Re: Alterkation, XV Level II and MagnumForce front end
[Re: quick77rt ]
#47161
11/11/07 10:49 AM
11/11/07 10:49 AM
Posts: 4,395 The Pale Blue Dot
Skeptic
The Pale Blue Dot
Are you refering to the crappy fatman FMJ spindles? HUH !!!!
If you have good experience with them, well you would be the first person I've heard of that did. They look good for a lightweight skinney tired street rod. I wouldn't trust them on my fat tired street car with speed bumps, potholes and the occasional canyon run I don't have an issue with the taller FMJ spindles, I've seen enough testing and frankly here to come to my own conclusion about that.
[Re: autoxcuda]
#47162
11/11/07 12:23 PM
11/11/07 12:23 PM
Posts: 5,394 Pikes Peak Country
TC@HP2
Pikes Peak Country
It would even work on FMJ cars, but it would be slightly shorter.
Well given the choice, I'd actually prefer the taller spindles over the shorter ones for the roll center placement, camber change curve, and lighter weight. But honestly, I'd use A body size too.
Fatman drop spindles are probably fine for the pro-parking crowd or the cruise it to the show and shine bunch. I personally am not too interested in trying them under any of my vehicles which will see some high level lateral stress. Not only that, their prices have jumped from $300 to $500 in the last two years with no change in the quality of the product.
I can think of two dozen people I personally know who would buy them right now. Odds are they could probably sell them as fast as they could forge them for the next couple of years.
[Re: BergmanAutoCraft]
#47163
11/11/07 05:11 PM
11/11/07 05:11 PM
Posts: 157 Santa Rosa CA
Bones
Santa Rosa CA
They are 500, and have been out for years...
Yes, we've all known about those for years, the problem is that they are a total rip off. For the most part, spindles are spindles. They are dimensionally different yes, but there is no reason that the spindles that Fatman sells should cost so much more than all the other spindles out there. Be they Mopar, MII, Chevey or whatever. The regular (non-drop) spindles that Magnum Force sells are a little over $300, good quality, and are manufactured right here in the good old USA. There are also plenty of other companies out there selling MII and Chevy drop spindles in the $229 range. If they can all make a nice profit at that price there's no reason someone couldn't do the same thing with with the 73' and up Chrysler units.
If someone had the money to invest, they could get these things made, sell them for a fair price, make a nice profit, and be a hero to the Mopar community all at the same time.
[Re: TC@HP2]
#47164
11/12/07 02:39 PM
11/12/07 02:39 PM
Since we have had posting from AlterK, XV, and now Magnumforce here is my challenge to all of you;
The first one to produce a 2" drop, disc brake spindle for $200 a pair, I know of a dozen or two buyers who will pick up a set.
We released the high-strength cast version of the 73-up AB&E Disc spindle about six months ago and 2" drop version is in development as we speak.
#47165
11/12/07 05:05 PM
11/12/07 05:05 PM
TC@HP2
Pikes Peak Country
Hey, hey, hey, you guys are going to be busy!!!
#47166
11/15/07 12:56 AM
11/15/07 12:56 AM
Posts: 116 long island
autodynamics
long island
Re: Alterkation, XV Level II and MagnumForce front end ?'s
[Re: Dos Snails]
#47169
11/18/07 04:52 PM
11/18/07 04:52 PM
Posts: 2,432 NorCal
RylisPro
NorCal
I totaled both RMS and XV Level II setups I wanted for my application: RMS: ARC4000L LevelPro compressor system w/ aluminum tank $2,070.00 ABAR20700 Mopar 68-70 B Body & 70-74 E Body rear AirBar w/ dual adjustable Shockwave $2,265.00 AIRBAR Air Ride Shockwave double adjustable $798.00 16160 Tubular K-Member Conversion B and E-Body Power Steering $3,595.00 16160 complete 1.125" sway bar $249.00 WIL-140-7018 Superlite 6 Piston 13" Big Brake Front Kit $1,250.00 total= $10,227.00 XV Level II: 20-1201 XV E-Body Level II Suspension - Front $7,495.00 20-1221 XV E-Body Level II Suspension - Rear $3,395.00 25-1201 XV E-Body Level II Brakes - Front $2,895.00 total= $13,785.00 when I add up the parts total of the XV Level II it is roughly $3,558.00 more for my application but what is not included is the amount for the extra welding of the XV Level II I would guess it would cost maybe $1000 for the proper welding procedure? if so it would only cost roughly $5000.00 more to have the XV Level II installed for my application bottom line is cost if there is any way to lower that extra $5000 difference to be more cost effective with the RMS setup, then I would choose the XV Level II in a heartbeat
[Re: RylisPro]
#47170
11/18/07 06:27 PM
11/18/07 06:27 PM
Posts: 42,714 Spokane Washington
ScottSmith_Harms
Mr Wizzard
Mr Wizzard
Spokane Washington
I think the bigger question would be;
"What performance or reliability difference would I see for the extra $5,000.00?"
Sure be cool to see two equally preppared cars go head to head on a closed course to see who could run the best times. I think the results would raise a few eyebrows.
[Re: RylisPro]
#47171
11/18/07 07:11 PM
11/18/07 07:11 PM
Posts: 27,471 So Cal
autoxcuda
So Cal
Sort of apples to oranges comparison. One has air bags and one doesn't. Why do you need air bags? They are not going to make you go faster.
Do you need the very last bit of refinement that the XV Level II? A XV level I kit is very capable too and would and has done fine on the track. Rare T/A took his car out to Pocono with some or all of Level I stuff.
An Alterkion with QA1 shocks and good brakes is very capable of track days too. And if you need a steering box rebuild and/or conversion motor mounts the Alterkion comes with new item to cover those needs automatically.
bottom line is cost
...I just went to your website and saw your build sheet for this car. They can't print money fast enough for all that stuff, so what's $5000 to get the very most handling out of it. You're planning on a dry sumped, EFI, aluminum Indy block 572 motor....
Get something wider than 235's for a car that's built to this level of capability. Like 275's. Also think about investing in a six point cage. They really tie everything together beyond frame connectors and even the XV stiffening. Especially on a car with a motor as capable at that.
I'd also suggest going out to a track day in your area that has some older cars and get a feel for things and ideas.
[Re: autoxcuda]
#47172
11/18/07 07:53 PM
11/18/07 07:53 PM
Posts: 2,432 NorCal
RylisPro
NorCal
your right, I don't need airbags to go faster but it is the most expensive option in Alterkations setup which is still less than XV's most expensive setup Why end with XV Level I when I know they have a Level II? I agree about the QA1's which do cost less! I have 30% of whats on the list. there are pics to the links if you click on them for example: http://www.rylispro.com/cuda/engine/440-B4-MWRB.htmI did not know you could fit 275 front tires in ebodys I thought 235 were the biggest? I am planning on a 10 point cage I am not looking down on the RMS Alterkation it is still on my list just saying the price difference is at least $5000 between RMS and XV who dosent want to save that money? thanks
[Re: RylisPro]
#47173
11/18/07 10:06 PM
11/18/07 10:06 PM
autoxcuda
So Cal
What do you want? The cheapest, the best, the best value, the most impressive...
Do you want the cheapest most expensive one?? -Ouch you just exploded my head.
What happens if they come out with a Level III that cost less than Level I and II. Then they come out with Level 0 that cost more than all of the levels combined. -Now I just exploded your head.
Ok, back on track. I think you want to know if your extra money is being well spent?
With the right offset they will. And tubular A-arms would give a little needed clearance too... https://board.moparts.org/ubbthreads/show...rue#Post3946034
Have you considered tubbing the back for more tire room. You're going to have more power than you can put down with that motor combo?
thanks
Well it looks like you are trying to maximize every bit of performance out of this car. Many times the last 5% takes the most money.
You could run a iron block 440 and a good designed wet sump and save a lot of that $5000 too.
[Re: autoxcuda]
#47174
11/18/07 10:37 PM
11/18/07 10:37 PM
Posts: 2,432 NorCal
RylisPro
NorCal
well said!
yes. problem is they dont make 19 lbs BBS RGR's wider than 18 x 10's and 295's fit just fine. besides the skinnier tire will just spin and save my driveline in the long run
i agree in my case the last 70%
whats the fun in that?
look I am not arguing, I am agreeing with you thanks
[Re: RylisPro]
#47175
11/18/07 11:28 PM
11/18/07 11:28 PM
Posts: 1,164 Los Angeles, CA
JF_Moparts
Los Angeles, CA
This is to the folks at RMS and XV:
Have you considered offering aero effects for the older Mopars? Suspension is all about stability and aerodynamics affect stability a heck of a lot.
The 71-up B bodies and all E-bodies were pretty aerodynamic for their day, but the right ground effects would really help stabilize them at high speeds. As far as I know the only option I have as a 71 Satellite/RR owner is the original eyebrow spoilers, which seem to do very little. If a company offered good looking front and rear spoilers for my car, I'd buy them in a heartbeat. The same goes for rear window louvers.
And as a corrollary to the above, if anyone knows of good aero effects for these cars that are already being offered, please let me know.
- Jim
[Re: JF_Moparts]
#47176
11/19/07 12:00 AM
11/19/07 12:00 AM
autoxcuda
So Cal
- Jim
From the 69 Car Life Spoiler Test article on a 69 Camaro, Javalin, and GTO the front end lifting is the biggest problem. All the cars then had a nose up front side profile. That traps air under the front and lifts the front. NOTE: this was real well ran test. Had well thought out cables to measure suspension travel. Pretty involved for it's day.
From the tests the sedan Camaro with it's notchback and flat trunk did well to not lift the rear. That car is like E-bodies and most 63-70 B-bodies. When they added the rear spoiler only the back had good downforce but in turn it pushed the nose up. They concluded the stock 69 Front spoiler only was the best deal.
But that 69 Camaro spoiler is not that big. Not like a 71 Charger or 69-70 Mustang type. I'd shoot for something those two cars had or bigger like the Trans Am cars had.
The Kammback and fastback profiled 69 Javelin and 69 GTO had rear end lift above 60 mph. And also front lift without a spoiler. The rear spoilers on those stunk and didn't do anything. Those two car are like 71-74 Ply B-bodies, 67-69 Barracuda Fastbacks, 66-67 Chargers and Duster/Demons.
I think a ducktail spoiler on those fastback type cars like the one Direct Connection sold once for Duster/Demons would help. Also 67 Charger had problems in Nascar with rear lift and they homogated a rear ducktail that came on the hemi cars.
Key thing about front spoilers is to make them out of ABS. Fiberglass ones crack and will always hit driveways and curbs.
This is the spoiler pictured below is modeled after one Dean Jefferies made and was used on the Ontario Speedway 70 Challenger Pace Car. It's like the race Trans Am ones. I think it's a lot more effective than a stock 69 Camaro front spoiler.
It's also huge PITA. Al's had this on his car for years. And had it repaired many times. And he babies it like none other. Not very fun to live with. Now if it were ABS that would change everything. The guy who did these fiberglass ones in the early 90's? made them for Challengers and 70 Chargers, IIRC.
[Re: autoxcuda]
#47177
11/19/07 01:00 AM
11/19/07 01:00 AM
Posts: 2,046 MD
RTSE4ME
MD
This 69 Camaro has gone 220 mph with just a small front spoiler and a ducktail spoiler for the rear.................. http://www.bigredcamaro.com/newsite/mainpage.html I guess you don't need much to keep the front end down. It would be interesting to see a purpose built XV race car compared to Big Red.
[Re: RTSE4ME]
#47178
11/19/07 01:46 AM
11/19/07 01:46 AM
autoxcuda
So Cal
The Camaro in the Car Life test had a lot more ride height to it also. Big Red is low in the front. And that will make the tip of the spoiler lower. I've seen it in person.
The pictures from the 69 season of the Penske Camaro show a short spoiler. But the car is low in the front and the body is raked. Nascar then raked their bodies on the chassis also for aero. The 69 season Camaro spoiler mounts at lowest point of the valance and has less angle to it. The 69 Camaro ran by Milt Mitner in 1970 (and also won once) was more a shovel type. Don't know what's better or if it matters.
Here's Tim Werner's spoiler. It's a garage door seal. Don't tell anyone.
[Re: RylisPro]
#47180
11/19/07 11:25 AM
11/19/07 11:25 AM
Posts: 2,432 NorCal
RylisPro
NorCal
I called XV about the proper welding procedure it is not any more complicated than welding in their subframe connectors and would not cost the extra money
just wanted to clarify my mistake...
