Re: 2 1/2" or 3" exhaust for SB stroker
[Re: Moparteacher]
#450477
08/26/09 10:38 AM
08/26/09 10:38 AM
Posts: 13,417 Marion, South Carolina [><]
an8sec70cuda
Personally I would run the 3".
CHIP
[Re: an8sec70cuda]
#450478
08/26/09 10:42 AM
08/26/09 10:42 AM
Posts: 15,493 the boonies
aarcuda
the boonies
CHIP
okay then, after further 'researching' on the weldtech site, they have a whole 3" stainless exhaust from headers to mufflers with an x pipe. thats everything i wanted in an exhaust.
any ideas about the flow on their mufflers? I'd imagine they would be fine but i just have to ask.
anyone know if they deliver to shows like the Monster? (they arent answering their phone right now)
[Re: aarcuda]
#450479
08/26/09 11:15 AM
08/26/09 11:15 AM
Posts: 52,972 Romeo MI
MR_P_BODY
CHIP
To be honest your 1 5/8 headers are a hold up but you could use a 3" till you get to the tailpipes then you could drop to the 2 1/2" ... the gasses at the tailpipe have cooled and dont require the big tubes vs up closer to the engine ![](/ubbthreads/images/graemlins/wave.gif)
[Re: aarcuda]
#450482
08/26/09 12:24 PM
08/26/09 12:24 PM
MR_P_BODY
i have the 1 3/4" hooker super comps. not the 1 5/8"
these were the biggest ones I could find that would work with my power steering and such
Sorry.... I seen that.... still holds true on the tailpipe thing ![](/ubbthreads/images/graemlins/wave.gif)
[Re: MR_P_BODY]
#450483
08/26/09 02:47 PM
08/26/09 02:47 PM
Best advice i've seen on here ![](/ubbthreads/images/graemlins/thumbs.gif)
Re: 2 1/2" or 3" exhaust for SB stroker. BURN!
[Re: aarcuda]
#450485
08/28/09 12:30 PM
08/28/09 12:30 PM
Posts: 16,123 Grand Haven, MI
patrick
Grand Haven, MI
street or pure race?
street you won't know the difference.
race, it might cost you a couple tenths.
[Re: aarcuda]
#450486
08/28/09 12:42 PM
08/28/09 12:42 PM
Posts: 43,373 Bend,OR USA
Cab_Burge
looks like I'm a day late. i finally got in touch with Weldtech and they said they do not have anymore 3" dies for bending the pipes. and they dont make the 3" in/out TA mufflers any more and they dont know anyone who does.
so even though Im ready to buy a 3" x pipe system, I can't.
How bad will the 2 1/2' system be?
I have tested a 2.5 system on my old 440 powered Dart, it was 2.5 inch out of the headers into 2.5 Turbo muffs and then 2.5 pipes to the front of the rear wheel wells. The car ran 12:20s at 109. MPH cork up, it ran 11:30 at 117. MPH uncorked My new car runs almost the same in the 1/8 mile, 6:98 at 100.3 MPH uncorked versus 7:01 at 99.8 MPH corked up, with the three inch system from the headers to the Magnaflow 3x14 mounted behind the rear end at the rear bumper I would put a three inch system on everything now based on those results. The Magnaflows and the Ultraflows seem to be real good at noise management and still not restrict power ![](/ubbthreads/images/graemlins/Twocents.gif)
[Re: aarcuda]
#450488
08/28/09 02:10 PM
08/28/09 02:10 PM
aarcuda
the boonies
well well well. After doing some more research, i came upon the flowmaster site and found they sell a muffler with a 3" in and two 2.5" outs with one of the outs being on the same side of the in. I called them to see if i could get away with just cutting the outlet on the back side and welding it up and pretty much making it an AAR style mufler with the inlet and outlet on both sides. They said i should call their special projects team and they could make me what i need (albeit not as cheap as I could get from summit. So now i have a choice of either a 4' tall or 5" tall AAR style muffler with a 3" inlet and a 2.5" outlet (which will match the 2.5" AAR style exhaust tip. i think I have it! ![](/ubbthreads/images/graemlins/thumbs.gif)
[Re: aarcuda]
#450489
08/28/09 02:11 PM
08/28/09 02:11 PM
Posts: 2,578 sweden
1Fast340
sweden
I wish i could go 3' all the way but I cant find a muffler that has 3" inlets and outlets on the same size like the TA/AAR muffler.
im not sure this can be done on a mopar of any kind but i have one option left for you but it depends on how wide the muffler pockets under the car is and how wide the muffler is, you can use a muffler with a offset inlet and center outlet and then use a 180degree bend behind it with a thight radius like a 4"radius to bend around the case and go forward again slightly tilted down and then use something like a 135 degree bend back again out in front of the wheels while it also goes around the front legs of the frames. i have done this on a mustang but it was only a 2½" system.. it did look good but was a very thight fit and requiers custom everything
[Re: OzMopar]
#450492
08/28/09 04:05 PM
08/28/09 04:05 PM
aarcuda
the boonies
Spintech do what your after with the sportsmans split case mufflers.
Check it out -
http://spintechmufflers.com/spintech/spintechindex.asp
just when I settle in to a decision, I get another choice. well better late than never.
i just checked these guys website and they sound interesting.
are they as good as they say they are? Any comparisons? have you tried them? any negatives?
