. I had considered that, but without some instruction, I didn't want to cut the battery apart. Could I get some help with that please? Thanks.
BTW, beautiful engine compartment 6T9
