Will a 440 fluid damper work on a race built hemi? #479066
09/25/09 09:30 AM
09/25/09 09:30 AM
East Coast, NJ
fig426 Offline OP
fig426  Offline OP
East Coast, NJ
A friend of mine has a fluid damper (fliudampr) off a 440. I'm building a 528 hemi. Will the damper work on the hemi?
Chris from New Jersey
Re: Will a 440 fluid damper work on a race built hemi? [Re: fig426] #479067
09/25/09 09:33 AM
09/25/09 09:33 AM
Deerfield, Ohio
70dusterjohn Offline
Deerfield, Ohio
Yes the numbers listed are the same... It will work...
Re: Will a 440 fluid damper work on a race built hemi? [Re: fig426] #479068
09/25/09 11:50 AM
09/25/09 11:50 AM
You may have a pulley alignment problem, which is normal when mixing Hemi and all ohter B and RB dampener and pulleys. Call March pulleys, they probally have a custom aluminum one for that application
Re: Will a 440 fluid damper work on a race built hemi? [Re: fig426] #479069
09/25/09 12:55 PM
09/25/09 12:55 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
Just a word of caution make sure it fits real tight!!! I had one on a 440 and had to hone it a bit as it was too tight (may because of swelling from having crank hardened) Then I thought I'll save $5 and use it on my KB crank for a 542. well it went on really easy. (could tap it on with a big rubber hammer??) well it started to rattle and worked itself oblong before welding itself to the crank and braking every main web out of the engine and the crank then in 3 pieces!! RIP 542.
I have a new fluid on my 452 and it stays there when I start my next 542 project!!
Re: Will a 440 fluid damper work on a race built hemi? [Re: Dodgem] #479070
09/25/09 01:35 PM
09/25/09 01:35 PM
East Coast, NJ
fig426 Offline OP
fig426  Offline OP
East Coast, NJ
Thanks all!!
Re: Will a 440 fluid damper work on a race built hemi? [Re: fig426] #479071
09/25/09 07:55 PM
09/25/09 07:55 PM
Illinois
CRE2004 Offline
super gas
CRE2004  Offline
super gas
Illinois
IMHO, those dampers are better suited to low rpm steady state industrial applications. I won't run them.
Re: Will a 440 fluid damper work on a race built hemi? [Re: CRE2004] #479072
09/25/09 07:59 PM
09/25/09 07:59 PM
, nothing but bearing problems when i ran one, my bearings after 60 passes were all smeared, i raced the beaerings, same thing again.
i went to a ATI super balancer and no more wiped bearings.
they are junk for any decent HP motor.
Re: Will a 440 fluid damper work on a race built hemi? #479073
09/25/09 09:28 PM
09/25/09 09:28 PM
Minnesota
Barnstorm Offline
Barnstorm  Offline
Minnesota
Yeah....My engine builder says the're no good. ATI here. Motor happy.
The little old lady from Pasadena is back!
Re: Will a 440 fluid damper work on a race built hemi? #479074
09/25/09 09:46 PM
09/25/09 09:46 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Then my junk low powered 7500+ rpm motor must be the exception or maybe I got a good one.
Re: Will a 440 fluid damper work on a race built hemi? [Re: Thumperdart] #479075
09/25/09 10:58 PM
09/25/09 10:58 PM
it's easier to just blame the damper.
Re: Will a 440 fluid damper work on a race built hemi? [Re: fig426] #479076
09/26/09 01:29 AM
09/26/09 01:29 AM
AndyF Offline
AndyF  Offline
I've used them for years without any problems but some engine builders don't like them. I probably wouldn't put a Fluidamper on a high winding Comp motor but no worries on a typical stroker big block or Hemi.
Re: Will a 440 fluid damper work on a race built hemi? [Re: AndyF] #479077
09/26/09 02:24 AM
09/26/09 02:24 AM
the complaints I have heard on the Fluid Dampener are all from the northeast states where it gets cold, it seems that the fluid in the Fluid Dampeners turns to jelly in the cold and does not keep in the liquid form like it is normally, which makes the motor go out of balance and does cuase damages. A lot of the 500 C.I.Pro Stockers ran them for years They didn't race in the cold either
Re: Will a 440 fluid damper work on a race built hemi? [Re: AndyF] #479078
09/26/09 08:38 AM
09/26/09 08:38 AM
Virginia Beach, VA
O
Old School Offline
Old School  Offline
O
Virginia Beach, VA
i have one on every one of my motors. some more than 15 years.......
68 cuda formula S 588" bb 5sp
70 CUDA CONVERT 500" 5SP (SUBLIME)
70 CUDA CONVERT 500" 5SP (PLUMCRAZY):TOO MUCH HORSEPOWER, IS ALMOST ENOUGH!
Re: Will a 440 fluid damper work on a race built hemi? [Re: Cab_Burge] #479079
09/26/09 10:38 AM
09/26/09 10:38 AM
Q
Quicktree Offline
Quicktree  Offline
Q
guess you didn't read eddie's story of 5 or so broken cranks in circle track motors down here. swapped it out with an ATI and no more broken cranks.
Re: Will a 440 fluid damper work on a race built hemi? [Re: Quicktree] #479080
09/26/09 11:08 AM
09/26/09 11:08 AM
Alberta Canada
StrokerAspen Offline
Alberta Canada
If the engine is balanced properly, why would you ever need a fluid dampener?
Re: Will a 440 fluid damper work on a race built hemi? [Re: StrokerAspen] #479081
09/26/09 12:07 PM
09/26/09 12:07 PM
every engine needs some sort of dampener to dampen harmonics, which all engines have. it's really just a question of which "type" of dampener to use.
Quicktree,i remember reading one of Eddie's posts with something to that effect. keep in mind those are mid to high to mid to high to mid, etc, etc. high rpm SBC motors with the tiny little snouts on them. IMO, that's not a good environment for any fluid type dampener, regardless of brand. also note that fluid dampers are much heavier typically than the ATI, Romac, BHJ, etc. etc. that heavy rotational inertia could have something to do with the problem Eddie had. those dampers aren't normally my first choice, but so far, every one i've used (probably over 100 of them) has worked just fine.
Re: Will a 440 fluid damper work on a race built hemi? #479082
09/26/09 12:22 PM
09/26/09 12:22 PM
Someplace you aren't
SomeCarGuy Offline
SomeCarGuy  Offline
How do you all feel about Romac brand?
I want my fair share
Re: Will a 440 fluid damper work on a race built hemi? [Re: SomeCarGuy] #479083
09/26/09 01:05 PM
09/26/09 01:05 PM
Suffolk,VA
dragracedr Offline
dragracedr  Offline
Suffolk,VA
Don't mean to butt in and hijack the thread, but what's wrong with a BHJ unit. I talked to an old-hand Nascar hemi builder who said that their testing revealed a 25 hp gain, BHJ over Fluidamper,on the dyno and the engines smoothed out. Fluid dampers are heavy. Maybe tuning for extended, consistent rpm ranges has a bearing?
Re: Will a 440 fluid damper work on a race built hemi? [Re: fig426] #479084
09/26/09 01:22 PM
09/26/09 01:22 PM
Thigh-Gap Junction
@#$%&*! Offline
New user name, Same old jerk!
@#$%&*!  Offline
Thigh-Gap Junction
A couple of points:
The fluid in a Fluidamper isn't a fluid, it's a gel.
The damper is for torsional vibrations, it has nothing to do with the balance of the motor.
Elastic type dampers will work best at a certain frequency of vibration and the effect will diminish the farther you get from that number. I expect that the viscous (fluid) type dampers will be effective over a wider range of engine speeds.
Re: Will a 440 fluid damper work on a race built hemi? [Re: Quicktree] #479085
09/26/09 04:29 PM
09/26/09 04:29 PM
I didn't read Eddies story why would I I wonder which brand of Fluid Dampeners he was selling
