Re: Dominator tunning
[Re: Quicktree]
#464389
09/09/09 10:00 PM
09/09/09 10:00 PM
Posts: 52,972 Romeo MI
MR_P_BODY
how come there are only 2 different pump cams for a dominator? yellow and white are the only 2 availble. anybody used a dom on a small cube motor?
How small Tony... I have a 8896 1050 on a 405ci
[Re: Quicktree]
#464392
09/09/09 10:42 PM
09/09/09 10:42 PM
MR_P_BODY
mine is 366ci, what pump set up are you running? squirter size etc?
I'd have to look at my other dom tomorrow... the one on the car now is a E-85 dom What kind of problem are you having
[Re: MR_P_BODY]
#464393
09/09/09 11:20 PM
09/09/09 11:20 PM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
brown cam is smaller pump for a Dom 50cc pump
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
[Re: sixpackgut]
#464394
09/10/09 06:03 AM
09/10/09 06:03 AM
Quicktree
there is no brown cam for a dom. the shaft on a dom is bigger than a 4150. it has nothing to do with the pump size.
[Re: MR_P_BODY]
#464395
09/10/09 06:07 AM
09/10/09 06:07 AM
Quicktree
the idle circuit is perfect. pump shot is to long I think. smaller squirters make it worse makes it load up. I have the white cams coming in. the yellow is the largest.
[Re: Quicktree]
#464397
09/10/09 10:27 AM
09/10/09 10:27 AM
MR_P_BODY
Tony, I have yellow cams on mine(both sides)
[Re: MR_P_BODY]
#464398
09/10/09 11:17 AM
09/10/09 11:17 AM
Quicktree
yea mine also, I have the white cams coming. I don't see a chart to compare the difference though. what squirters are you running? was just wondering why they make only 2?
Post deleted by Defbob
[Re: Cab_Burge]
#464401
09/10/09 02:57 PM
09/10/09 02:57 PM
#464403
09/10/09 06:47 PM
09/10/09 06:47 PM
Quicktree
Unless its a 750 Dominator, that carb is way too big for that little bracket motor. Try a 750.
duh you think
#464404
09/10/09 06:59 PM
09/10/09 06:59 PM
MR_P_BODY
WOW.... and we have guys on here with about the same CI and have 2 1150 doms on them... my 405 has run quicker and faster with every larger carb I've put on it
[Re: MR_P_BODY]
#464405
09/10/09 07:19 PM
09/10/09 07:19 PM
