Page 5 of 5 1 2 3 4 5
Re: NO BRAKES [Re: MR_P_BODY] #479388
09/26/09 01:58 PM
09/26/09 01:58 PM
Az
Crizila Offline
Crizila  Offline
Az
I can make all of the above scenerios not apply. Was racing my 63 Plymouth Max wedge car in 65 when I missed the 2-3 shift ( at the time I was running a hemi 4-spd )and had a major clutch explosion. Took out the bell-housing ( oil pan fell down on to the center link ), most of the flywheel, Brake line ( single master in 63 ), blew out the right front tire, took out the guys windshield I was racing with ( we were side by side when it blew). Coasted through the lights at 78 mph. Fortunately, the track I was at ( US30 in Indiana )had a long shut down area with lots of tall grass on ether side. Got the car stopped just as the ambulance pulled along side. I stepped out unscratched. Car wasn't so lucky. I was supprised at how many clutch springs were sitting on top of my cross-ram manifold. It wasn't pretty.
Fastest 300
Re: NO BRAKES #479389
09/26/09 03:02 PM
09/26/09 03:02 PM
Rio Linda, CA
John_Kunkel Online content
John_Kunkel  Online Content
Rio Linda, CA
i lost my brakes in my 63 plymouth 7 years ago at island dragway which has a little shutdown area,
never would i want to drop it in reverse, but i guess pushing my dash trans. buttons to reverse might be an option in the future.
If the valve body is automatic that won't work, the cable shift transmissions (including the old iron TF) have a Reverse blocker valve that prevents engaging Reverse when traveling forward more than a couple of mph.
Re: NO BRAKES [Re: John_Kunkel] #479390
09/26/09 03:23 PM
09/26/09 03:23 PM
Cali S.B
Sub95 Offline
super gas
Sub95  Offline
super gas
Cali S.B
Just remember to brace yourself if you go into Reverse as it will throw you forward hard
been here before with a old shoe box nova, bad shifter cable, doing about 45-50 went for 3rd and bam hit Reverse engine died. needless to say the cable got fixed.
Re: NO BRAKES [Re: Sub95] #479391
09/26/09 03:50 PM
09/26/09 03:50 PM
SE Michigan
TS3303 Offline
TS3303  Offline
SE Michigan
whether you agree with Tony or not, we should all be thinking of a couple things before strapping in.
1. what does the shutdown and turn look like.
2. what is our plan if we can't stop (right or wrong you should have a plan).
Re: NO BRAKES [Re: TS3303] #479392
09/26/09 06:08 PM
09/26/09 06:08 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
Tony,I think Paul is just trying to drum up some transmission work
Re: NO BRAKES [Re: TS3303] #479393
09/26/09 08:02 PM
09/26/09 08:02 PM
Az
Crizila Offline
Crizila  Offline
Az
A scatter shield would be good too.
Fastest 300
Re: NO BRAKES [Re: Crizila] #479394
09/26/09 08:57 PM
09/26/09 08:57 PM
Detroit, MI
CokeBottleKid Offline
Detroit, MI
Sooo what do you do with a Lenco with 3 sprags in it and no way to get into reverse at speed?
Re: NO BRAKES [Re: CokeBottleKid] #479395
09/26/09 09:26 PM
09/26/09 09:26 PM
Q
Quicktree Offline OP
Q
you have no worries it will never make it out of the garage
Re: NO BRAKES [Re: Quicktree] #479396
09/27/09 12:35 AM
09/27/09 12:35 AM
Detroit, MI
Detroit, MI
With comments like those you'd better know how to stop a car with no brakes... I might have to make an un-announced visit to the pits next time you're running.
Re: NO BRAKES [Re: Quicktree] #479397
09/27/09 12:37 AM
09/27/09 12:37 AM
Gainesville,FL
goldmember Offline
goldmember  Offline
Gainesville,FL
Nothing to add to that!!!
Re: NO BRAKES [Re: 72Challenger] #479398
09/27/09 02:04 AM
09/27/09 02:04 AM
Richmond, Tx. (Houston)
GTSDave Offline
GTSDave  Offline
I would have pull the chutes, hit the clutch pedal and go to 3rd...then repeat it going into 2nd and 1st...
No chute on mine, well not yet that is. But the rest of that plan will work for me. Guess not many people running 4-Speeds anymore.
Hit reverse in my mom's Chevy van when I was a teenager. It had a 350 and 4:11's. I was running about 60 and missed neutral. It killed the engine instantly. Did not lock up the tires. Pulled it back into N and restarted, shifted to drive and went home. Two weeks later it was in the shop for a new tranny. I am sure it was my stunt that toasted it.
-Dave
PLEASE Pray for our brothers and sisters in harms way.
If you are the owner of a GTS us at the GTS Registry www.gtsregistry.com
Re: NO BRAKES [Re: GTSDave] #479399
09/27/09 08:24 AM
09/27/09 08:24 AM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
I shifted in reverse on my very first car I owned as I put a shift kit in it and was running it thru the gears down the road.Rear locked up,but the car was fine,no trans damage.318/904 in a Duster.
Nautilus Racing-
