Re: 500+ HP from 440 How would you build it? [Re: 2boltmain] #474131
09/21/09 12:01 PM
09/21/09 12:01 PM
Central NC
gch Offline
gch  Offline
Central NC
500 hp is doable with stock heads.That being said the more effort spent on improving head flow the less radical the rest of the combo has to be.
There used to be a default 500hp combo in the tech archives.
A ported head motor won't have to turn as many rpm to make the number.It will also have more torque everywhere and be more fun to drive with a smaller cam.
Re: 500+ HP from 440 How would you build it? [Re: Blakcharger440] #474132
09/21/09 03:53 PM
09/21/09 03:53 PM
Iowa
E
eaglesguy1981j Offline OP
E
Iowa
Just out of curiousity what brand and model is that tunnelram?
It is a Weiand D port.
Re: 500+ HP from 440 How would you build it? [Re: eaglesguy1981j] #474133
09/21/09 05:25 PM
09/21/09 05:25 PM
Branson, Mo.
joedust451 Offline
super gas
joedust451  Offline
super gas
Branson, Mo.
Yes a pump gas car. Im not losing the T-ram sorry. Its staying. I know it will perform better on the street without it. Gas milage will be better without it. But I like it. I think I decided on
440 .060 over
stock rods ARP bolts
Speed Pro Dome pistons for about a 10.3 comp
Comp Cams XE285HL cam
440 source stealth heads OOTB
2x600 Holley Weiand Tunnel Ram
Dana with the 4.10s 29 inch tire
727 with a 3200 stall.
Now I just need ignition what do you guys recommend?
Not necessarily, i got better gas mileage & low speed responce from my TR, started better after sitting a week or so, better idle too, so i would keep the TR.
75 Duster, 451 10.87 @ 123.58 NA 97 Z28 6sp., 12.01 @ 115 on a 100 shot 71 Swinger. 360 magnum. 12.58 @ 105 78 cutlass, 469 BBC. 12.70 @ 108 on street tires. http://www.youtube.com/watch?v=Z2kqNmMfheU
Re: 500+ HP from 440 How would you build it? [Re: joedust451] #474134
09/21/09 05:45 PM
09/21/09 05:45 PM
Iowa
E
E
Iowa
440 .060 over
SO a guy that has experience with running one on the street. How do you think that build will work with the T-Ram?
Re: 500+ HP from 440 How would you build it? [Re: eaglesguy1981j] #474135
09/21/09 08:04 PM
09/21/09 08:04 PM
Branson, Mo.
joedust451 Offline
super gas
joedust451  Offline
super gas
Branson, Mo.
