Re: TNT trouble (sorry long)
[Re: DerickS]
#473908
09/24/09 08:47 AM
09/24/09 08:47 AM
Posts: 52,972 Romeo MI
MR_P_BODY
I tried some 110 with no effect and I pulled the MSD chip with no effect then I decided to check the 6 month old Cap and rotor that I figured wasnt an issue. The small ball that rides the rotor tang was burned flat and there was a large burn spot on the tang. I only had another used cap and rotor to try but it made an instant difference. I'll get a new cap and rotor this week and see if thats it. What would make an MSD cap/rotor go bad that fast??
It could have been a slight gap between the ball and rotor to cause a arc.... or alot of tension on the rotor and ball or if it had moisture on it. Glad you found your problem.... how long has it been in there ![](/ubbthreads/images/graemlins/wave.gif)
[Re: MR_P_BODY]
#473909
09/24/09 09:03 AM
09/24/09 09:03 AM
Posts: 1,562 Clinton Twp, Michigan
DerickS
Moisture my be the culprit with the open hood, it is not sealed to the carb...the cap was only on six months old but I drove the car in damp cold weather early in the year.
[Re: DerickS]
#473910
09/24/09 11:21 AM
09/24/09 11:21 AM
Posts: 1,949 land of 10,000______'s
BDS871Cuda
Hey Derick, What does it run in the 1/4?
New cap and rotor will be a cheap fix. Good luck and lot of fun with it!
Snap your neck, mega G-force launch, is all I want!
[Re: BDS871Cuda]
#473911
09/24/09 11:48 AM
09/24/09 11:48 AM
DerickS
Its nothing exciting actually rather slow! With it missing I couldnt make a full pass and it ran 12.00's at 109mph and change. So I think if I get it straightened out high 11's maybe.
[Re: 440Brian]
#473913
09/24/09 04:33 PM
09/24/09 04:33 PM
DerickS
I see it's a MSD cap and rotor, but what brand distributor is it? I might check the play of top end of the distributor shaft.
Its the MSD distributor too...how much play shpuld I have with it?
[Re: Lil Wedge]
#473915
09/25/09 12:02 AM
09/25/09 12:02 AM
DerickS
You have a beautiful car!!!! My small block does that to the cap and rotor also. Something I ran into with the MSD 6al and MSD distributor, is I had random misses up high over 5500 . MSD tech told me to get shielded cable between box and Dist. $18.00 at Jegs, fixed it.
Thank you I appreciate the compliment A shielded cable huh...never heard of it but i will look into it tomorrow thanks!
