Re: Track Checklist [Re: HardcoreB] #469821
09/17/09 11:31 AM
09/17/09 11:31 AM
Az
Crizila Offline
Crizila  Offline
Az
i didnt see...
That's because you didn't open the Word document I posted. Open it, (add to it?), print it out, and use it.
What's "pool floats" on your list.
Fastest 300
Re: Track Checklist [Re: Crizila] #469822
09/17/09 11:36 AM
09/17/09 11:36 AM
Chicken coop
dustergirl340 Offline
Chicken Little
Chicken Little
Chicken coop
Here's mine
I like Pit Crew - Mary, listed under Misc. Equipment.
Re: Track Checklist [Re: dustergirl340] #469823
09/17/09 12:20 PM
09/17/09 12:20 PM
gregsdart Online content
gregsdart  Online Content
Misc spare parts, small, nuts, bolts, washers,carb cleaner, gasket material, razor blades ,
Ign cap, rotor, wires, plugs, epoxy,carb gaskets and parts,drain pan, funnel, rags, valve train repair tools and spares, hose, clamps, torch, tie wraps, epoxy,sand paper,wiring kit and wire, small wiring parts,electrical test equipment, tow straps, cell phone, other racers numbers in case you need a tow, check tow vehicle spare tires, tire change equipment,,,,,,,
8.582, 160.18 mph best, 2905 lbs 549, indy 572-13, alky
Re: Track Checklist [Re: Crizila] #469824
09/17/09 02:24 PM
09/17/09 02:24 PM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
Contributed by Eric with the Arrow. They make the trailer ramp cables easily visible. Although I don't bring them I thought it may be a good addition to the list. As I said, this list was compiled from other posts by many members of the same nature here, I just used my own 'shorthand' abbreviations.
