Page 2 of 3 1 2 3
Re: My 440 is a slug, please help. [Re: @#$%&*!] #471579
09/18/09 04:37 PM
09/18/09 04:37 PM
dark side of the moon
Dougsmopars Offline
Dougsmopars  Offline
I'm running an 800 Thunder. 500 + lift cam advertised duration is 285 or there abouts. Yes big lumpy cam. Don't have exact spec's as i didn't put it in. I'm changing to Lunarti Voodoo 603 cam. Back to the carb. I bought this car with an 780 DP, torker intake, unilite dist. Ran good but no power house. As i'm not a fan of Holley carbs that went first. Had a stumble at tip in. Changed the springs and fattened up with rod change. Better but still a little weak down low. Removed the torker went to a Performer intake. Big difference. Went with an MP electronic. Still had a small stumble. Went to 43 squirters. Much better but still there. Got to the timing. started at 15 initial. Ended up with 22 initial. Recurved the dist for total of 38 all in by 2500. Stumble is gone Car is now a great tire frier. Still over camed for a street car but 100 times more fun to drive then when i bought it.
Re: My 440 is a slug, please help. [Re: Gator73] #471580
09/18/09 04:43 PM
09/18/09 04:43 PM
Branson, Mo.
joedust451 Offline
super gas
joedust451  Offline
super gas
Branson, Mo.
This is a higher mileage engine and the compression was checked before going into this. The cylinder pressure varied amongst the cylinders and ranged from a high of 145 to a low of 130. I thought I posted about these numbers and whether they would be ok, but I can't seem to find the post. Anyway, from what I gathered on other similar posts, my compression while not great was not all that bad. I believed the engine to be in good enough condition that it could take a mild cam along with the new timing chain, intake, and carb. All advice on timing including vacuum readings will be considered and we'll see how much additional it can take. I believe the pump shot is still in the stock position and we can play with that some too after the timing is figured out. It doesn't have any off idle stumble under moderate throttle or anything like that, just bogs when you try to open it up. This car runs great and could be driven all day long but just simply has no guts.
Those #s are a bit low, not horrible, but on the lower end, most stock 440s will be around 150-155, don't know what to tell ya other then you may want to check it agian, they may be alot lower, but like said, it might be carb/timing related.
75 Duster, 451 10.87 @ 123.58 NA 97 Z28 6sp., 12.01 @ 115 on a 100 shot 71 Swinger. 360 magnum. 12.58 @ 105 78 cutlass, 469 BBC. 12.70 @ 108 on street tires. http://www.youtube.com/watch?v=Z2kqNmMfheU
Re: My 440 is a slug, please help. [Re: Gator73] #471581
09/18/09 04:46 PM
09/18/09 04:46 PM
IL
furious70 Offline
furious70  Offline
IL
Yeah, I wouldn't think the SD would be causing the problem given the rave reviews it gets. Maybe it just works better on hotter engines rather than my relatively stock combo. Anybody ever use a SD on a stockish engine and have low end issues? I agree that changing carbs to a known good one regardless of the brand could elimiate a lot of guess work. I'll have to beat the bushes to see if I can scare a good candidate up.
Not a 440, but a 383.
~8:1, 268H cam, basically a stock rebuild smog engine with headers and a holley 750dp
4000lbs Fury, 275/60/15's
SD intake and 3.91's from an idle would barely chirp the tires
stock iron 4bbl intake and 3.23's from an idle I'd get a little spin
To be fair, I did not try to optimize timing for each intake, but for the gear change in the opposite direction I thought it a pretty substantial loss in tq with the holley intake. The big 383 intake comparo HotRod did confirms this. How that translates to a 440 is a bit up in the air however.
70 Sport Fury
68 Charger
69 Coronet
72 RR
Re: My 440 is a slug, please help. [Re: furious70] #471582
09/18/09 05:18 PM
09/18/09 05:18 PM
Gator73 Offline OP
Gator73  Offline OP
Dougsmopars, did you switch to a Performer or a Performer RPM on your combo?
Re: My 440 is a slug, please help. [Re: furious70] #471583
09/18/09 05:19 PM
09/18/09 05:19 PM
Lapeer, MI.
todd440 Offline
todd440  Offline
Lapeer, MI.
Did you degree the cam in when installing it??? If you just "lined up the dots", that could be your problem.
Re: My 440 is a slug, please help. [Re: Gator73] #471584
09/18/09 06:00 PM
09/18/09 06:00 PM
Dougsmopars Offline
Dougsmopars  Offline
performer. The rpm is a taller intake. Carb closer to motor is better for lower rpm power.
Re: My 440 is a slug, please help. [Re: Gator73] #471585
09/19/09 10:53 AM
09/19/09 10:53 AM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
John, the distributor is a stock Mopar replacement unit from a parts store that was bought years ago (not a Mopar Performance unit). It was recurved some time ago and has one heavy spring and one light spring. It seems to be working find. I have thought about replacing it with a known good MP unit to see if that would help.
was it recurved by just changing springs ? if so you probably have too much total timing since std mopar distributors have 30 plus degrees of mechanical advance , changing the springs does nothing to change that . But that's not your problem here .
Re: My 440 is a slug, please help. [Re: JohnRR] #471586
09/19/09 12:01 PM
09/19/09 12:01 PM
Gator73 Offline OP
Gator73  Offline OP
John, don't know what other modifications the guy did other than putting in the springs and I never inquired as to how much timing it had. The car ran great after the initial engine swap and had plenty of power (about 15 years ago).
There is an update to this story. From what I can remember, my friend told me he unhooked the vacuum advance and gave it more timing. It took it all the way up to about 21 initial and 38 total. Made a big difference in power as it will spin the tires. The Street Dominator is coming off and will be replaced by the Weiand Action Plus. I am running a stock air cleaner and it nearly hits the hood with the SD. Can't run a spacer with the SD which we need due to heat soak. I expect the change in intake will make a big difference in the low end and we'll adjust the timing again after the switch. The SD just doesn't appear to be a good match for this combo. I'll give an update with specifics after this is completed. Thanks to all who have posted with advice thus far.
Re: My 440 is a slug, please help. [Re: JohnRR] #471587
09/19/09 01:57 PM
09/19/09 01:57 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
That cam isn't very big , looks like a modern version of the stock 440 magnum cam .
John - That cam in a small block is a great runner. Lots of low end torque and retains a good amount of vacuun. IMO it should run good in a 440 as well.
Re: My 440 is a slug, please help. [Re: MoparforLife] #471588
09/19/09 02:44 PM
09/19/09 02:44 PM
JohnRR Offline
JohnRR  Offline
Don , I never said anything about how it would run , my comment was just saying that is not as big a cam as some seem to think .
Re: My 440 is a slug, please help. [Re: Gator73] #471589
09/19/09 05:21 PM
09/19/09 05:21 PM
Sk. Canada
RemCharger Offline
RemCharger  Offline
Sk. Canada
I would time it first, before the swap... With that cam it should like that intake IMO. I've run similar combos, and thats what i've found.
Re: My 440 is a slug, please help. [Re: JohnRR] #471590
09/19/09 08:23 PM
09/19/09 08:23 PM
Upper Midwest
Upper Midwest
Right it is not a real big cam but it seemed to have a lot of low and midrange when I had it in the Duster and it works great on the street in the Coronet 360. The engine has stock dished pistons too. Like you said it is not huge but a good torky cam.
Re: My 440 is a slug, please help. [Re: MoparforLife] #471591
09/19/09 08:33 PM
09/19/09 08:33 PM
San Jose, California
DennisH Offline
Vacation
DennisH  Offline
Vacation
69 440. 850 Demon. RPM Performer. MDS. Comp. TTI. 354 Dana. Rip tear smoke here.
Re: My 440 is a slug, please help. [Re: Gator73] #471592
09/20/09 01:34 AM
09/20/09 01:34 AM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
Holley SD is not a good choice for that combo. Holley SD likes more timing than a dual plane even on a combo it's suited for, which is one with torq to spare.
I do understand that all carbs may need tuning to get optimal performance but I would think the Thunder Series AVS would run pretty good right out of the box.
You can never assume that. I have a wideband o2 on my car, and trust me, baselined or out of the box tuning can be miles off. For example baselined to stock specifications I was getting a 17:1 a/f at a hot idle as well as cruise and a bad bog at WOT with my thermoquad. Not the same as an eddy thunder but mine's a 440 pre-smog era thermoquad an on the new combo it was crazy far off from ideal.
I've got a low-cr smog 440 stock bottom end w/ new piston rings, lunati voodoo 60303(226/234@050, 494/512 lift, 110lsa) cam, 440source heads, headers and a stock spreadbore intake w/ thermoquad. I was going to do a full rebuild but didn't have the money and decided to throw something together to have fun with instead of sitting on these parts until the end of time. It fries tires great off the line, the back end goes all over the place. Great street manners and I still drive the car to work and will do so until the snow flies.
FWIW my cylinder compression ##'s were a bit better than yours, even with the bigger cam.
Re: My 440 is a slug, please help. [Re: DaytonaTurbo] #471593
09/20/09 09:36 AM
09/20/09 09:36 AM
Gator73 Offline OP
Gator73  Offline OP
I guess I read too much into the SD and assumed it would be a good choice for any application given how many recommendations it receives and how well it does in tests. The Weiand Action Plus is going on and I am sure we will see a big difference. I'll share the results as soon as it is done.
Re: My 440 is a slug, please help. [Re: DaytonaTurbo] #471594
09/20/09 09:46 AM
09/20/09 09:46 AM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
Never got an answer to whether the cam was degree'd in properly or just installed dot to dot. As someone else posted if the cam is installed late it will be short of bottom end. If the engine pulls good on the top side I would look at that.
Kevin
Re: My 440 is a slug, please help. [Re: Twostick] #471595
09/20/09 12:11 PM
09/20/09 12:11 PM
Gator73 Offline OP
Gator73  Offline OP
I believe the cam was installed straight up, dot to dot. I sure hope that this is not the problem. I am pretty confident that changing the intake and adding timing will give the performance that I am looking for.
Re: My 440 is a slug, please help. [Re: Gator73] #471596
09/20/09 12:36 PM
09/20/09 12:36 PM
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
Installing a cam dot to dot is a crapshoot at best. I've been to Vegas enough to know I lose more than I win.
If I was you I would put the stock intake and carb back on it and if it won't run at least as well as it did before you changed the cam, it's time to buy a degree wheel and find out where the cam REALLY is installed at.
Kevin
Re: My 440 is a slug, please help. [Re: Twostick] #471597
09/20/09 01:24 PM
09/20/09 01:24 PM
Lapeer, MI.
todd440 Offline
todd440  Offline
Lapeer, MI.
That's why I asked the question about the cam. I degree every one I do. I've had them at 116 degrees in the straight up position, and it's supposed to be installed at 108. If I wouldn't have checked it.....it would have been a turd down low, or worse. Lots of variables with timing chains and cams.
Re: My 440 is a slug, please help. [Re: todd440] #471598
09/20/09 05:54 PM
09/20/09 05:54 PM
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
Kevin
Page 2 of 3 1 2 3
