Re: 32 valve hemi heads.
[Re: RoyceFlo73]
#470655
09/17/09 10:18 AM
09/17/09 10:18 AM
Posts: 214 Hamburg / Germany
Den300
Hamburg / Germany
they where tested in a magazine. i have the scans at home (i think). i will put them in as far as i am home. as far as i know they made only one set. never understood that. i think they should have an extreme potency.
Hamburg/Germany
69 Chrysler 300 446cui Dual Quad 12.64 @ 110.7
[Re: RoyceFlo73]
#470659
09/17/09 07:11 PM
09/17/09 07:11 PM
Posts: 1,141 Phoenix,Az.
hemicop
Phoenix,Az.
As I recall, Ford got beat so badly by the Hemi in NASCAR ![](/ubbthreads/images/graemlins/thumbs.gif) Ford came out with the SOHC motor shortly thereafter & said if Nascar was going to allow the Hemi,a non-production engine, Ford was going to use the SOHC. Mopar came back & said "Fine! we'll use THIS!" and brought out the DOHC Hemi. Bill France went nuts & said NEITHER was going to be used. That brought about Chrysler's protest of Nascar in '65 resulting in a lot of their racers (including Petty) going drag racing. In '66 when the street Hemi came out (and the only there WAS a street Hemi) Mopar could now return with a "production" engine in the Hemi. Ford had considered putting the SOHC in Fairlanes and/or Galaxies but that never happened, although rumors persisted some Gemini astronaut got one. Ford did sell the SOHC as an over-the-counter part & used them fairly successfully in drag racing (Gas Ronda, Connie Kalitta, even Don Prudhomme) for A/FX, F/C, T/F and a few ProsStocks in the late 60s/early 70s. But too few engines & parts were made & they were costly & the Boss 429 came on in the early 70s, so there was no real need for them. Actually, looking at old videos, the SOHC was really the only engine that could run with the Hemi in non-factored/indexed competition.
[Re: hemicop]
#470660
09/17/09 07:37 PM
09/17/09 07:37 PM
Posts: 3,505 DFW
mr_340
DFW
Yeah, that kind of sucked that NASCAR let Ford run the SOHC anyway after the Street Hemi came out. The 429 didn't come out until 1969. I remember the car mags showed the SOHC in the Woods Brothers cars back then.
Floyd Lippencott IV
[Re: Den300]
#470664
09/18/09 02:02 AM
09/18/09 02:02 AM
Posts: 27,483 So Cal
autoxcuda
So Cal
here they are
Nice work. That's pulling a rabbit out of the hat !!
[Re: autoxcuda]
#470667
09/18/09 02:30 PM
09/18/09 02:30 PM
Posts: 2,825 Sk. Canada
RemCharger
Sk. Canada
here they are
Finally, back on subject... ![](/ubbthreads/images/graemlins/eyes.gif) From what I remeber, They were just slightly less than a new car...
[Re: RemCharger]
#470668
09/18/09 02:49 PM
09/18/09 02:49 PM
Posts: 1,209 Fredericktown, PA 15333
maundmotorworks
Stealth poster
Stealth poster
Those heads were indeed made by Marty Covalt. I spoke with Marty a couple years ago or so about them because I had a customer inquire about them. Marty was working with Predator Cylinder Head at the time. He said that they didn't make too many sets of them. Back in the early 90s people saw the $10,000 kit price as a bad case of sticker shock despite what they were getting. You spend over 6,000 putting a top end together for a standard 16 valve hemi these days, so 10,000 for a complete 32 valve conversion kit realy isn't too bad IMHO. As for the 32 valve Nascar Hemi, it was called the A-925. It never ran under its own power. Chrysler played with two different top ends for it, one a SOHC and the other a DOHC. The DOHC ended up being what they went with. Just around the time the project was nearly done, the project was ended because Nascar outlawed overhead camshaft engines. Thank you, Bill France for your signature...you single-handedly killed off what was destined to be the greatest Chrysler engine of all time. ![](/ubbthreads/images/graemlins/puke.gif) It was projected to make over 900HP and be capable of long term speeds of 8000 RPM+! Here's something to think about, guys. At the time, to run an engine in Nascar the factory had to use the engine in at least 500 cars for sale to everyday people driving on the street. Imagine being able to buy a brand new '64 Plymouth with an optional aluminum block 32 valve DOHC Hemi.....WOW!!! ![](/ubbthreads/images/graemlins/drool5.gif)
Maund Motorworks--supplier of high performance Mopar engines--specializing in B, RB, and Hemi. www.maundmotorworks.com
