Re: Off to the track
[Re: slantzilla]
#472517
09/19/09 02:53 PM
09/19/09 02:53 PM
Quicktree
Give 'em hell Tony!
thanks and we are out of here
[Re: Quicktree]
#472518
09/19/09 03:08 PM
09/19/09 03:08 PM
this should be interesting! good luck and be safe Tony!
why do you think this is my first rodeo? thanks
Tony, i know you've been down alot in the past, just having some fun!! good luck dont bust up any ring and pinions
[Re: MegaDart]
#472521
09/19/09 11:33 PM
09/19/09 11:33 PM
Quicktree
well we just got back, the car did go down the track but we did have a few problems only made 2 passes. 1st pass had a hesitation but would not shif out of first so I aborted and just crusied through at 4k rpm. it felt strong after it picked back up after the hesitation but that didn't last long. checked the wiring to the Eshift and didn't see anything wrong. so I put it in manual mode so I could shift it manually. changed the squirters to see if I could get the hesitation out. 2nd pass it still had a hesitaton but pulled good in 2nd gear. shifted into 3rd and nothing so I just coasted through and loaded it up. car drove good with no wondering and went straight. I guess that was good so I'll search and see what the problem is. Woody seems to think it's in the valve body. had fun seen goldmember and a few old friends. all is good Ill figure it out later...
[Re: Quicktree]
#472523
09/19/09 11:53 PM
09/19/09 11:53 PM
Posts: 877 ky
68roadrunner
ky
I forgot the 2 hour delay some chevy driver gave for spitting parts all over the track
at least you didnt come home with your parts in a 5 gallon bucket.
[Re: Quicktree]
#472524
09/19/09 11:57 PM
09/19/09 11:57 PM
Posts: 9,366 Lehigh Acres, Florida
rickstershemi
OH My God....Hell Just Froze Over Congrats on getting down the track...you'll get it sorted out
Rickster
[Re: DaKuda]
#472526
09/20/09 12:44 AM
09/20/09 12:44 AM
Quicktree
Jet extensions....
it has them, but its hard for that to be a factor when the car hasn't moved happens right on the tip in.
[Re: Dodgem]
#472528
09/20/09 01:11 AM
09/20/09 01:11 AM
Quicktree
[Re: Quicktree]
#472529
09/20/09 03:03 AM
09/20/09 03:03 AM
Posts: 4,055 Salina ks
572_dup2
Back On The Bumper!!
Salina ks
Im glad you got to take your hot rod down the track.
Shawn Jennings
[Re: dc426]
#472533
09/20/09 07:51 AM
09/20/09 07:51 AM
Quicktree
Why did you go with the E shift V body
because it's a bracket racer. supposed to be one less thing to worry about I'll get it straight. a lot of the class racers are using them and loving it. the car really felt good and pulled hard once it got past the hesitation.
[Re: 572_dup2]
#472534
09/20/09 07:53 AM
09/20/09 07:53 AM
Quicktree
yea that was cool, lots of people came by to look at it.
[Re: 493_DART]
#472535
09/20/09 07:56 AM
09/20/09 07:56 AM
Quicktree
Might be to much lash in your ring/ pinion in the rear........
could be, I didn't set it up. this car (body and chassis)was built over 25 years ago. the rear set all that time with no grease in it. the ring and pinion looked fine but there was rust on the bearings.
