Re: E body frame rail splash shield [Re: anlauto] #455414
09/03/09 10:06 AM
09/03/09 10:06 AM
cataclysm80 Offline OP
Heat shields 3 each
Starter splash shield 4 ?
K frame shields 2 each
Rear axle rebound bumpers 2 each
I count 16
Yes, the Starter splash shield uses 4
Did the K frame shields ever use these screws? I thought they always had rivets. I think the holes in the frame are a different size.
What are the heat shields you guys are referring to?
Tav
Re: E body frame rail splash shield [Re: anlauto] #455415
09/03/09 10:06 AM
09/03/09 10:06 AM
ILL
MLR426 Offline
MLR426  Offline
ILL
Heat shields 3 each
I count 16
2 on each on front splash shield or ? 4
Axle rebound bumpers take captive washer 1/4-20 bolts (4)
Mine is 4 spd no spash shield.
Rear heat shields should take 1 each on front due to rear
portion of the heat shield attached to the tip hangers ?
So I would think total of 6 for 4 spd car and 10 for auto car.
Bill, Get ready to take an order.
logan426
Re: E body frame rail splash shield [Re: MLR426] #455416
09/03/09 10:38 AM
09/03/09 10:38 AM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Heat shields 3 each
I count 16
logan426
the 2 smaller K-frame sheilds USUALLY take rivets, but I've seen nunerous used shields where the plastic was damaged due to a bolt turning and digging into them.
rear muffler shields take 3 each I believe.
1 on the front and 2 along the side where they bolt to the side of the frame rail. rear is tucked under the muffler hanger to trunk floor brackets
Re: E body frame rail splash shield [Re: MLR426] #455417
09/03/09 10:40 AM
09/03/09 10:40 AM
Georgetown Ontario Canada
anlauto Offline
anlauto  Offline
Heat shields 3 each
I count 16
logan426
I don't agree....The rebound bumbers never used a 1/4 20 bolt, there would have to be nuts welded inside the frame rail which there isn't.
The muffler heat shield require 3 each AND the rear muffler hanger....I guess you could omit the two that go into each frame rail if you're into rattles
Most 72-74 cars that I've restored used the screws on the K frame shields, but recently I've been finding pop rivits on the 70's I've been working on. I believe 71 would be the change over year.
I'm sticking with my first count.
CHECK OUT MY NEW WEB SITE !
Re: E body frame rail splash shield [Re: gtx6970] #455418
09/03/09 10:58 AM
09/03/09 10:58 AM
ILL
MLR426 Offline
MLR426  Offline
ILL
I guess I'm totally screwed up with this
I just removed some clean ones and they were
1/4-20 captive washer on both cars.
Self tapping 1/4-20 screws don't need a welded nut in the frame to hold tight.
So we need (10 for a 4 spd car and 14 for automatic.
logan426
Re: E body frame rail splash shield [Re: anlauto] #455419
09/03/09 11:01 AM
09/03/09 11:01 AM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
What are the K frame sheilds your talking about? Do you have a pic? I'm drawing a blank for some reason on those.
Re: E body frame rail splash shield [Re: burdar] #455420
09/03/09 11:08 AM
09/03/09 11:08 AM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
http://amhightechauto.com/images/parts/Q668-9.jpg
http://amhightechauto.com/images/parts/G39.jpg
Re: E body frame rail splash shield [Re: burdar] #455421
09/03/09 11:10 AM
09/03/09 11:10 AM
ILL
MLR426 Offline
MLR426  Offline
ILL
Shields that mount on the bottom side of the frame on both side in front of the engine but behind the radiator. They shield water from the fan and engine.
logan426
Re: E body frame rail splash shield [Re: cataclysm80] #455422
09/03/09 11:47 AM
09/03/09 11:47 AM
Oh, the muffler heat shields. I'm working on a T/A clone and they don't use those shields.
You can check your frame to see if your car used screws or rivets for the K frame splash shields. Mine used rivets, but if it were screws the hole would be stretched a little and I'd be able to see the cut threads like I can with the starter shield.
Tav
Re: E body frame rail splash shield [Re: cataclysm80] #455423
09/03/09 02:18 PM
09/03/09 02:18 PM
anlauto Offline
anlauto  Offline
Just buy them in bulk...50 or 100 at a time, that's what I do
