Re: SILVALIANT 501 CI Small Block Under way..........
[Re: 9 Sec Phill]
#449251
11/04/09 07:35 PM
11/04/09 07:35 PM
Posts: 8,547 State College, PA
RyanJ
moparts member
moparts member
State College, PA
How much do you think you shaved off the heads and intake? Are you going to heli coil the heads so you have no worries of striping any threads for the intake and rocker gear?
I have weighed the heads, they were 2.5 lbs each... I hav'nt weighed the intake yet against a stock one since it is'nt finished yet.
The rockers are T&D's & they use ARP studs, so they won't be stripping. As long as the assembler does'nt cross thread the intake/header bolts or overtorque them, they won't strip... So no, I don't plan on helicoiling them unless Ron asked for it. It's not something I normally do when selling INDY heads....
[Re: cheapstreetdustr]
#449254
11/05/09 12:04 AM
11/05/09 12:04 AM
Posts: 1,880 USA
Ron Silva
USA
He got the header flanges from Indy.
SRT DEMON ONE SEAT
[Re: dodgeboy11]
#449256
11/05/09 09:36 AM
11/05/09 09:36 AM
RyanJ
moparts member
moparts member
State College, PA
What kind of flow numbers did you get on your bench Ryan?
The ports are not done, have just done VJ on them so far. They will be in the 345-350 range @.700 with 2.15 valve.
Yes flanges are ICH
[Re: Dave Watt]
#449258
11/05/09 06:46 PM
11/05/09 06:46 PM
Posts: 1,880 USA
Ron Silva
USA
The #1 Reason I come to this site is to learn.
I am grateful, so my #2 reason for coming on here is to share info with those who may need it to "pay back" what I owe.
I told Ryan at the beginning I have nothing to hide and he can share whatever info he wants on this project.
SRT DEMON ONE SEAT
[Re: RyanJ]
#449259
11/08/09 02:31 AM
11/08/09 02:31 AM
Posts: 273 Edmonton alberta Canada
mr. 63plymouth
This engine should make at least 800LARGE for power, I have a 461smallblock(that earlier in the post the guy from sasktoon had heard of a 462 in alberta, this is me, but its 461)pump gas 750 single carb NATURALLY ASPIRATED with indy heads light bobweight, basically the same parts as this buildup and mine made 741hp and 638torque. This engine is in a 68 barracuda street car with full interior,exhaust,etc...Best et is 9.52@142.88mph with a 1.39 sixty ft. on a 10"tire with leaf springs and cal tracs No trans brake.
[Re: Ron Silva]
#449260
11/08/09 03:29 AM
11/08/09 03:29 AM
Posts: 1,418 Mcallen, TX
SB449VALIANT
Mcallen, TX
................... gilberto
