Re: Headin to the strip, 1st time down, what will it ru
[Re: Moparnut426]
#471950
09/19/09 10:46 AM
09/19/09 10:46 AM
Posts: 3,443 Northern N.J.
hemi_doug
Northern N.J.
Caltracs..... There's your answer to your traction problem...and good tires.
71 440-6 4spd & 69 Hemi 4spd
[Re: hemi_doug]
#471951
09/19/09 11:00 AM
09/19/09 11:00 AM
Posts: 12,016 Finally a HUSKER again
Moparnut426
This is a street car 90% of the time. Im just a gluton for HP, and sweet exhaust note.
Kasey
[Re: dustergirl340]
#471953
09/19/09 11:14 AM
09/19/09 11:14 AM
Moparnut426
HUH,,,
Im happy with the shocks so far, I have been beatin the crap out of the car all summer long, and they are ok, Im sure If I go to the track more often they might be bad, Dont know, but Ill cross that one when I need to.
thanks though..
Kasey
[Re: hemi_doug]
#471954
09/19/09 11:17 AM
09/19/09 11:17 AM
Posts: 11,732 Portage,michigan
B3422W5
Portage,michigan
I dont know about cal tracks, in his application.My s/s spring very small tire car goes high nines and sticks anywhere with unmodified leafs. I see way more posts on here from people trying to get caltracks to work than i do s/s springs by a long shot.
He has a TON of stuff to sort out before he should ever thrown in the towel on a hopefully 12 second primarily street car
[Re: B3422W5]
#471955
09/19/09 11:34 AM
09/19/09 11:34 AM
Moparnut426
This was a test ant tune, Im happy with the results for now, I only had limited time to run, and this was the maiden trip...
When I get more pony under the hood, then Ill really get to the down and dirty, and probbly get a dedicated wheel and tire combo for taking to the strip.
I know the tire spinn really killed me, but it was TEST AND TUNE..
KAsey
[Re: Moparnut426]
#471956
09/19/09 12:35 PM
09/19/09 12:35 PM
Posts: 4,324 Prospect, PA
BSB67
Prospect, PA
Pluss I technicaly have the 360 in the car sold so I didnt want to hurt anything.
Do I understand this correctly? You took it to the track, after you sold the engine? - That's funny.
