Re: 1970 Challenger R/T Grill Resto.
[Re: Troy]
#45280
11/28/06 11:58 AM
11/28/06 11:58 AM
Posts: 3,957 West Coast, CA
Troy
West Coast, CA
I will start from the beginning.
....there is nothing like driving my 1968 Hemi Dart around town and having people looking at you like you're nuts!!
[Re: Troy]
#45283
11/28/06 12:13 PM
11/28/06 12:13 PM
Troy
West Coast, CA
I drilled out all of the rivets and carefully took it all apart. I used a buffing wheel that was on sale at Harbor Fright ($40.00) and polished the outer lip and the inner lip. When I was done I masked those two areas off and was ready to paint.
[Re: Troy]
#45284
11/28/06 12:16 PM
11/28/06 12:16 PM
Troy
West Coast, CA
Did the same to the egg crate frame... The egg crate was lightly fogged with Eastwood Reflective paint, the stuff you use inside turn signal housings. If you use too much paint it looks painted and that is not the look I was going for. I wanted something that was a little inconsistent and to give a more original look.
[Re: Troy]
#45285
11/28/06 12:24 PM
11/28/06 12:24 PM
Troy
West Coast, CA
I put it all back together and this is what I ended up with. I was into it for $80.00 including a new buffing wheel. There are people out there that want $1250.00 to restore a grill....there grills look better that mime but I don't think they look $1170.00 better that mine.
[Re: Troy]
#45288
11/28/06 12:57 PM
11/28/06 12:57 PM
Posts: 8,526 Tenn.
jrwoodjoe
Tenn.
Troy, ![](/ubbthreads/images/graemlins/bow.gif) Nice work. Looks Beautiful to me. Dave, ![](/ubbthreads/images/graemlins/bow.gif) To you also. This is a great thread and hope it gets saved somewhere. I may use a combination of what both you guys have done. Thanks for sharing. Troy, I had thought about getting a buffing wheel but didn't think about HF. I'll give them a look when I get out that way again. Thanks again. This has been helpful. Joe
[Re: jrwoodjoe]
#45289
11/28/06 01:24 PM
11/28/06 01:24 PM
Posts: 396 BC
70RT27N
BC
Very nice job to both Troy and Dave!. A couple of questions: Dave, Where in Canada did you buy that Aluminum cleaner? Troy, What buffing wheel did you use, and did you need to use any compound? Also, what rivets did you use to reassemble the grill? Excellant info...I have saved this thread ![](/ubbthreads/images/graemlins/thumbs.gif)
[Re: 70RT27N]
#45291
11/28/06 07:03 PM
11/28/06 07:03 PM
Troy
West Coast, CA
Thanks for the nice words.
The buffing wheel that I got from Harbor Freight came with a flapper wheel for soft or finishing compounds and a standard wheel for hard or cutting compounds.
[Re: Troy]
#45292
11/28/06 07:20 PM
11/28/06 07:20 PM
Troy
West Coast, CA
SOMTHING I FORGOT TO MENTION that is VERY important before you start to polish the grills or other parts. Many of these parts have a silver anodizing on them. That must be removed before you can polish the parts. I used Easy Off oven cleaner and a 00 steel wool. It will take two or three times to get the anodizing off but you have to do it before you polish it. You can tell when the anodizing is off when the steel wool starts to grab onto the part. When the anodizing is still there the steel wool kinda slides over it, making it feel very smooth.
[Re: Troy]
#45293
11/28/06 07:51 PM
11/28/06 07:51 PM
Posts: 992 Oakville.ON,Canada
hemi_rtdave
Oakville.ON,Canada
See attached for the name and number of the place I got the cleaner. The rivets and most importantly the tool were provided by mopart member Petes resto parts. Here is a link http://www.petesresto.com/
[Re: yellow sixpack]
#45295
11/29/06 09:08 PM
11/29/06 09:08 PM
Posts: 6,252 Zzyzx Road
beepbeep
moparts member
moparts member
Zzyzx Road
If you are going to all the trouble of taking the eggcrate apart, you may as well replace it with a new piece. The picture I posted above has a new eggcrate in it.
Amazing how an unchallenged lie can become the absolute truth.
