Re: New Rear Gear Pattern **New Photos**
[Re: S/ST 3040]
#459493
09/05/09 09:51 PM
09/05/09 09:51 PM
Posts: 11,689 W. Kentucky
justinp61
W. Kentucky
Are you getting paid by the hour?
The labor is the cheapest thing on this job.
[Re: DavidDean]
#459497
09/05/09 10:34 PM
09/05/09 10:34 PM
justinp61
W. Kentucky
Tomorrow is a new day ![](/ubbthreads/images/graemlins/thumbs.gif) . Before church I'll pull it apart and go again. Some of you know I broke the previous gear set. When I tore it down I found some interesting stuff. The (chevy) guy who set it up runs a repair shop and some very fast nitrous cars, low 5s, high 4s in the 1/8 mile. The rear pinion bearing had been clearenced with a burr and would slide on and off the pinion with no resistance. The pinion showed signs of movement in the rear bearing, also and the pinion depth shims were crushed to the point one was in two pieces and another was broken, all were distorted. This is why I'm learning to do it myself. Thanks guys for you're patience and advice ![](/ubbthreads/images/graemlins/thumbs.gif) .
[Re: 68roadrunner]
#459499
09/06/09 09:14 AM
09/06/09 09:14 AM
justinp61
W. Kentucky
i think i still have my set up bearings somewhere. you should have yelled to use them. your welcome to them
Thanks . Hopefully I'm almost there.
[Re: S/ST 3040]
#459505
09/06/09 07:09 PM
09/06/09 07:09 PM
Posts: 877 ky
68roadrunner
ky
[Re: DoctorDiff]
#459508
09/06/09 11:38 PM
09/06/09 11:38 PM
justinp61
W. Kentucky
I would decrease shim pack thickness 0.003".
You're killing me Cass .
Thanks, Justin
