I have a package of MP Viton Valve Seals I bought in 2001 for the 440 in my '71 Charger.
A few months later, I bought Edelbrock Heads, so these sat in the original package since.
QUESTION: Which seal is for intake and which is for exhaust (Tall-Cup versus short umbrella-seals, look like black contact-lenses?) Guessing the taller-cups are for Intake, but not sure.
The reason I suddenly need to know, I decided to try using these on the AMC V8 in my Jeep CJ-5.
The AMC cylinder heads received a complete valve-job, new seals, springs, retainers, keepers a year earlier, so was surprised to have oil-burning issue. Note: Compression for all 8-cylinders was within specs, so valve-seals or perhaps (less likely) worn guides suspected.
In any event, I decided to replace them. The taller Cup-Type Mopar Perf Viton Seals look similar to the Intake AND Exhaust seals on the AMC motor (AMC uses "the same" tall-cup-seal on both intake & exhaust.)
So, today I used up two of the taller cup seals on my #7 cylinder valve guides, as that cylinder was oil-fouling the sparkplug.
The AMC seals I removed looked fine (almost like New) so I wonder if they just came loose off the top of the valve-guides?
In any event, the exhaust is now "clean" on that right-side bank of cylinders. (Note: dual exhaust, no crossover.)
But, now I notice that the Left bank is smoking a bit too, though WAYYYY, WAYYYY, WAYYYY less than the right bank with he fouled plug had been. Probably didn't notice the slight/tiny amount of white smoke from the Left bank, due to the choking amount from the right bank before I fixed it.
Am considering using the rest of the seal package to do all the cylinders in the left bank. Should that work/be Ok?
Also, weird question... Could these seals, seal TOO well, and starve the guides of all lubrication? The guide diameter of the MP seals is a perfect fit, however, the end that fits over the valve guide is "snugger" than the old (Fel-Pro) AMC seals I removed.
When I say "snugger," the MP seals feels/seems like a more precise and better fit than the AMC/Fel-Pro seals I removed.
Thanks.
