Page 2 of 3 1 2 3
Re: total piece of trash!!!!!!!!!!!!!!!!!! [Re: 572_dup2] #465903
09/11/09 08:07 PM
09/11/09 08:07 PM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
I hate to hear that Shawn. So close be yet so far. Do you feel that the new induction system is tuned for all it's worth? I forgot if your using a wide band or not.
Dont give up man, it will happen. All your hard work will pay off....
At this point it's hard to keep from being disgusted.
But the others might be on to something, having a fresh set of eyes, or a 2nd opinion and suggestions at this point might not be such a bad idea.
Re: total piece of trash!!!!!!!!!!!!!!!!!! [Re: bigdad] #465904
09/11/09 08:08 PM
09/11/09 08:08 PM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
If it's worthless, I'll be down and take it off your hands.
Trailers already hooked up, just need directions to your place.
Re: total piece of trash!!!!!!!!!!!!!!!!!! [Re: sixpackgut] #465905
09/11/09 08:09 PM
09/11/09 08:09 PM
Salina ks
572_dup2 Offline OP
Back On The Bumper!!
572_dup2  Offline OP
Salina ks
start retard? timing chain or belt? valve stuck open? coil?
Start retard is where it has worked, brand new belt, heads were completly redone 6 runs ago, never checked coil.
Shawn Jennings
Re: total piece of trash!!!!!!!!!!!!!!!!!! [Re: 572_dup2] #465906
09/11/09 08:13 PM
09/11/09 08:13 PM
MD
Kevins493 Offline
Kevins493  Offline
MD
What was changed on the heads?
Re: total piece of trash!!!!!!!!!!!!!!!!!! [Re: 572_dup2] #465907
09/11/09 08:16 PM
09/11/09 08:16 PM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
fuel puddling in the intake, i have had cold start backfires but not while its running. if the start retard is pulling to much timming on start up it can cause a good backfire
Re: total piece of trash!!!!!!!!!!!!!!!!!! [Re: slantzilla] #465908
09/11/09 08:20 PM
09/11/09 08:20 PM
CheddarHead till October
weedlayer Offline
weedlayer  Offline
I'll race ya there Denniszilla, I like worthless junk
Re: total piece of trash!!!!!!!!!!!!!!!!!! [Re: weedlayer] #465909
09/11/09 08:27 PM
09/11/09 08:27 PM
Salina ks
572_dup2 Offline OP
572_dup2  Offline OP
Salina ks
Nothing was done to the heads just freshed up.
This was the first time it ever backfired with 2x4s.
Shawn Jennings
Re: total piece of trash!!!!!!!!!!!!!!!!!! [Re: 572_dup2] #465910
09/11/09 08:35 PM
09/11/09 08:35 PM
Upstate NY
Bigcube Offline
Bigcube  Offline
Upstate NY
Do you use a start retard? If so how much you timing are you pulling out? I had similar problems, many times it would backfire on startup when warm or act like it was flooded. It was fine when cold or hot but if it had been sitting for 10-15 mins it was a problem. 2 things were wrong to cause it. First, the carb was dripping fuel in the intake when it sat with the bowl full. If it was stone cold the dripped fuel would eventually evaporate. If it was hot there wasn't enough fuel dripped to make a difference. Second problem was too much start retard. I was pulling 25 deg, only option with a 7al3. I think it was enough to cause misfires in the cap. So fire the wrong cylinder with puddled fuel in the intake and you have flames coming out of the carb on startup.
Re: total piece of trash!!!!!!!!!!!!!!!!!! [Re: 572_dup2] #465911
09/11/09 08:36 PM
09/11/09 08:36 PM
Central,Ohio
FASTFISH420 Offline
FASTFISH420  Offline
Central,Ohio
Since i have put on 2x4s it has lost MPH! 60' is better but thats it. An caused nothing but problems in areas we have never had trouble with before.
Everyone that I have talked with that have changed to dual fours and manifold had nothing but problems..they are very tricky to get right and even harder for a heavy car..converter is a big deal with dual fours also..
1969 Barracuda 8 second all/motor small block 2014 Shelby GT500 Mustang Uratchko Racing Engines www.URE-RACING.com
Re: total piece of trash!!!!!!!!!!!!!!!!!! [Re: weedlayer] #465912
09/11/09 08:38 PM
09/11/09 08:38 PM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
Re: total piece of trash!!!!!!!!!!!!!!!!!! [Re: FASTFISH420] #465913
09/11/09 08:39 PM
09/11/09 08:39 PM
Salina ks
572_dup2 Offline OP
572_dup2  Offline OP
Salina ks
Since the 2x4s have went on we have had 15 retard. Has started perfect everytime never once a problem. It has started better than the single 4. Car wasnt hotter or colder than any other time.
Shawn Jennings
Re: total piece of trash!!!!!!!!!!!!!!!!!! [Re: 572_dup2] #465914
09/11/09 08:41 PM
09/11/09 08:41 PM
Upstate NY
Bigcube Offline
Bigcube  Offline
Upstate NY
Fill them with fuel, take them off the intake and set them on the workbench for 20 mins and see if they are dripping. My old carb did that.
Re: total piece of trash!!!!!!!!!!!!!!!!!! [Re: slantzilla] #465915
09/11/09 08:42 PM
09/11/09 08:42 PM
Charleston
sixpackgut Offline
sixpackgut  Offline
Charleston
dist phasing another thing to look at
Re: total piece of trash!!!!!!!!!!!!!!!!!! [Re: FASTFISH420] #465916
09/11/09 08:43 PM
09/11/09 08:43 PM
Central,Ohio
FASTFISH420 Offline
FASTFISH420  Offline
Central,Ohio
When I had a 572 In my car,,I always had trouble starting it..it had 16.1 compression and used to break the ring gear after around 20 starts or so..I didn't use the msd start retard,because I heard they very rarely work..so I installed a msd adjustable retard and used to crank it on -20 and when it started would switch the knob back to 0..worked great..I dont even use a retard with my small block and it has 16.1..it also helps having the 16 volt battery also...
Re: total piece of trash!!!!!!!!!!!!!!!!!! [Re: 572_dup2] #465917
09/11/09 08:44 PM
09/11/09 08:44 PM
Salina ks
572_dup2 Offline OP
572_dup2  Offline OP
Salina ks
Have been to 3 different tracks in kansas.
Dont matter if it 95* or 75*, air can be 1700ft or 4500'
60' can be 1.28 or 1.35
Dont matter if power valves are in with correct jetting. or change jettin with plugs in.
It dont matter what you do it will run 9.12-9.15 145 thats it!!!
Shawn Jennings
Re: total piece of trash!!!!!!!!!!!!!!!!!! [Re: Bigcube] #465918
09/11/09 08:45 PM
09/11/09 08:45 PM
Charleston
sixpackgut Offline
sixpackgut  Offline
Charleston
bigcube, where were they dripping from? the boosters, intermediat circuit? PV vac hole?
Re: total piece of trash!!!!!!!!!!!!!!!!!! [Re: FASTFISH420] #465919
09/11/09 08:46 PM
09/11/09 08:46 PM
S.E. South Dakota !
bigdad Offline
Still Posting A Lot
bigdad  Offline
Still Posting A Lot
S.E. South Dakota !
I put 16 volt battery in mine, wow..does it spin over now
And soon as I hit the ign switch , it fires instantly
The lips of fools bring them strife, and their mouths invite a beating.Proverbs 18:6
Re: total piece of trash!!!!!!!!!!!!!!!!!! [Re: 572_dup2] #465920
09/11/09 08:47 PM
09/11/09 08:47 PM
Central,Ohio
FASTFISH420 Offline
FASTFISH420  Offline
Central,Ohio
How do the plugs look after a run? and what fuel are you using?
Sounds like you might have a air problem...
Re: total piece of trash!!!!!!!!!!!!!!!!!! [Re: 572_dup2] #465921
09/11/09 08:49 PM
09/11/09 08:49 PM
N
NITROUSN Offline
NITROUSN  Offline
N
What coil? Last year I had a brand new MSD pro power coil that drove me nuts.
Re: total piece of trash!!!!!!!!!!!!!!!!!! [Re: bigdad] #465922
09/11/09 08:50 PM
09/11/09 08:50 PM
Salina ks
572_dup2 Offline OP
572_dup2  Offline OP
Salina ks
2-12volt batteries
Q16 fuel
An now i cut 2 HOLES in the cowl HOOD. Didnt make a difference. But maybe its still not gettin enough air?
Plugs look good. Have checked them at the end of the track.
Just dont no how starting it 2 minutes later could have done this make damage an cause this much of a problem?
Shawn Jennings
Page 2 of 3 1 2 3
