Re: Comp Cams XE268H vs. XE274H? Opinions? [Re: Sub95] #452339
08/29/09 06:35 PM
08/29/09 06:35 PM
Oregon City, OR
Baxter61 Offline
Baxter61  Offline
Oregon City, OR
I have the xe274h in a less than 8:1 360, I can go sideways from a 20 mph roll. Its installed at 106. It has plenty of bottom end in my opinion and pulls 12+ inches of vacuum. I would have 0 problems with driving it in an every-day application. The hp BB cams in 70 were 268 on the intake so do you want the same size or bigger?
Re: Comp Cams XE268H vs. XE274H? Opinions? [Re: Baxter61] #452340
08/29/09 06:44 PM
08/29/09 06:44 PM
Kirkland, Washington
Pacnorthcuda Offline
The modern grinds ARE larger. Because of lift. The old-school stuff was high in duration for a given lift so diveability suffered in the true Hi-Po grinds. Now you can get good lift at reasonable duration. A lunati 60303 is .493/.513 at 268/274 (as I recall---if thats not totatlly accurate its close) Look at the lift of the stock 268 lobes, its not even .480.
Modern grinds rock.
Re: Comp Cams XE268H vs. XE274H? Opinions? [Re: Pacnorthcuda] #452341
08/30/09 02:57 AM
08/30/09 02:57 AM
Oregon City, OR
Baxter61 Offline
Baxter61  Offline
Oregon City, OR
Modern grinds rock.
I dont argue the design of the modern cams is better. However, that doesnt change how long the valve is off the seat.
Re: Comp Cams XE268H vs. XE274H? Opinions? [Re: Baxter61] #452342
08/30/09 09:18 AM
08/30/09 09:18 AM
Ohio
theclutcher Offline
theclutcher  Offline
Ohio
exper with 2 diff apps and xe 268 both manual trans both very nice.
Re: Comp Cams XE268H vs. XE274H? Opinions? #452343
08/30/09 10:11 AM
08/30/09 10:11 AM
Mid-Atlantic
Scatransit Offline OP
Mid-Atlantic
Your cam question really can't be answered properly without having some idea of your actual CR; that's why someone brought up the issue - they were trying to help you, not harass you.
All I seek is personal experiences with the cams mentioned in the subject line with respect to a basically stock 383 HP. I have pretty much decided on the XE268. I was curious about the 274, that's why I posted...Sorry if I worded it improperly Thanks to all for info in that regard.
As far as a lecture in automotive math goes, after 33 years as a mechanic - I'm good.
It was never within the scope of this rebuild to delve into the exactness of measure...Were I to build a specialty engine, then that would surely come into play. This little 383 ran like a sewing machine, made great power, and was quiet...Its only problem was burning oil. Taper was excessive so I opted for the .030 over 10:1 flat tops from Sealed Power....That's it...All else measured fine...New bearings and gaskets, double roller chain, cam, lifters, springs and I'm done...Were it not for the oil burning issue, it would still be between the fenders!
Trust me, I do appreciate everyones input...I do not feel harassed, or defensive, or mad, or whatever...I've been doing this a LOT of years...You learn something new everyday...
[oo]======[oo]
Re: Comp Cams XE268H vs. XE274H? Opinions? [Re: Scatransit] #452344
08/30/09 10:48 AM
08/30/09 10:48 AM
IA
landon1 Offline
landon1  Offline
IA
my 440 has what are called 10:1 pistons - they aren't even close...more like 9:1. i think they figure the CR with closed chamber heads @ 74cc. i went with the XE268. haven't had a chance to get it out yet - hopefully sometime this week. i think i probably could have gone another step larger and been okay, but i wanted to play on the conservative side as i didn't want to mess with my torque converter or change my rear gears (yet )
will post back with more info once i get it back together and on the road
'71 Satellite Sebring 440
Re: Comp Cams XE268H vs. XE274H? Opinions? [Re: Scatransit] #452345
08/30/09 10:56 AM
08/30/09 10:56 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
My stock rebuilt 383, I used the Crower 271HDP #32242. It is simular in size. Advertised duration is 271/284, 222/234 @ 0.050", 0.486"/0.496" lift with 112 LSA. This cam made good power but it really wanted a higher stall converter. I guess I could have installed it advanced for more low end torque?
I think going with the smaller cam is the best choice if you plan on driving on the street.
Also, did your pistons have valve reliefs?
My "stock" replacement pistons had no valve reliefs, and I over-reved the 383, resulting in two bent intake valves.
Re: Comp Cams XE268H vs. XE274H? Opinions? [Re: 451Mopar] #452346
08/30/09 06:05 PM
08/30/09 06:05 PM
Mid-Atlantic
Mid-Atlantic
That's good info...sorry about the bent valves...My pistons are flat on top - no reliefs - as were the originals...I'd like to hear how Landon1's car turns out...Let us know...
[oo]======[oo]
Re: Comp Cams XE268H vs. XE274H? Opinions? [Re: Baxter61] #452347
08/30/09 06:29 PM
08/30/09 06:29 PM
Modern grinds rock.
A modern grind 268 is not "the same size" as OEM 1970 268. And thats a wonderful thing!
Re: Comp Cams XE268H vs. XE274H? Opinions? [Re: Pacnorthcuda] #452348
08/30/09 06:40 PM
08/30/09 06:40 PM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
the old 268 is around 212 @.050
Re: Comp Cams XE268H vs. XE274H? Opinions? [Re: Scatransit] #452349
08/31/09 12:11 AM
08/31/09 12:11 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
That was almost 20-years ago, and the 451 stroker was the replacement motor
Re: Comp Cams XE268H vs. XE274H? Opinions? [Re: 451Mopar] #452350
08/31/09 12:22 AM
08/31/09 12:22 AM
Marine Corps Base Hawaii
DemonKyle Offline
USMC LCPL
DemonKyle  Offline
USMC LCPL
i have the xe268h in my 360 and i love it
Re: Comp Cams XE268H vs. XE274H? Opinions? [Re: 451Mopar] #452351
08/31/09 12:24 AM
08/31/09 12:24 AM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
Go with the comp xe268. With your compression, cubes, intake and exhaust that comp 268 is about the most amount of cam your combo will tolerate without a noticeable loss of bottom end power anyway. Actually with your combo I might even step down to the lunati voodoo 60302. It's got a little more lift than that comp but 4* @050 less duration than the comp268 and the 60302 is ground on a 112 lsa vs the comp's 110 lsa which the longer lsa may suit your stock 383 a little better anyway.
Re: Comp Cams XE268H vs. XE274H? Opinions? [Re: Scatransit] #452352
09/03/09 08:49 PM
09/03/09 08:49 PM
IA
landon1 Offline
landon1  Offline
IA
car is up and running pretty well - need to get it timed right and i think the carb needs some adjustment, but it runs pretty well, has a bit of a lope even with headers and 2.5" duals with turbo mufflers. haven't had a chance to get it on the road yet - have some other things i need to get done first.
Re: Comp Cams XE268H vs. XE274H? Opinions? [Re: landon1] #452353
09/05/09 08:23 PM
09/05/09 08:23 PM
Willoughby Hills, Ohio
gd9704 Offline
super gas
gd9704  Offline
super gas
The 268 has a large following of very happy users here. For a largely stock engine (like yours) it seems to be a great upgrade. Like others above have said, a too-big cam for a street car will be less fun to drive.
I'd jab in the 268 and have fun!
My
Re: Comp Cams XE268H vs. XE274H? Opinions? [Re: gd9704] #452354
09/05/09 08:47 PM
09/05/09 08:47 PM
IA
landon1 Offline
landon1  Offline
IA
i have a vid of my fresh 440 in the project section with hedmans and 2.5" summit exhaust - idle is basically stock - power is greatly improved over the stock low-comp set-up, throttle response is way better, revs about the same, but can definitely hear and feel the increase over stock - i could have went another step up probably, but with an auto, i didn't want to get into changing the converter, but i'm happy with it
Re: Comp Cams XE268H vs. XE274H? Opinions? [Re: landon1] #452355
06/19/10 03:56 PM
06/19/10 03:56 PM
Seattle, WA
rss Offline
rss  Offline
Seattle, WA
Trying to raise an old thread from the dead to see if OP has any results to post.
