Re: 72 challenger 340 no spark issue!
[Re: menomoniemopars]
#459959
09/08/09 09:35 AM
09/08/09 09:35 AM
RapidRobert
Go onto the "tech archives" at the top of the page then click on "electrical topics" then click on "awesome ecu wiring diagram" & they have a comprehensive schematic that will help you better than I can explain it but the yellow wire on the diagram is wrong, you run that yellow wire from the (st) terminal on the ign sw out to the starter relay and it does not connect to the ballast.
[Re: RapidRobert]
#459960
09/08/09 10:04 AM
09/08/09 10:04 AM
Posts: 69 Menomonie,wi
menomoniemopars
Menomonie,wi
So Is that the same yellow that is all melted coming out of my harness bulkhead then? just make a new one off that connector and reconnect to ign terminal on relay where it was?
#459962
09/09/09 02:45 PM
09/09/09 02:45 PM
RapidRobert
on the male terminals one end will compress & one wont & you slightly compress the one that will move just slightly then it will come out the back side easily. The female ones look at the rectangular hole and on one side there is a mini groove & use an eyeglass screwdriver to go in & depress the tab then pull it out the back side also.
#459964
09/13/09 12:25 PM
09/13/09 12:25 PM
menomoniemopars
Menomonie,wi
well went back and worked on the car and I got it running but I found some cluster crap in harness, and I have included a pic of what someone did.. can u guys take a look and see what they did is ok? tx! Its running ,but need to tweak rotor placement etc now and then go from there..
[Re: 440challenger]
#459968
09/15/09 08:48 AM
09/15/09 08:48 AM
menomoniemopars
Menomonie,wi
Swap in a known good working distributor. My friends 440 was doing the same exact thing. The Pickup in his reman distributor came loose.
This is a brand new dist tho..
#459972
09/23/09 07:22 AM
09/23/09 07:22 AM
menomoniemopars
Menomonie,wi
We'll I think this Damn thing is useless at this point! it still will not run very well! I have it at 30 initial now just so it will run! Unknown on cam specs etc, And to top it off there is a damn knock somewhere in this motor! its towards the center sounds like? it doesnt go away when u rev it a little, i pulled all but the last two plug wires on drivers side as there a bitc* with headers and it didnt go away. so thinking no rod bearing. could be a main? or what else do u guys think? this motor was suppose to have been all rebuilt too! But after everything i have seen so far with the seller i wouldn't doubt he put used fricken bearings back in!! also when i pulled the drivers side valve cover to make sure both valves were closed At TDC I seen this on a couple of pushrods. this is the worse one u can literally feel a nice deep groove in it! where did that come from? I watched it roll over and it doesn't even come close to hitting way up ther ein the pushrod hole. Also how close should the pushrod be when valve is closed to that hole? cause its very close! p.s Is there anyone close to me that can come look at this for me? thanks!!
