Re: Painting the Roadrunner Today
[Re: fullfloater]
#471642
09/20/09 08:27 PM
09/20/09 08:27 PM
fullfloater
another
[Re: sthemi]
#471644
09/22/09 09:01 PM
09/22/09 09:01 PM
fullfloater
Thanks ,I waited about 30 hours ,I don,t have a paint booth ,i just painted in my shop ,it sanded real easy and buffed easy ,i had a couple of runs ,they sanded out real easy ,it just depends a lot if it air dries or is baked ,i have sanded and buffed in 3 or 4 hours after baking at 160 degress for 20 minutes in a down draft Blowtherm ,i went to Sikens Paint school in Dallas about 5 years ago ,they had a new clear that you could sand and buff in 5 minutes ,You had to bake it or put a heat lamp on it for 5 minutes ,It was real toxic so we stayed away from it ,It wouldn,t activate unless heated ,it would stay wet ,It sprayed real weird ,You put a light cut ,not wet and then hammered a real heavy 2nd coat ,and that was it ,You had to have Fresh Air when you mixed and sprayed ,No exceptions
[Re: sthemi]
#471645
09/22/09 09:02 PM
09/22/09 09:02 PM
moparpollack
Lil Herman
Lil Herman
85086
If it was Sikkens it would be about a day before it turned hard as a rock.
[Re: moparpollack]
#471646
09/24/09 12:27 AM
09/24/09 12:27 AM
Posts: 3,319 Chicago Burbs
sthemi
Chicago Burbs
I painted my brothers 55 Chevy in House of Color candy red and pearl with base, tint coat and clear. He was all done with car stuff for a while and let it sit for a month before trying to sand and buff. That stuff was like concrete, or harder..Luckiy the paint had a nice gloss so it only got a light sand and buff.. Hopefully my 68 roadrunner will get some paint soon !!
[Re: basketcase]
#471648
10/14/09 06:08 PM
10/14/09 06:08 PM
fullfloater
Thanks ,I don,t have anyway to control the temp in my shop, so i have to work around the weather ,the plan was too have the car running and driving before i painted it ,but it was getting late in the year so went head and shot it ,I like to paint early in the morning ,its usually calm and no flys or bugs are flying around ,The night before i set of 2 or 3 bug bombs in the shop and seal it up ,next morning i wipe car down with a pre paint prep Sickens M600 ,I thinking of putting steelies on it ,should i go 14,s or 15,s ,any ideas what looks the best ,will use a dog dish hubcap ,have a 4 door 69 valiat with mint wheels and dog dish hubcaps ,but are afraid the wheels are too narrow ,i have taken wheels of mid 80,s New Yorkers and they are 15x7 ,but not sure if my dog dish caps will work ,unfortunately i don,t have any of these wheels around any more too check Need some ideas ,Car is getting closer ,pulled rearend out and redone it ,bearing ,brakes 323 posi etc ,it looks nice ,hope too be finished by Thanksgiving ,will post pictures soon ,thanks Guys
[Re: fullfloater]
#471649
10/14/09 08:38 PM
10/14/09 08:38 PM
Posts: 2,467 Sydney,Australia
tex013
Sydney,Australia
what is the sikkens paint code you have used ? my 68 is a similar green and am trying to get the proper code,i am in Australia. thanks, Tex
New best ET 10.259@129.65 . New best MPH 130.32 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
[Re: fullfloater]
#471650
10/15/09 05:04 PM
10/15/09 05:04 PM
Posts: 6,716 KY
65pacecar
KY
The Valiant wheels should be small bolt pattern, they wont work anyway. I would stick with 15s, they look good on B-Body cars, Dog Dish would look nice on the car or a set of Crager S/S (old style Crager Mags) would make the green really pop.
[Re: 65pacecar]
#471651
10/15/09 06:09 PM
10/15/09 06:09 PM
fullfloater
The code for this particular green is CG ,its a 2009 GM color ,I wanted something darker than F8 ,As for the wheels ,your right ,i forgot all about them being small bolt pattern ,sniffed too much paint ,does the dog dish fit only 14,s if they came on 14,s or will they work on 15,s ,thanks
[Re: fullfloater]
#471652
10/16/09 01:03 AM
10/16/09 01:03 AM
Posts: 982 W. Sacto CA. USA
phantomx
W. Sacto CA. USA
The dog dish caps fit fine on the 80s 15x7 Diplomat/New Yorker wheels. Travis..
70 GTX project, orig 440-4, 4 spd, track pack, FC7, stripper/street racer special.
[Re: phantomx]
#471653
01/17/10 05:19 PM
01/17/10 05:19 PM
fullfloater
Its january 17 still working on Roadrunner ,getting close been working bugs out ,been driving car ,took it too town today ,washed it ,had 2 guys drooling over it before i got out of there ,sure like the way it drives ,need to do something with radio ,its just got a AM radio ,doesn,t seem too work ,need to do something here ,need tunes ,don,t want to spend a fortune on a original am fm ,any ideas ,i am about broke ,you guys that didn,t like those 20,s will this work ,i like it ,at this point would put a aftermareket radio in it ,but don,t want to cut dash ,not sure of my options ,Here are some pictures ,its kinda overcast today ,so picture quality is poor
[Re: fullfloater]
#471654
01/17/10 05:20 PM
01/17/10 05:20 PM
fullfloater
[Re: fullfloater]
#471655
01/17/10 05:21 PM
01/17/10 05:21 PM
fullfloater
[Re: fullfloater]
#471656
01/17/10 05:34 PM
01/17/10 05:34 PM
Posts: 3,106 Ridgeland Wi
mopars_1
Ridgeland Wi
muuuuch better without the 20's!! car looks georgous. you could mount an am fm under the dash or in the glove box. there are also companys that will convert your am radio to have am fm, but ive never priced that option.
1971 Plymouth Duster 340 auto 1937 Plymouth PT50 1969 Dodge Dart Swinger 340 4 speed 2013 Ram laramie 2500 hemi 2008 Harley FLSTSB springer
