Re: NO BRAKES
[Re: 65dragnet]
#479332
09/25/09 04:25 PM
09/25/09 04:25 PM
Posts: 7,131 Amarillo, Texas
BBR
Amarillo, Texas
Perform in "inverted Rockford".
Crank the wheel and jam it in reverse!
Ok Tony-Wan Kenobi, what's the answer?
Drag Week 2011 - 77th place - DD Drag Week 2012 - 2nd place SRBB N/A Drag Week 2014 - Kapooya RMRW 2018 RMRW 2020
Re: NO BRAKES
[Re: John_Kunkel]
#479333
09/25/09 04:27 PM
09/25/09 04:27 PM
Quicktree
Put it in Reverse.
I knew one of you tranny guys would know. this is a last resort after down shifting and what ever you can do scrub off speed hasn't worked. you use reverse to lock up the rear wheels. you put it in reverse and pull it out and repeat untill the car stops. sometimes you don't have a lot of time so you have to think quiclky. this will stop the car and I would rather do this than go off the end of the track.
Re: NO BRAKES
[Re: Quicktree]
#479337
09/25/09 04:30 PM
09/25/09 04:30 PM
Posts: 716 Indiana
65dragnet
Indiana
So this will work with a transbrake car where reverse is neutral via the transbrake button ?
E. Williams 65 Coronet 500 3400lbs w/d, 446, Indy EZ'S, A&A transbrake,Comp 650 lift cam, 6.50 @ 105 mph 1/8th 10.25 @ 130mph 1/4
Re: NO BRAKES
[Re: camastomcat]
#479338
09/25/09 04:31 PM
09/25/09 04:31 PM
Quicktree
Dump laundry, click off motor, downshift to first, and hit transbreak.That's what I would do
you never turn the motor off, you would be done. only way I would click it off is if the throttle stuck.
Re: NO BRAKES
[Re: 65dragnet]
#479339
09/25/09 04:36 PM
09/25/09 04:36 PM
Quicktree
I think you would have to mash the button.
Re: NO BRAKES
[Re: 65dragnet]
#479341
09/25/09 04:42 PM
09/25/09 04:42 PM
Quicktree
well, yes ! Thanks good info ! Hope I never have to try it !
I did try it once by accident, thats how I knew the answer. many many years ago I was driving and very low on gas. coming over a bridge I decided to put it in neautral to save some gas. oops it went into reverse at 60 mph locked up the rear wheels and scared the crap out of me snatched in back down and went on my way.
Re: NO BRAKES
[Re: camastomcat]
#479346
09/25/09 04:49 PM
09/25/09 04:49 PM
Quicktree
The pump is still turning and you wouldn't be done, and by the way, what makes you the expert? Have you ever had it happen? I have!
looknumnuts I was just trying to save somebodies butt. no expert here on anything. just some info I shared.
