Re: Dyno day for my 512 - finally!
[Re: ZIPPY]
#469934
09/16/09 10:22 PM
09/16/09 10:22 PM
Posts: 996 Queens, New York
Harley
Queens, New York
Good luck Tony. 655/610
Re: Dyno day for my 505 - Results and NEED HELP!
[Re: Harley]
#469935
09/17/09 11:04 PM
09/17/09 11:04 PM
Posts: 4,296 Chicago, IL
TonyS451
Chicago, IL
OK guys. Made a couple pulls tonight and its not even in the ballpark. timing was at 36 and jets were 78 w/pv and 86. Jetted up 2 sizes and lost power. Tried 34 degrees and lost power. Peak hp was at 5700 rpm - 560hp, peak tq at 4900rpm - 559lbft. Checked cranking compression and all cylinders were right at about 160. Loosened lash .005 on cyl 1 as a test and pressure went up to 175. Valve lash was checked and none were out of line. What do you think the problem could be? My engine builder thinks the cam is wrong and the intake is not great. How much could port matching the intake be worth (if it was off by a lot)? Why would it not pull past 5700?? Here are the cam specs: 262/268 @ .050 lobe lift .390/.400 lsa- 112 recommended installed at 108, and is installed at 109 .585/.600 lift Engine guys, please help!
2 kids and a dog
[Re: Streetwize]
#469937
09/17/09 11:50 PM
09/17/09 11:50 PM
TonyS451
Chicago, IL
Thanks for the feedback, Bobby. Manifold vacuum at 5700 is 1.5. Do you think the cranking compression is way low? As for the intake, how much do you think it could be holding back? What do you think about the torque numbers? They seem excessively low as well. Yes, the heads flow 315 at .600 according the MCH flow sheet.
Thanks, Tony
2 kids and a dog
[Re: TonyS451]
#469938
09/17/09 11:51 PM
09/17/09 11:51 PM
Posts: 6,591 Canton, Ohio
Sport440
Canton, Ohio
I was going to guess 575HP as the cam is very mild with a wide lobe sep of 112. But you asked for a cam with mild street manors and you got it.
But IMO the peak RPM HP is lower then it should be. So you Do have more there untapped as of yet. mike
[Re: GTXKen]
#469939
09/17/09 11:58 PM
09/17/09 11:58 PM
Posts: 19,537 Las Vegas
Al_Alguire
Las Vegas
I have never been a big fan of the SD manifold myself. But I know Dwayne and other have coaxed some good number sout of them, I just never have been able to. I would be looking there first and foremost. Assuming of course the cam is where it needs to be and is happy where it is.
[Re: Al_Alguire]
#469941
09/18/09 01:08 AM
09/18/09 01:08 AM
Posts: 2,840 Flint, Michigan
B1Fish540
Flint, Michigan
Probably need to port that SD intake. Or try an RPM Performer or M1 which should still fit under yer hood.
[Re: sixpackgut]
#469942
09/18/09 01:12 AM
09/18/09 01:12 AM
Posts: 2,410 Wichita,KS
Blakcharger440
Wichita,KS
Well... I have been watching this thread and waiting to see what kind of numbers you got with your 512 combo as it is soooo close to mine. Here is the combo and numbers as it was on the Dynojet. 512 stroker,4.25 Source crank,H-Beam Rods,.030 over,17cc dish pistons,10.5 compression,OOTB Stealth heads,OOTB EDDY RPM intake,950 Proform carb,1 3/4 headers,Hughes Solid 579/587 Lift 256/260 Duration LSA 108,Crane Gold 1.5 Rockers,Hughes springs,retainers and locks.Smith brothers pushrods,Melling HV pump,7 qt.pan,stroker windage tray. I used the 1 3/4 headers as they were all cheapy dinged up headers and I didnt want to ruin the ceramic coat on my Hooker 1 7/8 Super Comps 566HP / 5400RPM 640TQ / 3800RPM Primary jets are 78 with secondary 86. We tried jetting it up but the numbers fell down. The best runs were at 36 and thats where we locked it in. Fuel was a 50/50 mix of 87 pump and C14.
[Re: Blakcharger440]
#469943
09/18/09 01:36 AM
09/18/09 01:36 AM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
my old combo,493, standard port eddie heads, my tunnel ram w/ 6 pack and 590 cam would run 5 mph more than a single 4150 1000hp, it felt like i ran smack into a brick wall with the car at 5300.
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
[Re: TonyS451]
#469944
09/18/09 03:35 AM
09/18/09 03:35 AM
Posts: 793 Utah
topbrent
Utah
Yikes! That engine's potential is definitely higher than 560hp. I would presume a carb spacer, and intake porting/swaping is in your future. I know it is never a good idea to race dyno sheets, however...compare the data. Here is a very good engine to look at. (Not my engine, built by Straitline, Owned by Caper here on moparts) Straightline 496 info Simple, very stout, reasonable inexpensive 496" - similar to your combo. It is in Caper's 3700lb 69 dart, currently running 10.40's 496 CID Wedge - pump gas street engine (10.7 to 1) Built by Scott Brown at Straightline Performance. * 654 HP- 5600 -RPM ------------ - Hand Ported Edelbrock RPM heads (300 CFM) - Ported Victor Single Plane * 653 TQ- 4400 -RPM ------------ - Flat tappet, 263/273 @ .050 112LSA - 4150 Carb ( Quick Fuel 1050-AN) - 1" tapered spacer Somewhat lesser flowing heads, but definitely a better breathing intake setup.
[Re: topbrent]
#469945
09/18/09 08:10 AM
09/18/09 08:10 AM
TonyS451
Chicago, IL
Thanks for the feedback guys. I was figuring the intake may be a restriction, but I never guessed by this much. I will say this, I know this dyno is conservative. FWIW - The last engine I did on this dyno (493, indy-1's 13-1, solid roller, dominator) also had numbers on the low side compared to other combos here on Moparts.
Topbrent - I know about your combo and as a matter of fact, that is the combo that I had in my mind when I thought somthing was seriously wrong with my dyno numbers. I didn't expect to make 650/650, but I figured it would be at least 600/600. Maybe I should try a Victor for comparison?
2 kids and a dog
[Re: TonyS451]
#469946
09/18/09 08:32 AM
09/18/09 08:32 AM
Posts: 10,081 Frostbitefalls MN (Rocky&Bullw...
gregsdart
The increase in cranking compression when you loosened the lash, combined with the facts of only 175 psi at best and 1.5 hg vacuum on the top end get my attention. I would be real tempted to try the cam installed very early matched by a much better intake. Put it on the dyno with better headers and it should really come alive.
8.582, 160.18 mph best, 2905 lbs 549, indy 572-13, alky
[Re: TonyS451]
#469947
09/18/09 08:40 AM
09/18/09 08:40 AM
Posts: 347 Kewaskum, WI
Kelob_pie
Kewaskum, WI
I would guess 600-625 hp, low to mid 600's for tq. for your combo.
Might be that intake. Just more food for thought, I built a 506 very similar to yours, but slightly milder. 10.25:1 comp E-heads with valve job touched up Straightline hyd. flat tappet 240/250 .540/.530 lift, 112 lobe sep. Edelbrock Performer RPM intake Out of the box Demon 850 carb w/1" open spacer. Also on a conservative dyno, this thing made 577 hp and 644 tq. Had approx. .038 quench, so it liked timing at 35. This has to be one of the best bang for the buck street engines I did so far. It did pick up 8 hp with the open spacer, messed around with 2", 4 hole, open, etc., it liked the 1"open the best. So it just may be a matter of messing around with different intake combo's.
[Re: TonyS451]
#469948
09/18/09 09:22 AM
09/18/09 09:22 AM
Posts: 16,936 NC
440Jim
NC
What did the numbers look like from peak torque to the end of the pull? ie vol eff, A/F, torq, hp. Did the power fall off slowly or quickly?
Look at that other guys dyno table, it made peak hp at 5600, but only lost 5 hp at 6000. That is what I would expect.
I wouldn't expect the heads to flow enough to make power too high up (at 500+ CID), but I am guessing the MCH CNC should be enough to make peak power around 6000. And the cam should carry to that point too, IMO. Did you try a carb spacer on the intake? That should help. So you are missing only a few hundred RPM max. More duration would make more power up top, but if you are looking for 3000 rpm torque it will lose some there.
It is really just the hp number that seems low, and some of that could be the dyno comparison.
[Re: Dodgem]
#469952
09/18/09 02:27 PM
09/18/09 02:27 PM
TonyS451
Chicago, IL
Gonna try an M1 intake and my 2" TTI headers tonight. I'll let you guys know how it goes.
2 kids and a dog
