Re: Aluminum block [Re: B1Ken] #462470
09/08/09 05:45 PM
09/08/09 05:45 PM
Saskatchewan, Canada
cudabin Offline
cudabin  Offline
Hi Ken, welcome back!
I just bought a low deck Indy Max alum block from Muscle Motors and Mike told me he could not get a KB block right now...
They machined everything into spec and bushed the lifter bores.
Call Mike at MM to get a price.
Cheers,
Arnie
67 Cuda 8.48@ 158.7 mph 1.18 60' 2,600 DA(so far...) 70 Super Bee 440 Six Pack 4-speed. 13.2 @ 104 Stock exhaust/Street tires.
Re: Aluminum block [Re: cudabin] #462471
09/08/09 06:08 PM
09/08/09 06:08 PM
Illinois
CRE2004 Offline
super gas
CRE2004  Offline
super gas
Illinois
The Indy Maxx blocks come with NO oiling to the lifters, why did they bush it? Keyway lifters? Just not like aluminum bores? Did they drill it for lifter oiling?
Re: Aluminum block [Re: CRE2004] #462472
09/08/09 08:43 PM
09/08/09 08:43 PM
Arizona
Chris'sBarracuda Offline
Arizona
I'm fairly sure you can still get KB blocks..
You should call and check.. Last I heard you could..
Chris..
Re: Aluminum block [Re: CRE2004] #462473
09/09/09 12:43 AM
09/09/09 12:43 AM
cudabin Offline
cudabin  Offline
Yes they had the block machined for pushrod oiling for me. That cost more, but I like it better than spray bars.
Arnie
Re: Aluminum block [Re: Chris'sBarracuda] #462474
09/09/09 01:14 AM
09/09/09 01:14 AM
Sonora CA
Mopar_Rich Offline
Mopar_Rich  Offline
Sonora CA
I'm building two 572 engines right now using the World Products "prepped" aluminum blocks. I checked them both before deciding on what machining to do and guess what - nothing, nada, no machining required. Line hone was perfect (+ or - .0005), as was the lifter bushings, block height, sleeves and cap clearances.
I love KB blocks because I have built so many race engines with them including my own TS motor. Never had an issue that Ken didn't take care of. Great company, but if you can't get a KB - the WP block is my choice.
Re: Aluminum block [Re: Mopar_Rich] #462475
09/09/09 12:00 PM
09/09/09 12:00 PM
Mo.
supercomp Offline
supercomp  Offline
Mo.
426/440 Aluminum BB-Chrysler Race-Prepped Engine Block
Deck: 10.725
Bore: 4.530 Type:
Wedge Main Caps: Nodular, Cross Bolted
$7,864.99 truck frieght $119.00
Just seems a little high to me even though it's prepped.
Re: Aluminum block [Re: supercomp] #462476
09/09/09 12:28 PM
09/09/09 12:28 PM
Netherlands
72Challenger Offline
Netherlands
Looks way to high if you ask me too, I payd about 2k less for my alu KB ready to use...
Re: Aluminum block [Re: 72Challenger] #462477
09/09/09 01:27 PM
09/09/09 01:27 PM
The Swamp
MegaDart Offline
MegaDart  Offline
The Swamp
most of my opponents being 20+mph slower usaully do not lift and try to back into me.
if they are "backing" into you they are lifting
I've been on both sides of the fence being the faster and slower car. In Top Dragster I had the #1 qualifier come by my 182pmh at 227mph but my win light came on
At IRR in Top Sportsman I was the slowest car in the field and won the race looking backwards every pass. Do you job on the tree and decisions get much easier at the big end!!
good luck with your decision Ken, I would opt for #1 but that's just me!! But stay with 24* conventional head, much less top end maintenance and huge power potential.
