69 Road Runner - unable to locate fuse box
#465822
09/11/09 06:53 PM
09/11/09 06:53 PM
I'm new and this my first post.
Bought a 69 roadrunner 383
Any hint where the fuse box is?
I am not into electrical and wiring since I just do not fit into those spaces really well in the heat.
I searched every friggin nook and cranny of this site, google, and my car... I searched dash, behind dash, under steering column, under carpet by kick panels.
It's 100+ degrees in AZ and I got sweat rolling into my eyeballs messing up my glasses.
I checked underneath dash. Even unscrewed some lower dash panels to peak inside.
I am trying to troubleshoot why my fuel gauge, speedometer, hazards, rear back up lights do not work. Everything else works fine and the car runs like a bat outa hell.
The speedometer (once I am drive) will sweep from 40-60 at idle at a red light. It will not do it when in park. Gotta get that fuel gauge going or start thinking every 8 miles = 1 gallon. I wish I had a casette tape to shove in the player to see if that works...
Re: 69 Road Runner - unable to locate fuse box
[Re: stumpy]
#465825
09/11/09 07:07 PM
09/11/09 07:07 PM
yep - I even unscrewed the 2 screws on the inside left inside glove box area about a 2" high x 3" wide rectangular space.
#465827
09/11/09 07:13 PM
09/11/09 07:13 PM
ok because when I peeked in there I did not see it.
I will try again and bring my camera for a couple of pix after some shade gets here(2 hours) -
thanks that's where I would have put a fuse box. seems like it should fit behind that 2 screw panel on the left.
Anyone have ideas about the fuel gauge or speedometer? To me it looks like some jackass used teh wiring for the after market gauges. that's my guess at least for now. Any ideas are welcome.
