Re: Fuseable Link Fuse Blows in drive an reverse?!!! HE
[Re: stumpy]
#450856
08/28/09 07:43 PM
08/28/09 07:43 PM
Posts: 386 Maryland
reno340
Maryland
You need a fusible link not a fuse in the main circuit. Fusible links are slow blow for a reason. Fuses blow fast when spiked.
My goodness. He blew them both. what does that tell ya!
"There are only three real sports, Mountain climbing, Bull Fighting and Auto Racing. The rest are just games" - Earnest Hemmingway If you can't run with the big dogs, stay on the porch!! https://www.youtube.com/watch?v=_xQJtN1_6DU
[Re: reno340]
#450857
08/28/09 08:34 PM
08/28/09 08:34 PM
Posts: 99 NY
MoparGary7272
NY
I have a new NSS i got from a buddy still in the box, i looking at the harness.. it looks good.. BUT i didnt pull it off yet, at the time i was noticing the snapped Speedo cable and just replaced it... But if the NSS harness is good, where do i look next?! Yes the car is 38 years old, but its a southern car and a lot of stuff on it is like new, plus the low miles help,.. The Car is tuned Great now, doesnt stall or blow the fuse in reverse ever since the fusible link blew, and shifting into the gears while not moving, it doesnt blow a fuse, instead it does it while driving when RPM have a dramatic change, then like i said the alt. meter goes Frantic and the fuse blows... i must say , i have never seen a fusible link go so quick!!! it drove fine for about 8 miles.. i guess the NSS has to be looked over thouroughly to really know:/ After a fuse blows or the F.L. blew, it WILL NOT start in park just Neutral
[Re: MoparGary7272]
#450858
08/28/09 09:13 PM
08/28/09 09:13 PM
Posts: 6,840 The Swamp
Sixpak
The Swamp
You can chase gremlins, or you can fix it the right way. If you have the bucks you can replace everything. If you want to learn something and can work methodically then get a factory service manual, some good wire, tape, an ohm meter, solder and soldering gun and learn how to fix it yourself. Electrical work is a lot like plumbing, and the wiring diagrams in the FSM have never let me down. You got a dead short dealing with the NSS wiring. I've seen factory shift linkages chafe and cut into the wiring before. Also have fixed my share of hack jobs, both under the dash and under the hood. If you have the patience to go one wire at a time, you can fix that old harness.
