Re: Why does my car stumble in the air?
[Re: 572_dup2]
#454597
08/30/09 08:55 PM
08/30/09 08:55 PM
Best 60's ever all 1.28s. Got the bump stops set as tight as im gunna set them. Leaves the best around 2000rpm. Sounds like an feels like its starved for fuel right before 2nd an then after i shift it takes it a little time to recover. I have video i will show as soon as the get it to me.
had the same problem today, my car was leaving hard and pulling up the frontend causing my jets to be uncovered causing a lean condition. i raised my floats up on both carbs a bunch with a drill bit and problem solved. got my best et ever in bad air. dont touch your fuel psi, thats not your problem.
#454598
08/30/09 09:00 PM
08/30/09 09:00 PM
jet extentions wont help with sideways carbs.
#454599
08/30/09 09:21 PM
08/30/09 09:21 PM
Posts: 52,972 Romeo MI
MR_P_BODY
A set of 90% bent tubes would so the ends are at the rear of the carb(what is the rear now)... might be able to use a short piece of fuel hose to connect them to the jets.... I'd do all of the jets to make sure they are all getting fuel. This should work for a test and if it corrects the problem then I'd make up something that would be a little more permanent. Also the comment of being slower in high gear... it could be a air issue... put a air pan on first that may knock out some of the hot air thats up in the cowl(thats where its trying to escape to)
[Re: hemi-itis]
#454602
08/30/09 09:39 PM
08/30/09 09:39 PM
MR_P_BODY
To eliminate the hood as an issue,make a pass without the hood on
I believe he did(in his hood post) and really slowed
[Re: hemi-itis]
#454603
08/30/09 09:41 PM
08/30/09 09:41 PM
Posts: 4,055 Salina ks
572_dup2
Back On The Bumper!!
Salina ks
slowed down when i took the hood off.
Shawn Jennings
[Re: 572_dup2]
#454604
08/30/09 09:55 PM
08/30/09 09:55 PM
MR_P_BODY
Shawn, you might want to try larger needle and seats on the carbs(might need to go to the alky seats for more flow
[Re: Chris'sBarracuda]
#454609
08/30/09 11:50 PM
08/30/09 11:50 PM
Posts: 307 OH
TheBlackCar
OH
The first thing I would do is make a pass with the hood off..
Chris..
Taking the hood off of something fast usually has a negative affect because fuel is pulled out of carb and ends up on the windshield. Not to mention what it does to the air...
#454610
08/31/09 07:31 AM
08/31/09 07:31 AM
Posts: 10,082 Frostbitefalls MN (Rocky&Bullw...
gregsdart
They will if they are made to draw from further back in the bowl, and that was my idea, and I believe Als as well. It would take some custom work, as they would need to be flattened a little to allow for ending in the middle of the bowl instead of straight out from the jet. A little tubing, a torch, a (small!)hammer, and problem solved.
8.582, 160.18 mph best, 2905 lbs 549, indy 572-13, alky
Post deleted by Defbob
[Re: Al_Alguire]
#454612
08/31/09 11:23 AM
08/31/09 11:23 AM
[Re: gregsdart]
#454614
08/31/09 01:09 PM
08/31/09 01:09 PM
[Re: DJVCuda]
#454616
08/31/09 01:24 PM
08/31/09 01:24 PM
