Page 14 of 127 1 2 12 13 14 15 16 126 127
Re: Big block Ramchargers & Trail Dusters [Re: smokn440] #4608
07/25/04 09:42 PM
07/25/04 09:42 PM
Hawaii
smokn440 Offline
super street
smokn440  Offline
super street
Hawaii
aweful quiet in here lately
Re: Big block Ramchargers & Trail Dusters [Re: smokn440] #4609
07/26/04 12:22 AM
07/26/04 12:22 AM
Rosedale B.C Canada.. Eh
Fargo Freek Offline
super gas
Fargo Freek  Offline
super gas
Ya for a while there I was sure that there was some kinda love fest going on
I was the Black Warlock but now Iam the Fargo Freek 1950 plymouth fast back (custom) 1951 Fargo spring special 1996 Dodge 1500 Pu 2008 Magnum AWD The way I see it is If It doesn,t say MOPAR then what else is there. E Mail me @ nascar2000@telus.net
Re: Big block Ramchargers & Trail Dusters [Re: Fargo Freek] #4610
07/26/04 12:50 AM
07/26/04 12:50 AM
Hartselle AL
67MIke Offline
67MIke  Offline
Hartselle AL
Hey rico, I guy (macario) on ramcharger central has a 2wd 440 rc for sale still, I think
BTW has/ does anyone know if 600 cfm carb will run on a stock 440, I have 750 but me thinks it's a little strong for it. thanks
Re: Big block Ramchargers & Trail Dusters [Re: 67MIke] #4611
07/26/04 12:12 PM
07/26/04 12:12 PM
Dowell, IL
MrRico Offline
super gas
MrRico  Offline
super gas
Dowell, IL
Thank you 67mike, I will try and find out.
Re: Big block Ramchargers & Trail Dusters [Re: smokn440] #4612
07/26/04 09:38 PM
07/26/04 09:38 PM
Lebanon ,PA in the Susquehanna...
70Challengerse Offline OP
SMOKIN,If you answer your e-mails alittle more often,you wouldn't be saying that,did you even talk to Sam , about those bumper brackets,he has them, or are you spending to much time on that new KIDDY truck site , lol,now I forgot,what would you like to talk about,and NO black warlock ,not YET a love fest.lol,By the way I'm on the phone with Sam,he's is waiting for that e-mail about the brackets, DAMIT!
Re: Big block Ramchargers & Trail Dusters [Re: 70Challengerse] #4613
07/26/04 09:55 PM
07/26/04 09:55 PM
By the way, Larry Haga where are you,you seemed to drop out of existense!mspl
Re: Big block Ramchargers & Trail Dusters [Re: 70Challengerse] #4614
07/26/04 11:01 PM
07/26/04 11:01 PM
Hawaii
smokn440 Offline
super street
smokn440  Offline
super street
Hawaii
ouch Ric ,,,go easy on me,,,,I check this site every time I'm online,,and I always answer my e-mails...and I had no idea Sam has A pair or I would have bought them already,,,,,,,but I did get my truck legal today,,,just a matter of gettn the rear bumber on now
No oil pressure in the 440 today!!!!!!! [Re: smokn440] #4615
08/01/04 12:43 AM
08/01/04 12:43 AM
Dowell, IL
MrRico Offline
super gas
MrRico  Offline
super gas
Dowell, IL
MAN! I fired up the truck this afternoon, let it warn a bit and made a few passes up and down the road, pulled it back in and drained out the oil. Toped it off with new and refired the 440 and the oil PSI never came back up. Something is weird here, the shaft did not twist off, and it is full of oil, so I figure, must be the pump. The local parts guys in the area ( A-Zone, O'Reilly's Napa, All pro ) all said that a 440 oil pump will be special order. That will take a week or more! How about that for luck.
Re: No oil pressure in the 440 today!!!!!!! [Re: MrRico] #4616
08/01/04 07:38 PM
08/01/04 07:38 PM
Dowell, IL
MrRico Offline
super gas
MrRico  Offline
super gas
Dowell, IL
Boom! The 440 is OK! 100 psi, Never had that before. Weird that the pump stoped when I changed the oil, I got a used pump from a 400 I have in storage. This will do untill the new one comes in.
Re: No oil pressure in the 440 today!!!!!!! [Re: MrRico] #4617
08/04/04 09:58 PM
08/04/04 09:58 PM
Hawley, Texas
shinnery Offline
super street
shinnery  Offline
super street
Hawley, Texas
Look in the pump you pulled off. Specially the relief valve. If you got something that blocked the valve open it will not prime and build oil pressure the next time you try to run it. My brother had a 383 that parts of the nylon cam gear did that to a couple of times. That relief valve is what determines your oil pressure so your new one must have a stiff spring.
Bryce
Every electronic device is manufactured with smoke stored deep inside... only a true genius can find a way to set it free. The most terrifying words in the English language are: "I'm from the government and I am here to help!"
Re: No oil pressure in the 440 today!!!!!!! [Re: shinnery] #4618
08/05/04 12:18 AM
08/05/04 12:18 AM
Dowell, IL
MrRico Offline
super gas
MrRico  Offline
super gas
Dowell, IL
Ok, I will look when I have chance. I will let you know.
thanks Mr. Rico
Re: No oil pressure in the 440 today!!!!!!! [Re: MrRico] #4619
08/06/04 08:48 PM
08/06/04 08:48 PM
CA, Proprietor; The "PALOMINO"...
dynotune440 Offline
dynotune440  Offline
I agree, it must have something in the releif spring causing it to dead head the pump (full presure)
Dinuba, California, Home of the PALOMINO ranch and 440 truck farm, where dodge trucks have a home. Have Four 1979 dodge PALOMINO trucks now.
Re: No oil pressure in the 440 today!!!!!!! [Re: dynotune440] #4620
08/09/04 02:14 PM
08/09/04 02:14 PM
Dowell, IL
MrRico Offline
super gas
MrRico  Offline
super gas
Dowell, IL
Well I took the pump apart and I did not find anything obvious. I geuss that the trash could have been knocked out in the past week that it has been laying around. The spring is intack, I don't know if it is worn out but nothing in it and it is not broken. The new pump is on and working great so I will just have to be happy nothing went terribly wrong. Thanks guys!
Re: No oil pressure in the 440 today!!!!!!! [Re: MrRico] #4621
08/10/04 09:52 PM
08/10/04 09:52 PM
Well, I'm glad the oil pump worked,still hard to beleive that was the problem,and can't believe you waited that long for a pump?And also smokin you are right,, there is no chatter!!!!!!!!!!!!
Re: No oil pressure in the 440 today!!!!!!! [Re: 70Challengerse] #4622
08/15/04 03:22 PM
08/15/04 03:22 PM
Texas
garye Offline
garye  Offline
Texas
Glad you got the pump going. scary wasn't it. I dont know how to start a new message goody but I promised a picture a while back and her it is.
Re: No oil pressure in the 440 today!!!!!!! [Re: garye] #4623
08/15/04 04:15 PM
08/15/04 04:15 PM
Niiccce truck, fuzzy but very nice , still can't wait til our garage is up! have so much I could be doing,
Re: No oil pressure in the 440 today!!!!!!! [Re: 70Challengerse] #4624
08/16/04 01:36 AM
08/16/04 01:36 AM
Texas
garye Offline
garye  Offline
Texas
Sorry about fuzzyness ,. Cheapie camera , the kind you take the camera back to store and they develope.
not much of a flash on those cameras and the truck is black. would be better if i could roll it outside. Can you stand another pic?
Re: No oil pressure in the 440 today!!!!!!! [Re: garye] #4625
08/16/04 01:39 AM
08/16/04 01:39 AM
dynotune440 Offline
dynotune440  Offline
send away!! it's not that bad, it could be worse, it could be a furd or chebbie......lol.
Re: No oil pressure in the 440 today!!!!!!! [Re: dynotune440] #4626
08/16/04 02:06 AM
08/16/04 02:06 AM
Texas
garye Offline
garye  Offline
Texas
this shows a little better.
440 Trucks - Show us your cool trucks! [Re: garye] #4627
08/16/04 09:23 AM
08/16/04 09:23 AM
Dowell, IL
MrRico Offline
super gas
MrRico  Offline
super gas
Dowell, IL
garye, nice truck, here is a picture of my 440
