Re: 96 Interpid correction 97 sebring
[Re: BigTerry]
#471070
09/20/09 01:42 PM
09/20/09 01:42 PM
Posts: 862 Southeast Pa.
SALEM1912
Southeast Pa.
Engine Start-Up Mode – This is an open loop mode. The following actions occur when the starter motor is engaged: 1. The auto shutdown and fuel pump relays are energized. If the PCM does not receive the camshaft and crankshaft signals within approximately one second, these relays are de-energized. BTW are you getting spark?
[Re: BigTerry]
#471074
10/04/09 02:50 PM
10/04/09 02:50 PM
Posts: 163 Winnipeg, MB
sreinheimer
Winnipeg, MB
Yes it has a automatice tensioner for the timing belt and yes the water pump runs off the timing belt
69 Dodge Charger - first full resto
05 Dodge Magnum R/T
[Re: sreinheimer]
#471075
10/04/09 09:32 PM
10/04/09 09:32 PM
SALEM1912
Southeast Pa.
Big Terry w/pump rides on the t/belt.
