Re: Super duper gas miledge 273 experiment !!!
[Re: autoxcuda]
#47567
11/19/07 03:44 PM
11/19/07 03:44 PM
Posts: 16,123 Grand Haven, MI
patrick
Grand Haven, MI
the 7.25" in my '76 duster uses a sealed roller bearing w/o adjustment, so it has to be a straight roller or ball bearing...I can't remember which at the moment.
[Re: Prince_Valiant]
#47568
11/26/07 12:32 PM
11/26/07 12:32 PM
Posts: 1,692 Seattle WA
RichV
Seattle WA
For the tranny, I'd source an AL OD 833 (light weight and more efficient). For the rear end, I'd source a 7 1/4 rear with 2.94 gears for a 2.2 final drive ratio (lighter rear/gears/axles reduce losses/rolling resistance on several fronts...the closer to 1:1 a gear is, the more efficient it is with regard to frictional losses.)
A four speed with a direct drive high gear is more efficient than a overdrive trans. You can get a 2.2 something ring and pinion out of a M body. You can swap a 3.09 low gear, direct drive high gear set into a aluminum case if you want the weight savings.
[Re: dart4forte]
#47571
11/26/07 01:53 PM
11/26/07 01:53 PM
Posts: 12,419 Kalispell Mt.
HotRodDave
Kalispell Mt.
Manual trans is out of the question unless someone wants to donate a complete set up. I think with this low powerd motor the early dakota 5spd should fit and work best. The a-500 has a higher OD ratio and the trucks with them don't seem to get much if any worse miledge than the 5spds, but I would prefer the 5 spd personaly they are more fun to drive. The original 273 heads are not hardened seats. The 302 has more swirl and velocity in it also. I am torn between the 302 and MAG right now. I am in the process of moveing right now so I have not started yet, just gives me more time to plan. Keep the ideas flowing.
[Re: HotRodDave]
#47572
11/26/07 04:38 PM
11/26/07 04:38 PM
Posts: 16,143 Mesa, Arizona
dart4forte
Mesa, Arizona
I have flow number that show the 273 heads will outflow the 302. As far as hardened seats, unless you are towing and running that 273 hard and lean you don't need hardened seats. Pulled the heads off my 273 with 75,000 miles and no valve recession. 67 Dart, 273/Carter 625, electronic ignition, duel exhaust with Flowmasters, Comp 268 cam with 904 and 3:23's drove from NW to LA and back with an average of 22 MPG at average 64 MPH.
[Re: dmerc]
#47574
11/26/07 05:14 PM
11/26/07 05:14 PM
rig it up to go nuclear!!would last a lifetime.......
#47575
11/26/07 05:53 PM
11/26/07 05:53 PM
Posts: 28,067 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
I'll skip quoting all the "Prince Valiant" stuff but I do have to take exception with it. He did lots of work with numbers to show his theories. The real world blows a great big hole in it because torque production is not linear. Efficiencies of individual parts vary greatly with engine speed. The whole package will swing widely as the engine accelerates through the rpm range.
As for super stupid-low gearsets, you're killing your mileage. How many of you have a 2.2 or 2.4 geared M-body that gets better than 15 mpg in the city? It doesn't happen because the car has to work so hard to overcome the lack of torque multiplication during acceleration. Seteady state cruising is great but you've got to get up to speed first.
[Re: feets]
#47576
11/26/07 06:13 PM
11/26/07 06:13 PM
HotRodDave
Kalispell Mt.
I had a 318 87 150 longbed pickup with 2.94 gears and I got 16 in town. It had taller tires so it was more like a car would with 2.20 or 2.45 gears and more weight. And for the highway it would get 19-20 and it only had a 3spd 904 and worse aerodynamics. With a more optimized engine and drivetrain I really don't think 20 in town and even 30+ on the highway is too much to ask for(with sane driving habits and a few other car tricks).
[Re: feets]
#47578
11/26/07 08:29 PM
11/26/07 08:29 PM
Posts: 1,665 Milwaukee, WI
Prince_Valiant
Milwaukee, WI
Oh no...please quote your "exceptions".
I think one of the things people lose with "my" so called "theories" (which aren't really mine and are fairly well used in cars today...just look at how far down they get final drive ratios in this day and age) is people keep coming back with "throttle posistion" as if they believe that generating increased torque at a given speed will require a throttle that's opened further...thus putting more fuel down in the engine.
Couldn't be further off from what would actually happen.
Again, let's give a general example:
My car requires 30HP to travel down the road @ 60mph.
Doesn't matter if that's 30HP @ 3000 rpm or 30HP @ 2000rpm. It's just 30HP.
Now, HP is simply work. In this case, we can quite literally view it as the amount of air/fuel moving into and out of the cylinder at a given rate. So whether my engine is spinning 3000rpm at 30HP or 2000rpm, at the end of a minute, assuming NO friction within the engine, I will move ~ same amount of air and fuel within a given time period.
Given this (oh, and feets, please feel free to quote away should you disagree...otherwise, don't single me out again!), one can reasonably assume that the throttle posistion will be the same in either example.
Of course, it's NOT exactly the same...and this is NOT all that important. Why? because if my engine is spinning 3000rpm in a given minute, I'll generate more vacuum. More vacuum means that my carb is either going to flow MORE at a given throttle posistion, or to flow the amount to supply a given air/fuel demand, it'll take less throttle to flow the same amount (we know this is true...this is why vacuum info is given with flow data. A head will flow greater at 28mm/HG than at 20mm/HG, will it not? Don't you think it's the same with a carb?).
And still, do you think it's easy to turn an engine over? Try doing it by hand just once! That's a lot of work you've got to do just to overcome friction. Now, turn it over 1000 times in a given mile. Not easy is it? Of course, you remove all that work by gearing it lower and instead of turning 3000 revolutions per mile, you gear down and turn 2000revolutions per mile. And that's a significant amount of fuel you save by not doing this work.
Even by reading your "objections", I am not so sure you even read my post.
1979 Dodge Lil' Red Express - 360 rwhp, 13.2 @ 103mph 1968 Coronet: 318, 2.76, 15.2 @ 92mph! (SOLD) 1976 Valiant: 360, 3.90, 12.90 @ 106 (SOLD) 1989 Shelby CSX #500/500
#47579
11/27/07 02:10 AM
11/27/07 02:10 AM
Posts: 350 central IL
myduster360
central IL
Question Prince,
If the engine is using EXACTLY the same mass flow rate of fuel,(more fuel per cycle at lower rpms), how does RPM really make any difference???
In your over generalized 440 example at either 2800rpm or 1800rpm it still consumes about 14 lb/hr of gas. Correct?? You stated: "Doesn't matter if that's 30HP @ 3000 rpm or 30HP @ 2000rpm. It's just 30HP.....I will move ~ same amount of air and fuel within a given time period." So to make 30hp, you need 14lb/hr of fuel, wether you have a 440, 318, 2.2l, or 600cc. If gas weighs 6 lb/gal, your gas tank is STILL draining by at least 2.3 gal/hr regardless of the engine or its rpm.
Answer: By your arguments engine RPM(or even engine displacment) doesn't affect the rate of fuel consumption. You've talked yourself in circles because neither is actually true.
imo, you either really don't know what you're talking about or you're over generalizing and simplifing to the point of confusing yourself and others. I honestly think its the latter. Mainly because i agree with your general conclusions, but your reasoning and rational for them barely hold water. i suggest more work with the caculator before typing.
I've said it before and now agree with feets, torque vs VE isn't a straight line. Your VE example/argument is worthless.
BTW mechanical eff(friction)is a much greater % of total engine eff as rpm drop. So the thermal eff and ve both usually have to rise to maintain the same output, which is usually very unlikely given your argument for static throttle position. At a constant load friction doesn't rise nearly as quickly with rpms as VE and TE
One more thing, regardless if you're right or not, no one will respect your opinion of you're being a jerk.
1972 Swinger 3.6L Pentastar Diablo CMR tuner
#47580
11/27/07 12:17 PM
11/27/07 12:17 PM
feets
Senior Management
Senior Management
Irving, TX
PV... What's the deal? Wy get all fussy about what I wrote when you didn't even address it in your post?
I said that VE is not linear. That remains true. I didn't knock your work. Instead, I pointed out a simple flaw. You've got lots of info but when one little thing goes awry, it throws out everything related to it. Think of it as working a 6 page math problem then dividing by zero. OOPSIE! There goes all that work.
[Re: MarkZ]
#47583
11/27/07 03:55 PM
11/27/07 03:55 PM
HotRodDave
Kalispell Mt.
The 273 heads will have less velocity because they have a slightly larger port volume. Not that they would be a bad choice for that reason, they would make less pumping losses. That is also a reason for me to consider the magnums, I have a set of them and the 273 heads but no 302s...
[Re: HotRodDave]
#47585
11/28/07 01:58 AM
11/28/07 01:58 AM
dart4forte
Mesa, Arizona
I called my buddy that owns the flow bench. He recalls the velocity was greater on the 273 head vs the swirl port. He's going to pull it up on the computer and I'll post the numbers. Also remember that with the magnums you'll need the corresponding valve train and intake in order for the heads to work. There will be a lot of port mismatch with a Magnum/273.
