70 Challenger driveshaft length #452382
08/28/09 08:25 AM
08/28/09 08:25 AM
Davenport, IA
70shaker Offline OP
70shaker  Offline OP
Davenport, IA
I have installed a Strange Dana 60 in my Hemi Challenger and I am trying to get the right length driveshaft. I bought a slip yoke from Strange (1350 u joints). Their website says to bottom out the slip yoke in the trans take the measurement and then subtract 1".
This leaves me with a 45.62 long driveshaft. The charts say my driveshaft should be 44.60 long. Did Ma Mopar allow 2" from bottomed out in the trans?
The car had an 8 3/4 in it and the driveshaft was 45.25 long. The charts say it should have had a 45.60 long driveshaft. I asked Strange and they informed me their stuff is the same dimensionally as the originals.
Any help will be appreciated.
Ex Hemi Racer
70 Challenger Hemi 4 speed clone
Re: 70 Challenger driveshaft length [Re: 70shaker] #452383
08/28/09 11:26 AM
08/28/09 11:26 AM
Davenport, IA
70shaker Offline OP
70shaker  Offline OP
Davenport, IA
Anyone?
Ex Hemi Racer
Re: 70 Challenger driveshaft length [Re: 70shaker] #452384
08/28/09 12:19 PM
08/28/09 12:19 PM
Davenport, IA
70shaker Offline OP
70shaker  Offline OP
Davenport, IA
I just talked to a different guy at Strange and he told me their slip yoke is 1" shorter than stock and that is where the difference is.
Ex Hemi Racer
Re: 70 Challenger drive shaft length [Re: 70shaker] #452385
08/28/09 01:52 PM
08/28/09 01:52 PM
Central Coast, Calif.
Snoopy Offline
Snoopy  Offline
Original 7290 slip joint.
8 5/16" OAL
7 9/16" Center of u-joint to end of shaft.
Re: 70 Challenger drive shaft length [Re: Snoopy] #452386
08/29/09 03:04 PM
08/29/09 03:04 PM
Snoopy Offline
Snoopy  Offline
Looks like the Strange slip-joint is an 1 1/2" shorter. I wonder how much it sticks out the end of the transmission when it is bottomed out?
U1666 Mopar, Doug Nash, & Liberty / 30-spline / 1350
series (Strange Stainless Steel) (G= 6.062 H= 1.680)... $179.00
Re: 70 Challenger drive shaft length [Re: Snoopy] #452387
08/29/09 03:18 PM
08/29/09 03:18 PM
BDW Offline
BDW  Offline
Maybe I'm missing something but the length of the part that slides into the tranny won't affect the DS length.
44.6 should be the correct number.
Re: 70 Challenger drive shaft length [Re: Snoopy] #452388
08/29/09 03:20 PM
08/29/09 03:20 PM
Snoopy Offline
Snoopy  Offline
Here is a picture of the slip-joint I posted, bottomed out in a 70 E-Body A833 transmission. It sticks out about 2 1/4" from the end of the housing to the center of the u-joint (7290).
It appears that the only thing you get with a shorter u-joint is a shorter stroke and premature dropout.
Re: 70 Challenger drive shaft length [Re: Snoopy] #452389
08/29/09 03:27 PM
08/29/09 03:27 PM
BDW Offline
BDW  Offline
That's the measurement you need.
What's the measurement between the U-joint centerline to the base (not including the barrel part that slides in the tranny).
If the 1350 is 1" shorter than the 7290, then you need a 1" longer DS.
