Page 1 of 3 1 2 3
Post your 360 engine combos #47850
11/10/07 09:13 PM
11/10/07 09:13 PM
Marine Corps Base Hawaii
DemonKyle Offline OP
USMC LCPL
USMC LCPL
I am looking at having a 360 built as my 318 just lost a rod. It will be a stock block, mostly street driven and once in a while a strip car. Looking for something that is reliable and daily drivable. Have at it boys
Re: Post your 360 engine combos [Re: DemonKyle] #47851
11/10/07 09:31 PM
11/10/07 09:31 PM
On The Boat, On The Lake, Wa. ...
amxautox Offline
Still Retired. Still Posting on Moparts. A Lot.
amxautox  Offline
What car? What tranny? What rearend gear ratio? What altitude?
Tom
"Everyone should believe in something; I believe I'll go fishing."
-Henry David Thoreau
Men and fish are alike. They both get into trouble when they open their mouths
author unknown
Re: Post your 360 engine combos [Re: amxautox] #47852
11/10/07 09:33 PM
11/10/07 09:33 PM
USMC LCPL
USMC LCPL
71 Demon,904, 3.21 8 1/4, Southern Cali.
Re: Post your 360 engine combos [Re: DemonKyle] #47853
11/10/07 09:35 PM
11/10/07 09:35 PM
amxautox Offline
amxautox  Offline
There ARE mountains in S. Calif.
Tom
author unknown
Re: Post your 360 engine combos [Re: amxautox] #47854
11/10/07 09:36 PM
11/10/07 09:36 PM
USMC LCPL
USMC LCPL
Riverside, Temecula area... Geez Tom, we're awfully picky tonite
Re: Post your 360 engine combos [Re: DemonKyle] #47855
11/10/07 09:38 PM
11/10/07 09:38 PM
amxautox Offline
amxautox  Offline
Regular gas = Maybe 8 1/2 to 1 compression ratio, .455 lift, 214 dur. cam. Or a little stronger than those if ya want better times at the strip.
Tom
author unknown
Re: Post your 360 engine combos [Re: amxautox] #47856
11/10/07 09:41 PM
11/10/07 09:41 PM
USMC LCPL
USMC LCPL
I was looking at no more than 9.5:1, no bigger than about a 500 cam, (might go with the smaller thumpr cam), worked 360 heads, etc
Re: Post your 360 engine combos [Re: DemonKyle] #47857
11/10/07 09:52 PM
11/10/07 09:52 PM
Candler,NC / Myrtle Beach, SC
JDMopar Offline
JDMopar  Offline
Buy the Summit Racing rebuild kit for a 360.It has good pistons (H405P's),good gaskets,good bearings,and a good price! Buy a Crane 150052 cam and set it at 4 degrees advanced.Use an Edelbrock Performer RPM,RPM Airgap,or an LD340 if you can find one.Use a 1" 4 hole spacer under the carb,and use a decent ignition system.Use stock 360 or Magnum heads with a good 3 angle valve job and good springs matched to the cam. Here's what not to do Don't use KB107 pistons,because they will give too much compression for a street motor.Don't use the cheap Chinese Air Gap intake...they are junk! Good luck kid,and sorry you blew your 318 up.
Re: Post your 360 engine combos [Re: JDMopar] #47858
11/10/07 09:59 PM
11/10/07 09:59 PM
St. John's Newfoundland
440newport Offline
440newport  Offline
Mine is a '79 360 with
Comp XE268 cam (224/230@.050, .477/.480)
Speed Pro H116CP pistons (9.66 CR)
80's "345" heads with 2.02 valves put in
Perf RPM manifold
MP Windage tray
Melling HV oil pump
Heddman 1 5/8 headers
Holley 670 carb
Good for I guess 340-350hp, pulls plenty of vacuum for power brakes and idles at 600rpm in my '80 Mirada I drive every day even through the winter last year. I think it's a great driver combo.
Re: Post your 360 engine combos [Re: DemonKyle] #47859
11/10/07 10:08 PM
11/10/07 10:08 PM
85086
moparpollack Offline
Lil Herman
Lil Herman
85086
360 crate short block with eddy heads m-1 intake demon carb comp magnum rockers.
Re: Post your 360 engine combos [Re: JDMopar] #47860
11/10/07 10:11 PM
11/10/07 10:11 PM
USMC LCPL
USMC LCPL
The motor is being built in a shop by a friend. I have a 600 holley, ld340 and Dougs headers that are already on the 318 that are being switched to the 360
Re: Post your 360 engine combos [Re: DemonKyle] #47861
11/10/07 10:12 PM
11/10/07 10:12 PM
Alton, IL
Dakota_Don Offline
Dakota_Don  Offline
Alton, IL
.030 over
274H comp cam
RPM air gap
10.1 CR
770 holley
headers
904 trans
ported and polished 587 heads w/ 2.02 and 1.60 SS valves
roller rockers
FBO ignition sys
96 Dak
Re: Post your 360 engine combos [Re: DemonKyle] #47862
11/11/07 12:01 AM
11/11/07 12:01 AM
JDMopar Offline
JDMopar  Offline
Sounds like you've got some key parts to swap onto the 360 One other thing you will need is a B&M flex plate to mate the externally balanced 360 to your existing convertor.If you plan on upgrading convertors while you have it apart,you can just get one that's balanced for a 360 and use the stock flex plate. I have a 360 built like I described,and it runs great in my 71 Challenger.It should run better in your A-body because it's several hundred pounds lighter than my Challenger.
Re: Post your 360 engine combos [Re: DemonKyle] #47863
11/11/07 12:22 AM
11/11/07 12:22 AM
Milwaukee, WI
Prince_Valiant Offline
Milwaukee, WI
A good one I had:
Never measured...the compression could have been b/w 8.2:1 although the guy said they were "9.0:1" pistons (but they were far down the hole...but I digress).
Stock 360 heads, 1.88 valves, 3 angle valve job.
MP .450/.455 cam, 268/272 duration
Edlebrock performer intake (better ones out there...this one was free).
Holley 4016 600 cfm carb, electric choke.
Hedman headers
In a valiant with 4 speed OD manual trans, 2.94 gears this thing started great, idle great in traffic, got as high as 25mpg if you really took it easy on the hwy (typical tank was 18mpg), and even better, went 14.2's all day at the track This was in a 4 door 1976 valiant.
Re: Post your 360 engine combos [Re: Prince_Valiant] #47864
11/11/07 12:55 AM
11/11/07 12:55 AM
my own world
theraif Offline
theraif  Offline
my own world
89 to 91 i beleave 360 truck heads are good aka 308
Re: Post your 360 engine combos [Re: theraif] #47865
11/11/07 09:52 AM
11/11/07 09:52 AM
Upper Midwest
MoparforLife Offline
Upper Midwest
with a relativly stock rebuild I highly recommend the Crower 267 HDP cam with the springs to go with it. It has lots of drivability, vacume and has good low end. 267/272 adv. dur with 475/485 lift. A great little cam. Ust this with a good intake like a LD4B or LD340 with a 650 carb and you will be happy.
Re: Post your 360 engine combos [Re: JDMopar] #47866
11/11/07 10:04 AM
11/11/07 10:04 AM
NY
old340dog Offline
old340dog  Offline
NY
There's a cheap Chinese version of the air gap out there?Is there anything these guys don't try to copy. Who makes its and who sells it? guess I want to make sure I don't get one of these on my rebuild.
old340dog
Re: Post your 360 engine combos [Re: old340dog] #47867
11/11/07 10:22 AM
11/11/07 10:22 AM
its a crosswind,I just saw it in Egay when I went over there to look for an intake for my mag headed 360.
Re: Post your 360 engine combos [Re: DemonKyle] #47868
11/11/07 11:02 AM
11/11/07 11:02 AM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
To bad you didn't live closer. I would give you a ride in my 360 street truck. Engine will go up for sale when I get further along on my 416...
Re: Post your 360 engine combos [Re: DemonKyle] #47869
11/11/07 12:00 PM
11/11/07 12:00 PM
Mass
dgc333 Offline
dgc333  Offline
Mass
Here is my 360 build;
* 360, .030 over KB107 pistons at zero deck
* Magnum cylinder heads with 0.039" gasket
* Comp XE268H cam 224/230@0.050, .509/.512 with 1.6 ratio magnum rockers.
* Professional Products Crosswind intake. Don't believe the naysayers that it's junk and a cheap copy. It's no more a copy of the Air Gap than an M1 dual plane is of a Performer. Side by side it's obvious it's not a copy plus the casting finish quality is better than an air gap.
*I am using a Holley 670 Street Avenger and Hedman headers.
This engine is making around 370 HP based on 102 mph trap speeds in the 1/4. Has 10.6:1 compression and with the closed chamber magnum heads and ideal quench runs fine on 89 octane.
I have just shy of 20k miles on it since installing it in my 68 Barracuda in Jul 05. It gets 17-18 mpg around town and 21-22 on the hiway.
The only down side to the engine is the XE cam's aggressive ramps makes for a noisey valve train compared to what I would expect from a hydraulic cam.
Dave Clement Pembroke, MA 03 PT Cruiser GT Turbo 99 Dakota SLT+ CC 4x4 68 Barracuda sport coupe http://home.comcast.net/~dgc333/
Page 1 of 3 1 2 3
