Fluctuating Timing 340 W/MP eclectronic #460374
09/05/09 09:40 PM
09/05/09 09:40 PM
MA
ragtop Offline OP
ragtop  Offline OP
MA
I have a 340 with the Mopar electronic ignition. I went to set up the timing at 35 degrees total without vacuum advance, and noticed that when it got to 35 degrees at 2200 RPM, the timing was moving around between 35 and 40 degrees. Could this be my timing light or my ignition? Thanks.
Re: Fluctuating Timing 340 W/MP eclectronic [Re: ragtop] #460375
09/05/09 09:59 PM
09/05/09 09:59 PM
Willoughby Hills, Ohio
gd9704 Offline
super gas
gd9704  Offline
super gas
How many miles on the timing chain? Worn distributor, perhaps?
Re: Fluctuating Timing 340 W/MP eclectronic [Re: gd9704] #460376
09/05/09 10:08 PM
09/05/09 10:08 PM
BDW Offline
BDW  Offline
Re: Fluctuating Timing 340 W/MP eclectronic [Re: BDW] #460377
09/05/09 10:33 PM
09/05/09 10:33 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Had a similar problem with my old 64 300, the dual point distributor was all wore out. A new distributor fixed that.
But it could be a few other things. I'd check for chain slop. Never had to use a collar to get steady timing.
Don't be the exception.
Re: Fluctuating Timing 340 W/MP eclectronic [Re: Supercuda] #460378
09/05/09 11:22 PM
09/05/09 11:22 PM
timing gears/chain or needing a collar on the dist shaft or both.
Re: Fluctuating Timing 340 W/MP eclectronic [Re: ragtop] #460379
09/06/09 07:53 AM
09/06/09 07:53 AM
Hamburg, Pa.
72 RR DUDE Offline
72 RR DUDE  Offline
Hamburg, Pa.
I just went thru this with my 440 for over a year. This is what I found. The gap at the reluctor way like 18 thousands and the thing had two very lite springs in the dist. which was causing it to advance way to soon. Left one light spring in and put one heavier one in and set the reluctor at 8 thousands and the timing and idle is great.
Thanks Moparts
