Re: TNT trouble (sorry long) [Re: DerickS] #473907
09/24/09 08:32 AM
09/24/09 08:32 AM
Clinton Twp, Michigan
DerickS Offline OP
DerickS  Offline OP
I tried some 110 with no effect and I pulled the MSD chip with no effect then I decided to check the 6 month old Cap and rotor that I figured wasnt an issue. The small ball that rides the rotor tang was burned flat and there was a large burn spot on the tang. I only had another used cap and rotor to try but it made an instant difference. I'll get a new cap and rotor this week and see if thats it. What would make an MSD cap/rotor go bad that fast??
Re: TNT trouble (sorry long) [Re: DerickS] #473908
09/24/09 08:47 AM
09/24/09 08:47 AM
MR_P_BODY Offline
MR_P_BODY  Offline
It could have been a slight gap between the ball
and rotor to cause a arc.... or alot of tension
on the rotor and ball or if it had moisture on it.
Glad you found your problem.... how long has it been
in there
Re: TNT trouble (sorry long) [Re: MR_P_BODY] #473909
09/24/09 09:03 AM
09/24/09 09:03 AM
DerickS Offline OP
DerickS  Offline OP
in there
Moisture my be the culprit with the open hood, it is not sealed to the carb...the cap was only on six months old but I drove the car in damp cold weather early in the year.
Re: TNT trouble (sorry long) [Re: DerickS] #473910
09/24/09 11:21 AM
09/24/09 11:21 AM
land of 10,000______'s
BDS871Cuda Offline
BDS871Cuda  Offline
Hey Derick,
What does it run in the 1/4?
New cap and rotor will be a
cheap fix. Good luck and lot
of fun with it!
Snap your neck, mega G-force launch, is all I want!
Re: TNT trouble (sorry long) [Re: BDS871Cuda] #473911
09/24/09 11:48 AM
09/24/09 11:48 AM
DerickS Offline OP
DerickS  Offline OP
Hey Derick,
of fun with it!
Its nothing exciting actually rather slow! With it missing I couldnt make a full pass and it ran 12.00's at 109mph and change. So I think if I get it straightened out high 11's maybe.
Re: TNT trouble (sorry long) [Re: DerickS] #473912
09/24/09 04:20 PM
09/24/09 04:20 PM
Dallas, TX
440Brian Offline
440Brian  Offline
Dallas, TX
I see it's a MSD cap and rotor, but what brand distributor is it? I might check the play of top end of the distributor shaft.
Re: TNT trouble (sorry long) [Re: 440Brian] #473913
09/24/09 04:33 PM
09/24/09 04:33 PM
DerickS Offline OP
DerickS  Offline OP
Its the MSD distributor too...how much play shpuld I have with it?
Re: TNT trouble (sorry long) [Re: DerickS] #473914
09/24/09 08:37 PM
09/24/09 08:37 PM
Ohio
Lil Wedge Offline
Lil Wedge  Offline
Ohio
You have a beautiful car!!!! My small block does that to the cap and rotor also. Something I ran into with the MSD 6al and MSD distributor, is I had random misses up high over 5500 . MSD tech told me to get shielded cable between box and Dist. $18.00 at Jegs, fixed it.
Re: TNT trouble (sorry long) [Re: Lil Wedge] #473915
09/25/09 12:02 AM
09/25/09 12:02 AM
DerickS Offline OP
DerickS  Offline OP
Thank you I appreciate the compliment A shielded cable huh...never heard of it but i will look into it tomorrow thanks!
