Page 2 of 3 1 2 3
Re: New Rear Gear Pattern **New Photos** [Re: justinp61] #459491
09/05/09 08:41 PM
09/05/09 08:41 PM
Detroit, MI
CokeBottleKid Offline
Detroit, MI
more
Re: New Rear Gear Pattern **New Photos** [Re: justinp61] #459492
09/05/09 08:48 PM
09/05/09 08:48 PM
On the south side of Nowhere
S/ST 3040 Offline
S/ST 3040  Offline
Are you getting paid by the hour?
I'm just kidding..............010" more.
Re: New Rear Gear Pattern **New Photos** [Re: S/ST 3040] #459493
09/05/09 08:51 PM
09/05/09 08:51 PM
W. Kentucky
justinp61 Offline OP
W. Kentucky
The labor is the cheapest thing on this job.
Re: New Rear Gear Pattern **New Photos** [Re: justinp61] #459494
09/05/09 08:54 PM
09/05/09 08:54 PM
Rather be in Fallon, Nevada
RussW Offline
super gas
RussW  Offline
super gas
Yer almost there
Re: New Rear Gear Pattern **New Photos** [Re: justinp61] #459495
09/05/09 08:55 PM
09/05/09 08:55 PM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
Yep, try 0.010" more.
You should be getting close.
Re: New Rear Gear Pattern **New Photos** [Re: DoctorDiff] #459496
09/05/09 09:11 PM
09/05/09 09:11 PM
Lubbock,TX
DavidDean Offline
DavidDean  Offline
Lubbock,TX
Keeper,thanks!
Re: New Rear Gear Pattern **New Photos** [Re: DavidDean] #459497
09/05/09 09:34 PM
09/05/09 09:34 PM
W. Kentucky
W. Kentucky
Tomorrow is a new day . Before church I'll pull it apart and go again. Some of you know I broke the previous gear set. When I tore it down I found some interesting stuff. The (chevy) guy who set it up runs a repair shop and some very fast nitrous cars, low 5s, high 4s in the 1/8 mile. The rear pinion bearing had been clearenced with a burr and would slide on and off the pinion with no resistance. The pinion showed signs of movement in the rear bearing, also and the pinion depth shims were crushed to the point one was in two pieces and another was broken, all were distorted. This is why I'm learning to do it myself.
Thanks guys for you're patience and advice .
Re: New Rear Gear Pattern **New Photos** [Re: justinp61] #459498
09/06/09 01:28 AM
09/06/09 01:28 AM
ky
68roadrunner Offline
ky
i think i still have my set up bearings somewhere. you should have yelled to use them. your welcome to them
Re: New Rear Gear Pattern **New Photos** [Re: 68roadrunner] #459499
09/06/09 08:14 AM
09/06/09 08:14 AM
W. Kentucky
W. Kentucky
Thanks . Hopefully I'm almost there.
Re: New Rear Gear Pattern **New Photos** [Re: justinp61] #459500
09/06/09 09:39 AM
09/06/09 09:39 AM
Ohio
theclutcher Offline
theclutcher  Offline
Ohio
What pinion setter you using?
that far off from initial indication?
calibration or cleanliness issue on initial reading?
A bit agravating to redo many times but its good learning process, looking close to good.
Re: New Rear Gear Pattern **New Photos** [Re: theclutcher] #459501
09/06/09 05:49 PM
09/06/09 05:49 PM
W. Kentucky
W. Kentucky
SOS different day.
Re: New Rear Gear Pattern **New Photos** [Re: justinp61] #459502
09/06/09 05:50 PM
09/06/09 05:50 PM
W. Kentucky
W. Kentucky
Another.
Re: New Rear Gear Pattern **New Photos** [Re: justinp61] #459503
09/06/09 05:50 PM
09/06/09 05:50 PM
Lehigh Acres, Florida
rickstershemi Offline
Rickster
Re: New Rear Gear Pattern **New Photos** [Re: rickstershemi] #459504
09/06/09 05:52 PM
09/06/09 05:52 PM
S/ST 3040 Offline
S/ST 3040  Offline
Re: New Rear Gear Pattern **New Photos** [Re: S/ST 3040] #459505
09/06/09 06:09 PM
09/06/09 06:09 PM
ky
ky
that should work, pull and coast sides back to back , and slightly to the inside.
lets see if you can break it again.
Re: New Rear Gear Pattern **New Photos** [Re: justinp61] #459506
09/06/09 08:20 PM
09/06/09 08:20 PM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
I would decrease shim pack thickness 0.003".
Re: New Rear Gear Pattern **New Photos** [Re: DoctorDiff] #459507
09/06/09 09:45 PM
09/06/09 09:45 PM
RussW Offline
super gas
RussW  Offline
super gas
Re: New Rear Gear Pattern **New Photos** [Re: DoctorDiff] #459508
09/06/09 10:38 PM
09/06/09 10:38 PM
W. Kentucky
W. Kentucky
You're killing me Cass .
Thanks, Justin
Re: New Rear Gear Pattern **New Photos** [Re: justinp61] #459509
09/07/09 11:50 AM
09/07/09 11:50 AM
W. Kentucky
W. Kentucky
Just for you Cass , .003 out.
Re: New Rear Gear Pattern **New Photos** [Re: justinp61] #459510
09/07/09 11:51 AM
09/07/09 11:51 AM
W. Kentucky
W. Kentucky
Drive.
Page 2 of 3 1 2 3
