Re: drag racing: obvious safety gaps
[Re: Scott440]
#467629
09/14/09 07:04 PM
09/14/09 07:04 PM
Posts: 1,131 Thigh-Gap Junction
New user name, Same old jerk!
Thigh-Gap Junction
1-bigger, softer barricades ...
Hard impacts are rare when you're travelling parallel to the wall.
2-soft center divider along the entire strip so a crazy car doesn't take out his competitor
crossing the center line is common and usually the only casualty is a foam block or two. Two vehicle accidents are very rare.
(-- even a 48" high wall sitting in a 12" deep trough could delay the cross over a second or two.
How are the Jr. Dragsters going to see each other? How would other pipe-rack divers judge the finish line?
3-fluid catch pan/tray under the engine.
Diapers are being phased in, have been for a while.
4-if a car has a parachute and is not reasonably close to the center of his lane, or tire pressure drops way low, or a fire occurs, there should be an electronic auto-deploy of the parachute.
Yeah, I want someone pulling the chute on me when I still have a chance to win, flames or not. You're allowed to use the whole lane, if necessary.
Go back to running for president, Ralph (Nader)
[Re: Scott440]
#467630
09/14/09 07:11 PM
09/14/09 07:11 PM
Posts: 5,314 Carstairs, Alberta, Canada
dave571
have an e body pink slip to bet?
I don't see where you've raced anything, in this answer.
Is this a yes or a no?
As for safety gaps, the NHRA rules have evolved over time. They have evolved with the cars and the sport. Are they perfect? Of course not. Neither is any other motor sport.
[Re: dave571]
#467631
09/14/09 07:26 PM
09/14/09 07:26 PM
Posts: 4,616 Kissimmee Fl.
dusturbd340W5
Kissimmee Fl.
Well I am sure I will get flamed for this but I fell they try and push to much safety down my throat now I don't think I could stand any more of it.
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
[Re: Scott440]
#467638
09/15/09 10:48 PM
09/15/09 10:48 PM
Posts: 12,584 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Not offensive, just a lack of reality. Belly pans and diapers exist and are in use. You want one, build it and put it on your car. Auto chute release in use on fuel cars. A center divider with a water trough? I don't know what to say about that, be a little tough to fender race somebody in the lights. Hay bales? What would that look like after someone hit them at 200+? No concrete walls? Have you ever seen a car torn to pieces because it got up on an old fashioned guardrail and started to roll? Do some more research, spend some time at the track and try again.
[Re: CMcAllister]
#467639
09/15/09 11:18 PM
09/15/09 11:18 PM
Posts: 435 New Mexico
Scott440
New Mexico
so for the driver in the accident (see link)... what do you think could have been done to make the mechanical failure a minor incident only.
[Re: Scott440]
#467640
09/15/09 11:25 PM
09/15/09 11:25 PM
Posts: 3,616 Riverside, Ca
G_bob
Riverside, Ca
Would probably have to see video of the whole thing to make a determination of that. He wasn't on a track with concrete barriers, but rather old style posts and rails. He's on the grass side of the rail, so somehow he went over. Maybe front end, or a tire caught one of the posts and sent him flipping whereas he could have slide along a concrete barrier.
As said, hard to say without seeing the whole thing.
Maybe a diaper (did he have one?) would have kept water/oil off the tires.
[Re: Scott440]
#467642
09/16/09 06:56 AM
09/16/09 06:56 AM
Challenger 1
Cincinnati, Ohio
quote]i drag raced at lacr and once at fontana. my current car is strictly for road racing. i'd love to road race against your rail for it's pink slip can you trailer it 1,100 miles.
I've towed over 100K miles all over the country in the last 19 years. I've raced everything from a low 9 sec drag bike to a 5.49 ET TAD. 1100 miles is nothing.
NHRA has been studying safety for 50+ years, I beleive it's as safe as it can be right now without slowing down the cars. What fun would that be? I think your ideas are way out there and not realistic.
In 2003 I hit the wall head on at 240 MPH and got out of the car on my own with no injurys, Thank God and the NHRA. Part of the reason I crashed was because of water coming up through the track and dips in the pavement, same day 5 other cars crashed in the same lane including Jason Line in Greg Andersons pro stock car. Been there, done it! It was my choice to go down the track that morning. NHRA closed that track early that year and repaved it.
Just got back from a 5000 mile road trip a month ago, I was in Kings Beach,Truckee Ca,Reno, Vegas, Colarodo Springs, Grand Canyon. I would have raced you in my street car just for fun.
Bonneville Salt flats Red car is mine.
[Re: Scott440]
#467643
09/16/09 09:19 AM
09/16/09 09:19 AM
Posts: 23,515 Here
jcc
Here
And I might add, using water anywhere near the track for safety really doesn't work IMO. Ever seen a 150 mph hydro skip multiple times and then dig into the water when out of control. Not pretty. And hitting water at high speed is a lot like concrete. Additionally it would likely spray the track in the other lane ruining his day. And 6" of water can drown someone. Imagine 6" of water being scooped up at hign speed by an upside down car with its windshield blown out. AT Mororos years ago on the road race course a sport car flipped upside down and slid thru the wet mud off course. The drivers compartment filled up with mud and he died before they could remove the mud and extract him. The safest track likely would be 2 high concrete walls teflon lined only inches wider then the car and totally counterproductive to typical racing Everyone now gets to choose how much safety they desire, or don't race.
"When one’s appeal is emotional, it does not matter if there is no substance."
[Re: Scott440]
#467646
09/16/09 06:38 PM
09/16/09 06:38 PM
Posts: 1,329 NC
DCM71cuda
NC
...too much attitude here given the lack of background.
I think my background in this area is well substantiated.
Water will not be used unless contained in a barrel.
Your Studebaker crash: The best way to prevent that crash is to prevent the mechanical failure. From the pictures shown, you can't tell much other than most of the rolling done by the car was on the grass and not the track. You can see the car was not on the guardrail anywhere near where it came to rest.
[Re: Scott440]
#467647
09/16/09 07:34 PM
09/16/09 07:34 PM
Posts: 6,257 acworth / N. georgia - south e...
cheapstreetdustr
prior to the 60s, seatbelts and helmets were sometimes missing from motorsports. now, it seems like an obvious safety gap...to even THINK otherwise is insane. we get a chuckle out of seeing leather racing helmets in old photos.
well, after seeing a few drag wrecks, i gotta say there are still some obvious things missing:
1-bigger, softer barricades ... hay bails burn rapidly , water filled drums hose down the track ... with or without a guard rail. just get rid of those concrete walls!nope keep car pointed down track to deflect blow. how about 4 rows of water drums on each side of the track, spaced. and space them a few feet apart to give the car more gradual deceleration.did someone mention all the issues water will create? and make the drum easy to split open -- water or fire slurry couldn't hurt a car on fire. yea but a simple little outa groove excursion and track is down for hrs drying/cleanup.
2-soft center divider along the entire strip so a crazy car doesn't take out his competitor (especially when the competitor is slightly behind). so it obstructs visibility for the fans -- even a 48" high wall sitting in a 12" deep trough could delay the cross over a second or two. shame on you sanctioning bodies -- if you've left this out for fan visibility, you've been getting away with murder. "what"
3-fluid catch pan/tray under the engine. how many times has something broke loose, spewing lubricant or coolant conveniently ahead of the rear tires. it could help with aerodynamics (smoother airflow under the car) and eliminate costly downtime (ridding the track of fluids). yea and be a huge source of fuel for a fire
4-if a car has a parachute and is not reasonably close to the center of his lane, or tire pressure drops way low, or a fire occurs, there should be an electronic auto-deploy of the parachute. i'm sure with today's technology, the signal to deploy could be sent remotely by track equipment. OK, this concept is a bit elaborate, but definitely worthy of some trials. until i get the garage door opener code and deploy your shoot mid track in the other lane...oooops.....sorry dude.
while you're at it, apply these concepts to other forms of auto racing.
items 1-3 may be present at *some* strips today, but if drag racing is around in 2050, they will be universal, and people will laugh at 2010 safety standards.
i got something that will fix all of this..just attach said race car to a track or rail like a monotrain...that would be the safest...NOT! or better yet..lets just race in the vertual cars they trailer in..the ones the KIDDDIES wait all day in line for....that would be safe!!!!
365" Iron J heads,,3480lbs best 1.39 60ft on SS springs.10.54,124 mph ...6.67 1/8th et.average 60fts 1.46 w/ small cam &.063 no2 pill tagged & insured [image][/image]
[Re: cheapstreetdustr]
#467648
09/16/09 08:04 PM
09/16/09 08:04 PM
Posts: 3,104 Wheels up, MO
nhramark
Wheels up, MO
When I saw this topic I had a few other ideas:
Pro Stock, Comp Eliminator, etc, DO NOT need a guy standing directly in front of the car during the burnout. Let that car get the least bit out of shape and you have a dead man. If you can pilot a 6 second car, you should be able to complete a burnout on your own.
Funny car crews should NEVER be allowed to reach their arms under the rear fenderwells to wipe the tires while that car is pulling up to the line. I don't want to see two guys lose both arms because of a throttle or clutch malfunction.
Downtrack safety crew, EMT, track manager, SOMEBODY should have full control of when next pair of cars go down the track. The starter should have NO authority to send cars down unless the downtrack person has given the "all clear." I have seen several times when a broken car was still on the track with the next pair coming right at them. No excuse for this at ANY level of racing EVER.
Also NHRA national events should allow maybe half the people at the starting line then they have now. Remember Doug Herberts starting line explosion? Scott Weis had one too a couple years ago. No way all those people are needed up there.
[image]http://s1126.photobucket.com/user/nhramark1/library/Racing[/image]
9.100 @ 150 mph
5.780 @ 120 mph
