Re: Anyone else Having trouble with JUNK INDY Pushrods ????
[Re: Quicktree]
#462358
11/04/09 04:19 PM
11/04/09 04:19 PM
Posts: 1,608 fresno ca
mikeysmopars
fresno ca
Well as a matter of FACT! I aparently am crazy But now I'm crazy enough to go eslewhere for parts and service. Just an expensive lesson.
Founder and CEO of the Central Valley Mopar Drag Pack
[Re: B G Racing]
#462360
11/04/09 07:10 PM
11/04/09 07:10 PM
Built right and used in the proper application and installed correctly you should not have issues.We have used the pushrods from Indy for 10 years and can only remember one bad set for a small block and can count the number of cup issues on one hand.Most the problems that occurred were caused by geometry and oiling issues.If your building a engine with big demands then you should use top quality custom valve train part and not over the counter kit pieces.Like rockers,springs,retainers,valves and locks don't cheap out on the pushrods.
my 500 ci indy motor has had 0 issues with indy pushrods.this motor is not on kill but very respectable at 715 hp.
[Re: B G Racing]
#462361
11/04/09 07:10 PM
11/04/09 07:10 PM
mikeysmopars
fresno ca
Are you saying Indy is cheap over the counter pieces? It all came from Indy. I didn't cut any corners. I also have a little inside info on this issue and it is definatly a failure problem. watch for changes in early 2010.
[Re: mikeysmopars]
#462362
11/04/09 07:19 PM
11/04/09 07:19 PM
Posts: 882 ky
68roadrunner
ky
dont feel alone there is more of us in the same boat with you.
[Re: mikeysmopars]
#462363
11/04/09 07:52 PM
11/04/09 07:52 PM
Posts: 1,288 Oregon
sg66mopar
I broke two that popped the cups right off the end. I bought the whole 295 ez c&c kit with 620 comp cam, Over $4k! Indy will not help anyone with it but I did talk to Manton today about this very issue. The person I talked to said Indy knows they have a problem and are in the process of changing the rockers and pushrods. They also said when indy does thier own engines they use MANTON pushrods.Its definatly disgusting spending "Indy Money" Making 7 runs and only 5 all the way through. My Advise, If your looking into buying an Indy Head Kit, Get the heads and Heads only!
I got 4 runs before losing a pushrod cup on my Indy setup. I had them in my little motor on a .610 lift, flat tappet cam with only 480 lbs. open pressure. Also split a rocker in two @ about 200 runs. It would be nice if Indy and their dealers would man up and tell their customers we are buying "cheap over the counter parts". Nobody mentioned anything like that until after the fact.
Smith Brothers are now in my motor!
[Re: sg66mopar]
#462365
11/05/09 06:36 AM
11/05/09 06:36 AM
Posts: 317 Indiana
79_W200
Indiana
I bought an assembled set from Indy and ran them all season, checked valve lash and never needed reset. I am running a roller with .715 lift at 7000-7500 rpms, and 600 lbs open
1979 W200 470
[Re: mikeysmopars]
#462366
11/05/09 08:30 AM
11/05/09 08:30 AM
Posts: 9,910 Eighty Four, PA
B G Racing
Eighty Four, PA
Are you saying Indy is cheap over the counter pieces? Those are your words not mine.Indy puts to gether a basic quality and affordable kit and when used properly and in the proper application is very reliable,this can be attest to by the hundereds of engines that we have built and the many BGR racers that are quite successfull.Indy offers many upgrades as far componants and the customer or their builder must make the determination as to what level of reliability is needed and what parts(quality) are needed.The information is readly available from the many good venders and builders here on this sight and others.Example ie: you wouldn't use Dove rockers on a 800 lift cam with 900lb spring pressure.At some point people have to rely on common sence and get good advise as the first step in building anything,race oriented or otherwise.A good game plan before spending dollars,a well organized plan with specific goals,and a well executed plan will usually be successfull.
[Re: sg66mopar]
#462367
11/05/09 08:48 AM
11/05/09 08:48 AM
B G Racing
Eighty Four, PA
BTW Barnyard Bob, didn't mean to step on any toes here. Sounds to me like you're one of the good guys, but no all of Indy's dealers want to spend much time with their customers. Just get the sale and get off the phone so they can go racing.
Your not stepping on anyone toes here.We are more of a engine/race car building shop and not a parts retail shop.90% of our stuff is used in our builds that we stand behind.As I have said many times we are not here to sell anyone anything,we are here to share our experience and knowledge and gain the same from others who do likewise.To construe my comment "don't cheap out" was not saying anyones product is cheap ie: go to AutoZone and you can by their brand of ball joint or the more expensive Moog ball joint.They will both serve the purpose,which will last longer?There is an inherient cost for top quality and realiability,your choise,Crane or Jesel.I just finished a set of pushrods for a member here that had Smiths pushrods that all bent,Smths sold him 5/16 rods for a wedge with 300# seat,go figure?Great pushrods,wrong application
[Re: webemopes]
#462369
11/05/09 11:51 AM
11/05/09 11:51 AM
Posts: 10,157 Frostbitefalls MN (Rocky&Bullw...
gregsdart
I have run the Indy pushrods for a long time, no troubles. And these were the cut to length type, put together in my shop. Clearly the materials are not at fault, as they survived a .775 roller running 947 springs. That was ball to ball on both ends. So the only differance might be at the adjuster end. So I wouldn't be too quick to blame materials, just assembly or other valve train problems, like springs.
[Re: B1Fish540]
#462371
11/05/09 02:14 PM
11/05/09 02:14 PM
B G Racing
Eighty Four, PA
I remember a while back everybody was having adjusters break(including me). The cause was apparently a batch that was not heat treated properly. I dont think Crane ever admitted it but everybody was getting them from the same vendor. Could be a simialr problem with the push rods.
Same here,we had HS adjusters breaking at idle.Watched them with the valve covers off.They were light grey in color we replaced them with a new dark black and no more problems.
[Re: mikeysmopars]
#462374
11/05/09 03:03 PM
11/05/09 03:03 PM
Posts: 882 ky
68roadrunner
ky
Several of mine look exactly like that. The others are missing the cup!
that is when i found these, when a cup snapped off at idle. but to be fair, i didn't build these properly. now i find that out
[Re: 68roadrunner]
#462375
11/05/09 03:17 PM
11/05/09 03:17 PM
mikeysmopars
fresno ca
After fitting mine with the adjuster I took them to a machine shop and they were chucked in lathe & cut, champhered, Chucked in some kind of round hole vise and then pressed in the ends. I can't immagine anything wrong with that. Had I of chopsawed them and hammered them I could aim the problem at me but I followed through the right way.???
