Page 16 of 29 1 2 14 15 16 17 18 28 29
Re: It's FINISHED! [Re: POS Dakota] #449410
07/05/10 09:00 PM
07/05/10 09:00 PM
USA
Ron Silva Offline OP
USA
Took a couple more pics. Here you go.
SRT DEMON ONE SEAT
Re: It's FINISHED! [Re: Ron Silva] #449411
07/05/10 09:01 PM
07/05/10 09:01 PM
USA
USA
one more
SRT DEMON ONE SEAT
Re: It's FINISHED! [Re: Ron Silva] #449412
07/05/10 09:01 PM
07/05/10 09:01 PM
USA
USA
last w/Vacuum PP hose.
SRT DEMON ONE SEAT
Re: It's FINISHED! [Re: Ron Silva] #449413
07/05/10 10:31 PM
07/05/10 10:31 PM
Land of the Brave, Home of the...
63CandyMatic Offline
Great looking motor, and nice pics to boot!! Those are nicer than our family portraits!
Re: It's FINISHED! [Re: 63CandyMatic] #449414
07/06/10 02:20 AM
07/06/10 02:20 AM
West Coast, CA
Troy Offline
Troy  Offline
West Coast, CA
Hi Ron, looks like all is well with you.
I work with a friend of mine Ford engine (before anybody starts bashing, 1225HP and that is motor only, ) we have played with push rods the entire life of this combo. We run a tapered 7/16 to 3/8 push rod. What we started to do was painted the push rods with diecome (sp?) where they pass through the heads. We will run .030 clearance all the way around the rod and only after some hard pulls, we would see where the push rods were rubbing the heads (the joys of 1000lbs open pressure) The point I'm trying to make is, and I know you know this, it is a heck of a lot easier to figure out small problems on a dyno than in a car. Dyno the motor Ron!!
....there is nothing like driving my 1968 Hemi Dart around town and having people looking at you like you're nuts!!
Re: It's FINISHED! [Re: Troy] #449415
07/06/10 09:20 AM
07/06/10 09:20 AM
the house on the left.
cogen80 Offline
cogen80  Offline
Of course you cannot get it all and had to clean up what I could and hope the oil filter gets the rest....
for real? all that time and money and your gonna HOPE the oil filter gets it ? oh man thats just crazy if you ask me.
Re: It's FINISHED! [Re: cogen80] #449416
07/06/10 11:16 AM
07/06/10 11:16 AM
State College, PA
RyanJ Offline
moparts member
RyanJ  Offline
moparts member
State College, PA
That Jones Drive mandrel pulley stuff looks like it ended up pretty nice
I just used one of those E brock Water pumps recently for 1st time as well & they are by far nicest mechanical out there, now that the MP Nascar unit is gone. Looks good.....
Any debris left in engine has to go through filter to get to bearings. & Knowing Ron, I highly doubt there really was any debris he missed, I think he just said that in case there was one tiny little sliver etc that somehow escaped his eyesight. I've done the grind for P rod clearance with head on motor before in a bind time wise etc before & never had it be an issue, with proper care/cleanliness when grinding.
Re: It's FINISHED! [Re: RyanJ] #449417
07/06/10 01:36 PM
07/06/10 01:36 PM
USA
USA
EXACTLY!
SRT DEMON ONE SEAT
Re: It's FINISHED! [Re: Ron Silva] #449418
07/06/10 01:58 PM
07/06/10 01:58 PM
Now - Port Orange,Fla. Former...
MIKES_DUSTER Offline
Hey Ron...Motor looks GREAT!!!! Just curious what it weighs...Will you weigh it??
Re: It's FINISHED! [Re: MIKES_DUSTER] #449419
07/06/10 02:46 PM
07/06/10 02:46 PM
USA
USA
That is a good question. Because I have done a lot to reduce weight. I used all the titanium Bolts I have been hoarding on this project. And, I have bought a few more. For instance the 6-1/2" Underhead length bolts on the Pass side of the water pump cost $27 each. But when you pick up and hold a bolt like that in Titanium, it is freaky light. Almost seems like PLASTIC.
I have no good way to weigh the engine. My best guess is I will be losing about 60 pounds changing engines. My car was 3115 with me in it at Vegas and resently it showed 3160 with me in it at Fontana. But is Vegas it was out of gas! LOL. The fuel pump fell silent in the shutdown area! Doh!
I will tell you this, I have no problem grabbing the bar that turns the engine on the stand (with 2 hands)and lifting that end of the engine to move it over when I am trying to position it in the garage.
I will post what I believe the weight reduction to be when I re-weigh the car in the future. With this new Engine, now I can start pigging out. Where's them RIBS!
SRT DEMON ONE SEAT
Re: It's FINISHED! [Re: Ron Silva] #449420
07/06/10 02:52 PM
07/06/10 02:52 PM
State College, PA
RyanJ Offline
moparts member
RyanJ  Offline
moparts member
State College, PA
Ron, just curious, is there any particular reason you ran the vacuum pump line all way over to pass side of motor? (just would have looked alot cleaner over on drivers side)
I'm already making plans to come out to Vegas for the MATS race next year for 1st time, so hopefully I can see that beauty & meet you in person.
Re: It's FINISHED! [Re: RyanJ] #449421
07/06/10 03:04 PM
07/06/10 03:04 PM
USA
USA
You are not going to believe this. But I sat the Valve cover on the bench and got distracted and then ended up cutting the hole in the WRONG END! So, the only way would be to plug it or have it at the back of the drivers side or the front of the pass side. I agree with you 100%, but it would have required tighter bends in the fittings. As it is I think the gentle bends and ease of installation are slightly better. But look like crap. But if you think about it, when it's installed in the car it will not be as big an issue with the bathtub for the air cleaner etc.
I put a full size baffle under that breather and it has 2 layers of the stringy material inside as well. I hope to provide the "dry air" to the vacuum pump as required.
Below is a pic of the current setp to compare.
SRT DEMON ONE SEAT
Re: It's FINISHED! [Re: Ron Silva] #449422
07/06/10 03:42 PM
07/06/10 03:42 PM
USA
USA
inside
SRT DEMON ONE SEAT
Re: It's FINISHED! [Re: Ron Silva] #449423
07/06/10 03:42 PM
07/06/10 03:42 PM
Mira Loma, CA
69B3GT Offline
69B3GT  Offline
Mira Loma, CA
Isnt fontana doing night races on the 17th?
Thats one bad motor to go with a really clean car
Re: It's FINISHED! [Re: 69B3GT] #449424
07/06/10 04:18 PM
07/06/10 04:18 PM
El Dorado Ca
65signet Offline
65signet  Offline
El Dorado Ca
Are you still planning on coming to Sacramento in Sept for the Mopar race?, looking forward to seeing the car again and hearing that motor run.
1965 Plymouth Barracuda 273 M/SA
1970 Plymouth Duster 360/904 10.60s with J heads
Re: It's FINISHED! [Re: 65signet] #449425
07/06/10 04:54 PM
07/06/10 04:54 PM
USA
USA
I really want to make that race. So, when I get home from Woodburn I will thrash and try to get the new engine in and the headers built and get it running. I think I will probably not make it, but you never know. I am going to try. That is one of my favorite races.
I even prefabbed the upper radiator hookup to save time. The upper is going to be different. I hope it works. It should be close enough.
I have tomorrow and the next day off and I am actually thinking of doing some prefab work on the headers.
SRT DEMON ONE SEAT
Re: It's FINISHED! [Re: 65signet] #449426
07/06/10 04:56 PM
07/06/10 04:56 PM
USA
USA
PS: I noticed in ND , your Daughter won some races. Mental note to self. "Do NOT" line up next to the Pink Valiant................
SRT DEMON ONE SEAT
Re: It's FINISHED! [Re: Ron Silva] #449427
07/06/10 05:17 PM
07/06/10 05:17 PM
El Dorado Ca
65signet Offline
65signet  Offline
El Dorado Ca
She will be racing this year in the ET finals at Sacramento in the Sportsman Class
Re: It's FINISHED! [Re: 65signet] #449428
07/06/10 05:25 PM
07/06/10 05:25 PM
USA
USA
SWEET! I only talked to her for 2 minutes last year and I am proud of her. I am sure you are too!
SRT DEMON ONE SEAT
I THOUGHT THIS DAY WOULD NEVER COME ! [Re: Ron Silva] #449429
07/23/10 01:37 PM
07/23/10 01:37 PM
USA
USA
I got home from Woodburn on Tuesday and.............I dropped the 501 in the Valiant yesterday evening. I will now build headers (about 3 weeks) and then see if she blows up! LOL
SRT DEMON ONE SEAT
