Painting the Roadrunner Today
#471620
09/18/09 09:07 AM
09/18/09 09:07 AM
fullfloater
Its 6.30 Am car is ready ,getting ready to seal car
Re: Painting the Roadrunner Today
[Re: fullfloater]
#471621
09/18/09 09:10 AM
09/18/09 09:10 AM
340dart4spd
Parts Problem
Parts Problem
It's now 10:15 here now...what stage is it in now?
[Re: fullfloater]
#471624
09/18/09 10:23 AM
09/18/09 10:23 AM
fullfloater
10:30 Am First coat of base is on ,waiting on it to flash ,then will have to put stripes on ,then will clear whole car ,its goning to be a long day ,everything is drying slow from humidity
[Re: dodgem1]
#471626
09/18/09 11:03 AM
09/18/09 11:03 AM
fullfloater
Yea i was kinda thinking i ought to pull them out but didn,t ,car has new interior in it ,didn,t want to mess with pulling door panels ,this car i put togther before i painted ,motor is in etc ,i have painted cars before and then assembled ,just seems like something always gets dinged up and i have to repaint it ,car is Dark Green ,it looks black in picture ,final coat of base is on ,waiting for it so dry so i can put stripes on ,paint is BC CC Sickens Autobase plus
[Re: fullfloater]
#471631
09/18/09 10:29 PM
09/18/09 10:29 PM
moparpollack
Lil Herman
Lil Herman
85086
What are you doing next weekend? Need some more practice? I got a 70 dart that needs the It should be ready if the weather cooperates tomorrow.
[Re: fullfloater]
#471634
09/19/09 09:16 AM
09/19/09 09:16 AM
fullfloater
[Re: moparmojo]
#471638
09/20/09 07:13 PM
09/20/09 07:13 PM
fullfloater
I just finished wet sanding and buffing car ,i already had this done before i saw your post ,What i,m talking about is dirt ,trash etc in clear coat ,What i did on this car was take a paint stick ,cut it off about 4-5 inches long ,Put 2000 Grit wet sand paper,Lightly sand out spots ,Then used a Heavy duty rubbing compound with a buffer ,buffer spots and whole car ,then polish with a polisher pad and polishing compound ,i try to sand and buff when its pretty green ,it sanded buffed real easy ,The longer you let the clear set ,the more Harder it will get ,The car is still taped and papered off ,so you don,t have to deal with too much compound being slung in every crack and creves in car ,Take Quick detail and detail rag and clean car up ,I woulkd recommended you find a body shop and work part time ,it takes lots of experience and time and definatly patience ,Thats what i did years ago ,i do all my own work ,heres some pictures of car outside with some 20,s on it ,I need some ideas for wheels
[Re: fullfloater]
#471639
09/20/09 07:18 PM
09/20/09 07:18 PM
340dart4spd
Parts Problem
Parts Problem
Just curious why did you put those on the car......
