Re: Economy 440 Build Suggestions
[Re: CYACOP]
#468948
09/17/09 01:42 PM
09/17/09 01:42 PM
Posts: 5,221 Branson, Mo.
joedust451
super gas
super gas
Branson, Mo.
new one: "decompressed pistons"
I'm so sorry. Low compression pistons, dog dish pistons, blower pistons, smog pistons.........any of these suit you?
Yes, all the same thing. If you order a complete engine kit make sure the pistons are NOT the ones with the 1.912" compression height. There's no point in putting those in a motor, you'd be better off re-ringing a tired 440 than wasting your money with those. The one summit may be waiting on are likely their 'not as bad' 1.991" compression height pistons. At least with those you get a somewhat usable CR. My choice if you want something on a budget would be KB237's or even trw 2355's.
I did some checking and see the KB237's will give me a 10:1 compression ratio at 88cc heads. To get a 9.5 to 1 ratio It was suggested use the KB184's which I cannot find, orders since June not filled yet, back orders The TRW's 2355's at 9.4 to 1 are also not available until who know's when. So I continue my search. Decided to get away fron rebuild kits and get the pistons for now but that seems to have it's own issues. I want to shoot for a 9.5 to 1 comp ratio.
Just get the KB237s, with a 90cc head (wich most 906/452s are around 91-92 stock) says the comp. will be 9.7.1, this is with the piston around .010" in the hole & a .039" gasket, i've run these pistons before, with an untouched block, they accually sit around .016".017" below deck, mine ran fine on pump premium, Competition Products has them in stock for 329.99, don't know what Summit/Jegs wants for them, i checked on the TRW 2255s, they didn't stock them.
[Re: CYACOP]
#468949
09/17/09 03:45 PM
09/17/09 03:45 PM
Posts: 16,123 Grand Haven, MI
patrick
Grand Haven, MI
if you actually do the math, those pistons, to a blueprint height block will sit .015" in the hole. with a 4.35" bore, 3.75 stroke, a gasket 4.5" diameter, .039" compressed, with the 5cc valve pockets and .015" in the hole, and neglecting crevice volume, for an 84cc head (closed chambered eddies) you get 9.9:1 comp, 88cc (open chambered eddies) 9.55:1, and the typical OEM open chambers (90-92cc) 9.25-9.4:1 compression. change the head gasket to a steel shim (.018-.021" thick, 4.38-4.45 bore for the MP or Mr. gaskets'), compression goes up by ~.4. reducing my 4.5" diameter, .039" head gasket to a 4.35" diameter, .039" gasket raises compression by .05
[Re: Robbins]
#468951
09/17/09 06:24 PM
09/17/09 06:24 PM
Posts: 3,958 SW Fla.
CYACOP
SW Fla.
This info below is for the KB184 piston
ENTER YOUR DATA CALCULATED DATA Cylinder Head Volume (cc) 78 Piston Head Volume (cc) -2 Gasket Thickness (in.) .044 Gasket Bore (in.) 4.5 Cylinder Bore Diameter (in.) 4.35 Deck Clearance (in.) .08 Stroke (in.) 3.75 STATIC COMPRESSION RATIO 09.40 OPTIONAL DATA Rod Length (in.) 6.758 Adjusted Stroke (in.) 3.255 Intake Closing Point (degrees) ABDC @ 0.050 lift plus 15 degrees 49 DYNAMIC EFFECTIVE COMPRESSION RATIO 08.29
This is what I ran with 915's.
Looks like the dynamic calcs are much lower than expected. Looking at the chart I have it says the 80cc heads result in a 9.7 CR your static number is even lower, then you add in the dynamic variablles and end up with about an 8.3 CR. It seems to be a fine line but I really didnt want to have to run premium gas but upon closer inspection the KB237's are looking to be the better choice. Actual results may vary.
[Re: CYACOP]
#468952
09/17/09 11:02 PM
09/17/09 11:02 PM
DaytonaTurbo
Manitoba, Canada
Don't waste your time with those charts. The charts the piston manufacturers put out make all kinds of assumptions and always give back an overly high CR. Just use an online calculator and plug in the real numbers and get an accurate reading.
For a piston installon a real-wold block and a typical .039" gasket, 90cc production heads, etc, compression is not as high as they make it out to be. Granted it is high enough for iron heads and pump gas, but should be doable. I still think that the KB237's or TRW2355's are the ticket for you, if you can find them in stock.
[Re: DaytonaTurbo]
#468955
09/18/09 09:37 AM
09/18/09 09:37 AM
CYACOP
SW Fla.
I did the online calculator and see what you mean. Resulted in a 9.5 CR. Looks like I'll go with the KB237's. I spoke with the machine shop and early next week he will underbore the worst cylinder to be sure .030 will clean things up then I will order the pistons next week. Thanks for all the help, I'm sure I will be back for more.
[Re: CYACOP]
#468956
09/18/09 11:26 AM
09/18/09 11:26 AM
Posts: 12,675 Columbia, CT
moper
Columbia, CT
Also keep in mind, a dynamic compression depends on teh cam, and you dont want a dynamic with open chamber heads any higher than 8.3:1. To put it in perspective I use 8.5:1 as a max dynamic with aluminum and closed chambers to run pump high test.
