Page 18 of 18 1 2 16 17 18
Re: Super duper MPG 273/318 experiment ! NUMBERS!!!!!!! [Re: Rug_Trucker] #47847
08/01/11 11:59 PM
08/01/11 11:59 PM
Kalispell Mt.
HotRodDave Offline OP
Kalispell Mt.
So 20% of his fuel was just dumping out the tail pipe un-burned? Either he changed something else like mabey added a chip or taller gearing or... mabey he doesn't want anyone to know he got suckered so he is throwing out some dreamed up number The only real world experiance I have had proved that the physics was right, takes more energy to run them than what you get back from them.
Re: Super duper MPG 273/318 experiment ! NUMBERS!!!!!!! [Re: HotRodDave] #47848
08/02/11 01:59 PM
08/02/11 01:59 PM
Not2farfromNashville, TN
Rug_Trucker Offline
Rug_Trucker  Offline
Nope. I've known him since 1978. He isn't a BS'er. It was a bone stock Cummins, and gearing.
You can believe it if you want.
"The only thing to do for triumph of evil is for good men to do nothing"
"NUNQUAM NON PARATUS!"
Re: Super duper MPG 273/318 experiment ! NUMBERS!!!!!!! [Re: Rug_Trucker] #47849
08/23/13 11:14 AM
08/23/13 11:14 AM
Earth
Rob C Offline
Rob C  Offline
Earth
It all in the cruise rpm and the locking up of the converter all in the most Efficent spot. I so believe hot rod. This is not the first time I heard this and two very good and long time freinds told me the same thing. The truck simply just hot better mileage on the hwy. towing something heavy.
I think it may having something to do with the converter and the rpm range which the engine is running at while towing forcing the converter to work better/harder.
