Re: race gas compared to E85 when converted
[Re: 10sec340]
#454064
08/31/09 08:06 PM
08/31/09 08:06 PM
Posts: 52,972 Romeo MI
MR_P_BODY
what about the concern that it's not always e85, some times it on 70 -75 or winterblends?
Mid summer isnt a problem... but I check the drop sheets at the station to see what the percentage of alky it is.... they drop X gals of alky and X gals of regular into the same tank OR you can get a tester from Quick Fuels
[Re: 69dart]
#454065
08/31/09 08:19 PM
08/31/09 08:19 PM
Posts: 16,934 NC
440Jim
NC
Well I'm finally going to try this E85 stuff. I stopped at Jegs and picked up the Quick Fuel conversion kit and an alcohol rebuild kit. So next Friday I'm going to hit test n tune and see how it works. I'm currently running a Holley 950
I did a home conversion on a Holley 950 and it worked OK, but it really needed the boosters changed to optimize it for E85. If you can't get it rich enough to slow down the car (then lean for optimum), look into having boosters swaged in that will flow more fuel.
[Re: MR_P_BODY]
#454066
08/31/09 08:20 PM
08/31/09 08:20 PM
Posts: 16,934 NC
440Jim
NC
Is there a problem with E85 ruining oil like is the case with methanol? S/F....Ken M
No its nothing like meth... get get it warmed up before your run... I get to about 185 degrees at the end of my run each time and when I get back to my pit spot and shut it down it back to about 165... I havent seen hardly any oil contamination, I went last season with 1 oil change mid season and it still looked good
[Re: MR_P_BODY]
#454067
08/31/09 08:23 PM
08/31/09 08:23 PM
Posts: 16,934 NC
440Jim
NC
And I fill a 55 gallon fuel drum whenever I go to the station. In late summer, buy enough to last until the summer blend comes out in late spring or so. Call and test.
[Re: MR_P_BODY]
#454068
08/31/09 09:26 PM
08/31/09 09:26 PM
Posts: 316 Ohio
Lil Wedge
Ohio
Mid summer isnt a problem... but I check the drop sheets at the station to see what the percentage of alky it is.... they drop X gals of alky and X gals of regular into the same tank OR you can get a tester from Quick Fuels I tried this, went to 4 different places , asked the attendants, you would have thought I asked them to explain Nuclear fusion. In fact on the pump it states to ask the attendant which blend is currently being sold, They didn't know anything about it.
[Re: Lil Wedge]
#454069
08/31/09 10:26 PM
08/31/09 10:26 PM
Posts: 123 long beach,ny
10sec340
long beach,ny
LOL suprised the even knew English !!!
real 383 car now 440..
[Re: Lil Wedge]
#454070
08/31/09 10:36 PM
08/31/09 10:36 PM
MR_P_BODY
None of them know....or care, you have to ask to see the drop sheets for the E-85... they will have to get off their butts to look for it but all the trucks have to give them the drop sheets.... I get my fuel from Meijer and even the woman manager found it, now she knows me.
[Re: MR_P_BODY]
#454071
08/31/09 11:14 PM
08/31/09 11:14 PM
Posts: 3,698 NE Oklahoma
Von
NE Oklahoma
I called the semilocal station that has E85 about their drop sheets. I messed up because I called from work ( I work for the state of OK environmental regulatory agency, no Im not an environmentalist, LOL). The girl who answered the phone obviously read the Caller ID. She started sturrering, everything is legal, we do it by the book, etc. I reassured my call was not work related, finally I had to call the main office. The lady there was very helpfull and gave me the latest drop sheet info and told me to call back anytime.
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72.
Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
[Re: Von]
#454072
09/01/09 06:59 AM
09/01/09 06:59 AM
10sec340
long beach,ny
Okay, before i got check these drop sheets, what am I looking to see #'s wise thats good and what to stay away from ??
Tim
