Re: Detroit Locker [Re: autoxcuda] #472902
09/21/09 01:27 AM
09/21/09 01:27 AM
70duster340 Offline OP
Thanks autoxcuda! I have been trying to locate some resemblance of a part number on the unit itself, but nothing so far. I have found both cast and stamped numbers, all of which have been 5 digit numbers. Not too many places on this thing that a number could be hidden! At least I can rest assured that I purchased a Detroit Locker, now on to find out if it's in operable shape!
I'm with you on the spool thing. Going in a straight line would be better done with a spool, I would think! I am a drag racing fan, but never been up close with a top fuel or funny car to observe the drivetrain. Kinda wish I could, though.
Re: Detroit Locker [Re: 70duster340] #472903
09/21/09 02:05 AM
09/21/09 02:05 AM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
I know your Detroit Locker is an early one because it has the '68 and earlier style carrier bearings.
All the modern 8 3/4" lockers use the '69 and newer bearings.
Re: Detroit Locker [Re: DoctorDiff] #472904
09/21/09 11:00 AM
09/21/09 11:00 AM
Well, sir, I appreciate your input very much. Can you advise what the difference is between the earlier carrier bearings and the newer ones? Can the newer ones be used on the older lockers?
Re: Detroit Locker [Re: 70duster340] #472905
09/21/09 01:23 PM
09/21/09 01:23 PM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
You must use the same part number that came off the unit. The carrier bearings are specific to the Locker, not to the third-member casting.
Re: Detroit Locker [Re: DoctorDiff] #472906
09/21/09 01:46 PM
09/21/09 01:46 PM
But this locker will work in my 489 case, correct?
Re: Detroit Locker [Re: 70duster340] #472907
09/21/09 02:50 PM
09/21/09 02:50 PM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
Yes, the carrier bearings are specific to the Locker, not to the third-member casting.
Re: Detroit Locker [Re: DoctorDiff] #472908
09/21/09 06:53 PM
09/21/09 06:53 PM
OK, thanks. But, since the bearings are obviously still on the unit (I don't currently own a puller), can you possibly advise what part number and make of bearing that you would recommend?
I appreciate it!!!
Re: Detroit Locker [Re: 70duster340] #472909
09/21/09 09:44 PM
09/21/09 09:44 PM
BTT!!!
Re: Detroit Locker [Re: 70duster340] #472910
09/21/09 09:46 PM
09/21/09 09:46 PM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
Pre '69 differential bearings/races: 25590/25520
I have them in stock.
Please E-mail me for more information.
Re: Detroit Locker [Re: DoctorDiff] #472911
09/21/09 09:50 PM
09/21/09 09:50 PM
Thank you, sir!!!
Re: Detroit Locker [Re: 70duster340] #472912
09/22/09 03:07 PM
09/22/09 03:07 PM
Doctordiff, I sent you an email. Not sure if you received it, since I have been having some issues with my email account.
Re: Detroit Locker [Re: 70duster340] #472913
09/22/09 04:04 PM
09/22/09 04:04 PM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
Unfortunately, I did not receive it.
Re: Detroit Locker [Re: DoctorDiff] #472914
09/22/09 10:05 PM
09/22/09 10:05 PM
Hmmm, ok, let me try it again!
Re: Detroit Locker [Re: 70duster340] #472915
09/22/09 10:11 PM
09/22/09 10:11 PM
OK, I sent it again. I hope I have the correct email address. I used the one supplied in your contact info.
Re: Detroit Locker [Re: 70duster340] #472916
09/23/09 12:05 AM
09/23/09 12:05 AM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
I still haven't received the E-mail.
You can also send me a PM me on this board.
Re: Detroit Locker [Re: DoctorDiff] #472917
09/23/09 10:18 AM
09/23/09 10:18 AM
Well sir, I just did that. Sorry, I have no idea why the emails aren't getting through.
