Page 6 of 29 1 2 4 5 6 7 8 28 29
Re: SILVALIANT 501 CI Small Block Under way.......... [Re: dodgeboy11] #449210
10/05/09 12:40 PM
10/05/09 12:40 PM
Finally a HUSKER again
Moparnut426 Offline
Moparnut426  Offline
Those look like the YFZ 450 pistons used in the 4 wheelers. Really short,
NICE!!!
Kasey
Re: SILVALIANT 501 CI Small Block Under way.......... [Re: Moparnut426] #449211
10/05/09 01:20 PM
10/05/09 01:20 PM
State College, PA
RyanJ Offline
moparts member
RyanJ  Offline
moparts member
State College, PA
You can read most of the specs right off the spec sheet..... 1.01" CH, 443 grams.
They did lighten the skirts some internally, but they wanted to leave as much strength as possible since it hardly has any skirt length & a 1.40 R/S ratio. They could have been made little lighter, maybe into the high 420's but they'd be hand grenades.
We're using a 2.50" X .866" Tool steel pin, bobweight will be about lightest you could imagine for a 500 CID motor.
The rods just walked in the door on the UPS truck a few minutes ago. I'll have pics this evening of them, they are unreal.... the beam is scary looking.
Re: SILVALIANT 501 CI Small Block Under way.......... [Re: RyanJ] #449212
10/05/09 01:44 PM
10/05/09 01:44 PM
oberlin, Ohio
Rapid340 Offline
Rapid340  Offline
oberlin, Ohio
Ryan,
Would you mind taking a rough measurement of the crown thickness (in the dish area) and let us know.
1971 Factory Appearing Duster 340 11.000 @ 122 mph
Re: SILVALIANT 501 CI Small Block Under way.......... [Re: Rapid340] #449213
10/05/09 02:28 PM
10/05/09 02:28 PM
State College, PA
RyanJ Offline
moparts member
RyanJ  Offline
moparts member
State College, PA
Ryan,
~.195"
Re: SILVALIANT 501 CI Small Block Under way.......... [Re: RyanJ] #449214
10/05/09 05:25 PM
10/05/09 05:25 PM
State College, PA
RyanJ Offline
moparts member
RyanJ  Offline
moparts member
State College, PA
Custom Billet R&R A beam Conn rods..... 6.30" With 2.0" SB GM big end & .866" pin end. I'll get them weighed tomorrow, but they are plenty light....
Re: SILVALIANT 501 CI Small Block Under way.......... [Re: RyanJ] #449215
10/05/09 05:27 PM
10/05/09 05:27 PM
State College, PA
RyanJ Offline
moparts member
RyanJ  Offline
moparts member
State College, PA
Big End
Re: SILVALIANT 501 CI Small Block Under way.......... [Re: RyanJ] #449216
10/05/09 05:27 PM
10/05/09 05:27 PM
State College, PA
RyanJ Offline
moparts member
RyanJ  Offline
moparts member
State College, PA
ARP 325 Plus cap screws.....
Re: SILVALIANT 501 CI Small Block Under way.......... [Re: RyanJ] #449217
10/05/09 05:28 PM
10/05/09 05:28 PM
State College, PA
RyanJ Offline
moparts member
RyanJ  Offline
moparts member
State College, PA
Pin end
Re: SILVALIANT 501 CI Small Block Under way.......... [Re: RyanJ] #449218
10/05/09 05:29 PM
10/05/09 05:29 PM
State College, PA
RyanJ Offline
moparts member
RyanJ  Offline
moparts member
State College, PA
1280
Re: SILVALIANT 501 CI Small Block Under way.......... [Re: RyanJ] #449219
10/05/09 05:30 PM
10/05/09 05:30 PM
State College, PA
RyanJ Offline
moparts member
RyanJ  Offline
moparts member
State College, PA
Crank should be done in next few weeks....... I'll post pics when it arrives.
Re: SILVALIANT 501 CI Small Block Under way.......... [Re: RyanJ] #449220
10/06/09 05:39 PM
10/06/09 05:39 PM
State College, PA
RyanJ Offline
moparts member
RyanJ  Offline
moparts member
State College, PA
Rods checked in @ 560 grams
Re: SILVALIANT 501 CI Small Block Under way.......... [Re: RyanJ] #449221
10/06/09 06:14 PM
10/06/09 06:14 PM
USA
Ron Silva Offline OP
USA
The Manley Pro series Tour Light Rods I had before in a 525 HP 4" stroke motor were 518 grams They were the same length and were for a .927 pin and 2.100 large end with a 3/8" bolt. I am certain they were not as good materials as these and held up just fine. I am 100% cofident with this Rod in THIS motor.
Thanks for the pics Ryan!
SRT DEMON ONE SEAT
Re: SILVALIANT 501 CI Small Block Under way.......... [Re: Ron Silva] #449222
10/06/09 08:02 PM
10/06/09 08:02 PM
Moparnut426 Offline
Moparnut426  Offline
Sweeeeeeet rods!!!
I thought my CHilds track masters were nice. Those are VERY NICE, I have read really good things on the R&R rods. They build some awsome Diesel stuff.
kasey
Re: SILVALIANT 501 CI Small Block Under way.......... [Re: Moparnut426] #449223
10/08/09 12:19 PM
10/08/09 12:19 PM
State College, PA
RyanJ Offline
moparts member
RyanJ  Offline
moparts member
State College, PA
Got everything weighed out to give Bryant the Bobweight today.....
1639.2 Bobweight Not bad for Steel rod 500 Inch motor
Re: SILVALIANT 501 CI Small Block Under way.......... [Re: RyanJ] #449224
10/08/09 03:05 PM
10/08/09 03:05 PM
Oakland, MI
dizuster Offline
dizuster  Offline
Oakland, MI
1640g?! WOW!
For you guys to compare, my 440" small block with Diamond Piston, Oliver Billet rods, and a Dragon slayer crank, has a bob weight of 1905g...
Re: SILVALIANT 501 CI Small Block Under way.......... [Re: dizuster] #449225
10/08/09 03:23 PM
10/08/09 03:23 PM
State College, PA
RyanJ Offline
moparts member
RyanJ  Offline
moparts member
State College, PA
1640g?! WOW!
Yeah but these R&R rods would fold in half @ your power & RPM level.
Re: SILVALIANT 501 CI Small Block Under way.......... [Re: RyanJ] #449226
11/04/09 06:39 PM
11/04/09 06:39 PM
State College, PA
RyanJ Offline
moparts member
RyanJ  Offline
moparts member
State College, PA
We have a crank........
Re: SILVALIANT 501 CI Small Block Under way.......... [Re: RyanJ] #449227
11/04/09 06:41 PM
11/04/09 06:41 PM
State College, PA
RyanJ Offline
moparts member
RyanJ  Offline
moparts member
State College, PA
BOBWEIGHT
Re: SILVALIANT 501 CI Small Block Under way.......... [Re: RyanJ] #449228
11/04/09 06:42 PM
11/04/09 06:42 PM
State College, PA
RyanJ Offline
moparts member
RyanJ  Offline
moparts member
State College, PA
Double keyway
Re: SILVALIANT 501 CI Small Block Under way.......... [Re: RyanJ] #449229
11/04/09 06:43 PM
11/04/09 06:43 PM
State College, PA
RyanJ Offline
moparts member
RyanJ  Offline
moparts member
State College, PA
1.25" Rifle drill on mains
