Page 2 of 18 1 2 3 4 17 18
Re: Super duper gas miledge 273 experiment !!! [Re: Prince_Valiant] #47527
11/12/07 10:32 AM
11/12/07 10:32 AM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
if you're looking more for economy than power, I'd look for a 7.25 or 8.25 axle. less mass, which is a good thing. also, I'd probably look at 2.94-3.23 gears with the OD. I'd also look at an A833OD instead of the A500 (less mass, and planetary geartrains are not as efficient as regular bevel geartrains)
another option for highway efficiency would be a slant 6 A833 (3.09 first gear, 1:1 4th) with like a 5th ave/diplomat 2.2-2.45 rear gear. technically, the least amount of geartrain loss in a manual tranny is in direct drive), and the 3.09 first will make take off tolerable.
personally, I'd go a 318 roller as a base, either using the 302's that came on it, or the mag heads. I'd use a hughes HER9204AL (192/204@.050, 114LSA, .459/.471" lift with 1.5's and .490/.502" lift with 1.6's--that's some pretty fast ramps)for the cam, and KB167's (or equivalent KB forged) for pistons. frankly, I don't think rod weight would come into play that much, I'd probably use the magnum stockers. that should be right about 10:1, I'd go super tight on quench, probably ~.035"....I bet it would still run on pump premium, you might have to play with where you install the cam, or timing. thermal barrier coat the tops of the pistons and the combustion chambers, and pump gas should be fine.
couple that with a standard eddie performer intake (as they seem to make the most torque down low of the small block 4bb intakes, at the expense of upper RPM power), headers and a small t-quad. or if you use the mag heads, I'd use a stock mag intake, smooth out the throttle body, and run the whole thing with a megasquirt, or GM TPI computer....you can get way more creative on fueling and timing curves with EFI to max out economy.
2017 Grand Cherokee Overland
Re: Super duper gas miledge 273 experiment !!! [Re: patrick] #47528
11/12/07 10:47 AM
11/12/07 10:47 AM
Not2farfromNashville, TN
Rug_Trucker Offline
Rug_Trucker  Offline
Dave, I have a stocker 360 cam, and I have a Melling Blue Racer Wolverine RV cam. It is a .414 single pattern cam. Take you pick. I put 9K on it then switched engines and bought a Comp .425 lift RV cam.
I also have a SP2P Eddie intake. It is the TQ mount one.
You can have either cam for free.
The Eddie might be better than the Offy (Offy on my van engine) I might want some money for that or maybe trade for something.
I am thinking the SD is over kill and will kill the torque.
"The only thing to do for triumph of evil is for good men to do nothing"
"NUNQUAM NON PARATUS!"
Re: Super duper gas miledge 273 experiment !!! [Re: mopowergtx] #47529
11/12/07 12:04 PM
11/12/07 12:04 PM
murfreesboro, TN
Q
Qbird Offline
Qbird  Offline
Q
murfreesboro, TN
Yes, however your ram has a lockup converter, as did the later 318 powered cars. Take a stock 60's 3sp trans, stick a 2.2 rear gear into it and at cruise speed on the highway your rpms will be so low that the converter is slipping.
He said he was going to use a
A-500 trans
Thats a lock up torque converter trans same as my Ram. Dave I messed around with my Ram today watching the tach and my speed in OD with a load of firewood in the back. 10-15% uphill grade at 1800 rpm in OD at around 57 mph and it was fine. Wasn't losing any speed. Was pulling fine. I like the consesus here that you need to put it between 1800-2000 at your normal cruising speed. Dave if you could get your hands on a 7 1/4 or 8 1/4 that would bolt in it that would be instant mpg bonus versus the heavier 8 3/4. Lightweight aluminium wheels sounds like a good idea too. What year did the Dippys and 5th Aves get roller cam motors? Theres a 86 I believe here next to my house I been thinking about getting for the K-member on the cheap. I need to come down to Tenn anyhow and see Defeo, guy owes me twenty bucks! [/quot
20 Bucks!!!...how do I owe you 20 bucks?....
Re: Super duper gas miledge 273 experiment !!! [Re: Qbird] #47530
11/12/07 12:16 PM
11/12/07 12:16 PM
Rug_Trucker Offline
Rug_Trucker  Offline
Did you lose a bet Tony? He may spend more in gas to collect the money!
Re: Super duper gas miledge 273 experiment !!! [Re: Rug_Trucker] #47531
11/12/07 12:44 PM
11/12/07 12:44 PM
Eastern Ohio
mopowergtx Offline
mopowergtx  Offline
Eastern Ohio
Gas is expensive. Thats right it was $50.
Re: Super duper gas miledge 273 experiment !!! [Re: mopowergtx] #47532
11/12/07 01:02 PM
11/12/07 01:02 PM
Rug_Trucker Offline
Rug_Trucker  Offline
And don't forget the price od a can of Whhoopazz!
Instead of Defeo rocks? "Warning this guy owes me twenty bucks!"
Re: Super duper gas miledge 273 experiment !!! [Re: HotRodDave] #47533
11/12/07 01:17 PM
11/12/07 01:17 PM
The Netherlands
BigBlockMopar Offline
The Netherlands
.060 over bore
Why the .060 overbore?
Re: Super duper gas miledge 273 experiment !!! [Re: mopowergtx] #47534
11/12/07 01:59 PM
11/12/07 01:59 PM
murfreesboro, TN
Q
Qbird Offline
Qbird  Offline
Q
murfreesboro, TN
What was the bet???...did I sleep through this or something?
Re: Super duper gas miledge 273 experiment !!! [Re: BigBlockMopar] #47535
11/12/07 02:44 PM
11/12/07 02:44 PM
Montana
FuryUs Offline
FuryUs  Offline
Montana
I believe that was to unshroud the bigger Magnum valves.
Re: Super duper gas miledge 273 experiment !!! [Re: FuryUs] #47536
11/12/07 03:11 PM
11/12/07 03:11 PM
Southern Cal
Noblewk Offline
Noblewk  Offline
Southern Cal
For a torque motor, the smaller valved 273 heads would be a better combo since the port velocity would be up. While I'll agree the Magnum Heads flow better, but for mileage you don't want to be spinning the motor in the higher RPM's.
Keep internals light, RPM's Down, and about 8 / 8.5 to 1 so you can get away with running the cheap gas (Your looking for economy). Shorty headers would be ok but not nessessary.
66 Dart GT, 402 11.18:109 Best 63 1/2 Galaxie 500XL 406 4Speed 13.20:103 Best 2000 Ram 2005 Durango Hemi.
Re: Super duper gas miledge 273 experiment !!! [Re: Noblewk] #47537
11/12/07 03:29 PM
11/12/07 03:29 PM
Kalispell Mt.
HotRodDave Online content OP
HotRodDave  Online Content OP
Kalispell Mt.
I figured the high swirl ports of the mag would be just as efficent as the small factory 273 ports with puny swirl and flow. Let me know if you guy think I am wrong. I think the 302 heads might be the best way to go but I don't have any sittin around.
As for the compression ratio, since higher mechanical compression generaly makes around %4 more efficency it would make up for the %3 differance in price and make a little more power to boot, that is why I say 93 octane. Spend a little more on a tank but drive a little farther on it. That would mean less stops for fuel and stop and go also hurts miledge.
Re: Super duper gas miledge 273 experiment !!! [Re: HotRodDave] #47538
11/13/07 10:54 AM
11/13/07 10:54 AM
Pikes Peak Country
TC@HP2 Offline
TC@HP2  Offline
Pikes Peak Country
I wouldn't get too hung up on spinning the engine slower just to keep fuel consumption down. You will need to match the final drive ratio to the engine combination. You will get better mileage running your engine at a reasonably built torque peak than you will be simply turning it slower. If your out of the power band, then you will have to apply more throttle, more throttle angle results in more fuel consumption, regardless of rpm involved.
The 440 in my truck will produce better mileage figures at 3200 cruising rpm , just under its torque peak, than it will at a steady state cruising rpm of 2500. But, my engine combo is built to be optimized at 75 mph, which coincides with that 3200 rpm number. That is achieved using a very small cam. To get anything smaller than most basic off the shelf variaties will require some custom grind of some sort.
I'd also figure some way to use the magnums. They are a newer head which will get better results for flow, swirl, tumble and the resulting burn than the 40 year old 273 heads. A lot more thought and effort went into those magnums than the earlier LA heads.
Re: Super duper gas miledge 273 experiment !!! [Re: HotRodDave] #47539
11/13/07 11:35 AM
11/13/07 11:35 AM
Charlotte, NC
Orange_Crush Offline
Belieber!
Belieber!
Charlotte, NC
I would recommend a good multi-port EFI setup. That way you would not sacrifice driveability AND it would maximize your efficiency (read power output and mileage). Perhaps you can adapt a pre-'96 Ford 4.6L setup to your needs.
1970 Dodge Charger R/T Hemi Orange U-code 4-speed
1971 Jaguar E-Type Series 3 V-12 4-speed 2+2 Signal Red.
Re: Super duper gas miledge 273 experiment !!! [Re: TC@HP2] #47540
11/13/07 12:23 PM
11/13/07 12:23 PM
Kalispell Mt.
Kalispell Mt.
The peak tq of a 273 2bbl was factory rated at 260lbft at get this... 1600 rpm. I am looking to keep the rpms low for this reason. I am also trying to figure ways to make even more tq at a lower than stock rpm. Even with this high gear combo I will still be OVER the peak tq at cruise speed of 70mph so don't get your pannys in a wad and say I need more lower gear ratio. Just trying to come up with creative ways to make this happen.
Re: Super duper gas miledge 273 experiment !!! [Re: HotRodDave] #47541
11/13/07 12:55 PM
11/13/07 12:55 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
The 340 in my 72 Swinger gets about 17mpg hwy @ 70mph and the car runs 13.80's. Don't see why you couldn't see those numbers.
Re: Super duper gas miledge 273 experiment !!! [Re: HotRodDave] #47542
11/14/07 08:09 AM
11/14/07 08:09 AM
USA
3
360view Offline
Moparts resident spammer
360view  Offline
3
USA
Some thoughts:
Read up on
"Atkinson Cycle"
"Miller Cycle"
"Delayed intake valve closing"
http://en.wikipedia.org/wiki/Atkinson_Cycle
and consider even higher static compression ratio that is compensated for by reduced 'dynamic' compression ratio.
The greater amount of expansion on the power stroke will help fuel economy. Compression ratio is also expansion ratio. Expanding 12 to 1 on the power stroke helps, even if you don't have the octane rating to do that on the compression stroke without detonation. Prius, Honda Insight, and Ford Escape engines all use these ideas to run 87 octane gasoline on 12 static compression ratio.
Calculate your average 'piston speed' with the short stroke 273 ci and then set up the highway cruise gearing to get piston speed around 1000 feet per minute and vacuum inside the intake manifold about 6-8 inches of vacuum. This is the 'island' of maximum fuel economy that stands above the 'ocean' of otherwise inferior fuel economy for most gasoline engines, when measured by pounds of fuel consumed to make a given horsepower for an hour. The 800 to 1200 foot per minute piston speed range is where friction & torque are optimum for fuel economy...above this speed range torque peaks, then volumetric efficiency peaks, then horsepower peaks but neither are best for fuel consumption.
see this complicated link for island and ocean fuel economy graphs of a TDI diesel converted to sparkplugs and running on methanol and ethanol:
http://www.epa.gov/otaq/presentations/sae-2002-01-2743.pdf
The EPA guys above use
'mean effective pressure' and rpm,
but you can use the stroke of the TDI crankshaft to convert their graph to piston speed along the bottom.
There is also a 'generalized' gasoline engine fuel economy graph in this 'classic' book by the father and son Taylors:
http://tinyurl.com/3dgkod
there is also a graph showing optimum quench area by piston diameter
Keep in mind that MPG is not dominated by engine efficiency. Most engines are nearly the same efficiency at their best spot..varying mostly on compression ratio.
To get better MPG
make tire rolling resistance lower
make aerodynamic drag lower
make mass lower
...then re-gear drivetrain to optimum horsepower for all those improvements:
A long read on MPG improvement by tire rolling resis, aero and engine eff...almost a small book:
http://tinyurl.com/kgqlz
Good luck and please keep posting on your project.
Re: Super duper gas miledge 273 experiment !!! [Re: 360view] #47543
11/14/07 10:30 AM
11/14/07 10:30 AM
Kalispell Mt.
Kalispell Mt.
Thanks 360View! Some good reading there. The descriptions there seem to me like they want a cam ground with wide lobe seperation and then retarding it to keep the exhaust opening/closeing the same, is that how it sounds to you? The late intake closeing will definately bleed some preasure back in the intake. I would guess this forward-backward motion of the mixture around the valve would help atomize the fuel more also and provide some increase in efficency.
Re: Super duper gas miledge 273 experiment !!! [Re: HotRodDave] #47544
11/14/07 11:42 AM
11/14/07 11:42 AM
Seattle WA
RichV Offline
RichV  Offline
Seattle WA
I doubt this backflow will help fuel atomization. I bet it makes it really difficult to tune a carb properly. Have you ever seen how a 2 stroke with a partually plugged exhaust will spit fuel out of the carb throat even at idle? This happens even when the exhaust is free flowing enough for the engine to run at 50% power. I think fuel injection is the only way to go if you want to use the Atkinson cycle. Don't discount lean cruise either, it can't really be used by the OE due to the increase in NO emissions when running lean. It will significantly increase fuel mileage. The GM tbi software tweaked for lean cruise is readily available for free. GM tbi should be sufficient for your engine and is the cheapest way to put fuel injection on a engine. However the learning curve is much longer than with aftermarket systems.
Don't discount deep gear ratios, the Corvette gets really good fuel economy on the freeway if you can keep your foot out of it. The 2008 6 speed gets 26 mpg EPA highway fuel economy. A significant factor is really low rpm in high gear. I have a a body 8 1/4 with 2.45 gears from 1975. I have heard that some Diplomats and Fifth Avenues had 2.25 gears.
Re: Super duper gas miledge 273 experiment !!! [Re: RichV] #47545
11/14/07 11:57 AM
11/14/07 11:57 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
I think you guys are going way overboard. a mild 318 (318 9:1, magnum heads, LD4B intake, small sumitt cam, 1.5 or 1.6 roller rockers, headers, Electronic ingnition, 600 carter), w/ a 4 speed O/D trans in a A-body w/ 3.23's should net easy 22 mpg...if you keep your foot out of it.
Re: Super duper gas miledge 273 experiment !!! [Re: HotRodDave] #47546
11/14/07 12:24 PM
11/14/07 12:24 PM
Madison Wi
NTOLERANCE Offline
NTOLERANCE  Offline
Madison Wi
Good luck, I love mileage experiment cars/engines. Outside the box thinking at its best. Gas will be $4.00 a gallon soon.
BUT.....
Back in the day, when there were sponsored MPG contests, mopar always sent the slant 6. At least all the ones I read about were slants.
