Re: 7 second street C-body on DOT tires? [Re: mopar383] #454531
08/30/09 11:52 PM
08/30/09 11:52 PM
Considering the speed and ET, and not counting the rear tires, that thing almost qualifies as a sleeper!!
Re: 7 second street C-body on DOT tires? #454532
08/31/09 07:46 AM
08/31/09 07:46 AM
an8sec70cuda Offline
Simply awesome! Congrats on the 7 sec slip!! CHIP
CHIP
'06 GMC 2500HD LBZ Duramax
Re: 7 second street C-body on DOT tires? [Re: an8sec70cuda] #454533
08/31/09 07:55 AM
08/31/09 07:55 AM
Netherlands
72Challenger Offline
Netherlands
Congrats again!! Simply unreal, a 7sec slip with that kind of a car.
When are you gonna bring it over to make some passes over here so I can see it in person
Re: 7 second street C-body on DOT tires? [Re: 72Challenger] #454534
08/31/09 09:28 AM
08/31/09 09:28 AM
Finalnd, Perkele
jyrki Offline OP
jyrki  Offline OP
Finalnd, Perkele
Thanks for the compliments, here is a longer story with links to some pics. I'll put a video of the run to youtube if I get one.
The race started on friday evening, according to the schedule at 4 pm. I left work early and drove the 100 miles to the track, was there at 3.30 pm. Took all the stuff out and drove to the tech. pic1 Everything was ok, except that I had forgotten my helmet to the pits. When I drove back to get it, they already collected street cars to the line up, so had a little hurry. Got there in time and realized that I hadn't lowered the tire pressures and the chute was still unpacked. I was in the race alone, but got a little help from the neighbours to pack the chute.
As you propably know, we had huge problems with the driveability of the car before the race and only a day before after checking and changing a lot of stuff I noticed a loose axle tube from the Danas center section. Got that reapaired and thought the car worked like a charm again.
The weather on friday evening was weird, no wind and very low pressure, after the burn out the smoke just stayed and stayed there and messed the timers and visibility. pic2
After permitted to stage I messed up everything; didn't remeber to put the trans brake on etc. etc. I left the line at 5 psi with a hole shot style RT of 8.5 seconds. The ET was 2.75 seconds. The timers were a bit messed up. Lost the traction immediately after launch and just accelerated lightly, some 150 ft before the traps I pressed the gas pedal deeper and the shift light immediately came on. Like Finnish rallye drivers say; dö roud wos veri sliperi! Speed was ok at 160 mph and the car went straight while spinning, so there was hope for better. 160 mph ok; two years ago I would have given everything I have for that kind of speed! Before the run I hadn't had any time to concentrate and did about everything wrong.
The next run was very late in the evening, the track seemed good now after one complete round, but just in front of me a car broke and it took very long to get it off the track. Basically they had to carry it off. Meanwhile my engine temp got so low, that in the burn out the engine didn't pick rpm, "low temp rpm limiter" was still on. So I took the launch very carefully, still only 5 psi of boost, and the car lifted front end and pulled to the right strong. Every time I pressed the gas pedal it lifted front tires and went right; 9.9 sec at 130 mph. This pic is taken at approxiamtely 400 ft pic3
That was all for the day, and I was pretty hopeless. Went to the bar for a few beers, and actually didn't get back until 5 am to the pits to get a few hours of sleep. When I woke up it rained heavily, I had had time to think about the situation, and realized that the stiffer rear springs and therefore raised rear chassis height was propably part of the problem. The possibilities were either lower the rear or change link positions; didn't want to do the latter alone and without a suspension map. So, I spent the morning walking around the pits asking if anyone had lower rate extra coil over springs with them.
Finally found one set of 110 lbs springs. The ones I had were 175's, and the lowest and the last ones I had used before were 125's. I intended to get them with me to the track, but in the hurry I forgot to put them in to the trunk. The first thing anyone should do at the track is to check that you've got all the needed equipment with you, because teh ones you forgot will most likely fail! Mounted the new springs with some preload, and weighed the car. Didn't like the corner weights at all, pic4 so I changed them radically with adjusting the torsion bars and preloads.
Next run, I decided to try a little more boost in the launch, eight psi. So, after staging and seeing the yellow I stepped on the throttle and watched the boost gauge, wehn it was at 8 psi I realesed teh trans brake. The launch really wasn't a "kick", but still good, after about one ft or so it started to pull very well. pic5 Shift at 7100 and ready to open the chute. Hadn't done that for a couple of months and since it had been packed for a day and in the heavy rain I actually wondered wether it would open at all. And where once again was the chute handle, had to look at the roof and put my hand on the handle, then look forward again; still going towards the traps! Just before the traps I opened the chute and it started slowing the car down pretty much at the right moment.
After turning to the return road I stopped, left the car idling and put the chute in to the trunk while wondering the ET, thought that because of no initial hit it was propably some 8.2-8.3. On the tech point and return road everyone was showing thumbs up, and the trend continued at the pits, so I started to wonder..., then when I stopped the car there was people congratulating all around, and I finally got to know I had run the first 7 sec ET ever in Finland in street car classes.
The guy I had borrowed the rear springs from needed them back, so I immediately decided I wouldn't drive in the eliminations on Sunday. The car was still in one piece and everything was fine, so it was time for some celebration.... pic6
Mechanically this summer has been very easy. Only some valvetrain problems in teh first race, but after that only checked valve lashes a few times adn installed new spark plugs when the car becomes hard to start. It runs so rich cold, that it occasionally kills plugs. The max boost was 20 psi; the current turbos have been run succesfully at 25 psi, so still got some steam left. 60 ft was 1.268, 330 3.371, 660 5.106/142 mph, 1000ft 6.611 and the final ET 7.89/ 174+. Last 0.4 seconds were against the 7500 rpm rew limiter.
Next winter I will install wheelie bars and an anti roll bar, but proapbly leave the engine and trans the way they are. Only wish I have time to take the engine to the dyno to really get it sroted out, now it's stille pretty much untuned only having tuned it leaner, and changed the boost, but never changed for example the timing. We are still about 300 lbs overweight for our class, so might do something to that too.
Plynouth VIP '67 TT IC EFI
Re: 7 second street C-body on DOT tires? [Re: jyrki] #454535
08/31/09 04:00 PM
08/31/09 04:00 PM
North Sweden
RT540 Offline
RT540  Offline
North Sweden
Good job
Re: 7 second street C-body on DOT tires? [Re: RT540] #454536
08/31/09 04:08 PM
08/31/09 04:08 PM
Renton Washington
Triple Threat Offline
Renton Washington
Very cool, congrats on reaching another goal.
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: 7 second street C-body on DOT tires? [Re: Triple Threat] #454537
08/31/09 04:14 PM
08/31/09 04:14 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
Dam I love a good story especially with pictures!!
Was that 3410 lb (or so) with you in the seat??
Re: 7 second street C-body on DOT tires? #454538
08/31/09 05:03 PM
08/31/09 05:03 PM
WA 98043
thecarfarmer Offline
WA 98043
C'mon, even with the huge rear tires, that's still a sleeper.
Look at the SIZE of that thing! I'd look at that and think, "tens, maybe nines; perhaps even high eights."
But nothing should go that fast pushing that much air.
BTW, this pic is soo cool, I've had to save it...
Your car rules!
-Bill
Seduce the attractive, and charm the rest. ****** 489 C.I.D., roller cam, aftermarket heads, tunnel ram, stock '54 Dodge rear axle assembly: which of these doesn't belong?
Re: 7 second street C-body on DOT tires? [Re: thecarfarmer] #454539
08/31/09 06:40 PM
08/31/09 06:40 PM
Orlando Fl
Dos Snails Offline
Dos Snails  Offline
Orlando Fl
Congrats on the 7! Well deserved.
Re: 7 second street C-body on DOT tires? [Re: Dos Snails] #454540
09/01/09 01:14 AM
09/01/09 01:14 AM
Finalnd, Perkele
jyrki Offline OP
jyrki  Offline OP
Finalnd, Perkele
The weight was with me in the seat, but without the hood. That's propably about 30 lbs. We also left the tailpipes off and the aluminum gastank that broke in Swededn was replaced with a smaller one, 10 gallons vs 16 before. I'm also a little lighter than Jussi, the other part of our team that during this race was on a vacation in Nizza. In Sweden with Jussi the car weighed 1622 kg, 3570 lbs. We also had lowered the boost a little from Sweden, and I didn't raise it back, I think that power reduction about made the weight difference.
Re: 7 second street C-body on DOT tires? [Re: chryco] #454541
09/01/09 02:21 AM
09/01/09 02:21 AM
Califor-ni-A!
MrFoFody Offline
MrFoFody  Offline
Califor-ni-A!
pics of your car
THIS THREAD IS WORTHLESS WITHOUT PICTURES
Here you go !
So which one is the 7sec car?
Re: 7 second street C-body on DOT tires? [Re: MrFoFody] #454542
09/01/09 02:26 AM
09/01/09 02:26 AM
Finalnd, Perkele
jyrki Offline OP
jyrki  Offline OP
Finalnd, Perkele
This one, in the previous race with the chassis gremlins:
http://www.youtube.com/watch?v=aEHELDeG6Lc
Re: 7 second street C-body on DOT tires? [Re: jyrki] #454543
09/01/09 06:03 AM
09/01/09 06:03 AM
Europa, Estonia
Georg Offline
Georg  Offline
Europa, Estonia
Nice and interesting story! Congrats again, Your The Man!
Keep Mopar flag high
Outlaw Plymouth Valiant R5/P7 Powered by Liuzzo Racing COMP Performance Group dealer in Baltic Premium Performance
Re: 7 second street C-body on DOT tires? [Re: Georg] #454544
09/01/09 08:33 AM
09/01/09 08:33 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
Isn't boost wonderful? Nice car, nice pass.
Coming soon!!!!
