Hemi Cross Ram intake Explosions?? !!!Max Maniac!!!
#448522
08/24/09 09:35 PM
08/24/09 09:35 PM
Posts: 6,293 Rock Springs
Bob_Coomer
Rock Springs
Seen the other guys talking about exploding intakes, so I though Id better ask here. Could this be a problem on the MP Hemi Cross Ram? These intakes are pretty expensive, and haven't been in production awhile.. Max Maniac I would like to know some details of that "pop off Valve". And no replacement parts to buy. Do you know what kind of pressure were looking at? Also I assume the intake has been threaded, or a bolt jammed with holes drilled around it correct? How does the seal seat? is there a O-ring or receiver grooves? I would love to see some pictures disassembled etc. Me and My crew chief would be grateful for any info guys...
[color:"red"]65 Hemi Belvedere coming soon [/color] [color:"#00FF00"]557" Indy engine 1.07 60ft 144mph in the 8th 2100 lbs package [/color]
Re: Hemi Cross Ram intake Explosions?? !!!Max Maniac!!!
[Re: Bob_Coomer]
#448523
08/24/09 10:31 PM
08/24/09 10:31 PM
Posts: 6,354 Aurora, Oh.
max_maniac
Aurora, Oh.
Max Maniac I would like to know some details of that "pop off Valve". And no replacement parts to buy. Do you know what kind of pressure were looking at? Also I assume the intake has been threaded, or a bolt jammed with holes drilled around it correct? How does the seal seat? is there a O-ring or receiver grooves? I would love to see some pictures disassembled etc. Me and My crew chief would be grateful for any info guys... If I can get to the garage sometime tomorrow I can get some pics of the set up. This was done to both of my intakes by Bob George. There is a bolt through the intake with holes drilled around it and they are sealed with rubber o rings glued to the cover. It has worked for me so far maybe BG can respond to the pressure settings since he installed them but when I took one apart I kind of went by feel on how tight they should be. I never used them or had a problem when I was running the oe cross ram but have heard stories of them bursting open also. PS: Looks like a really sharp crew chief ya got there Russ
[Re: max_maniac]
#448530
08/30/09 08:02 PM
08/30/09 08:02 PM
i ran my 440-25 crossram all day today with 7 passes with not 1 backfire.the trick is no gas before firing it up warm.
#448531
08/30/09 08:11 PM
08/30/09 08:11 PM
max_maniac
Aurora, Oh.
I agree but that is not how the 2nd intake I had made a big bang. The 2nd one happened when the car was running and I was driving through the pits. I later did find a carb issue that was dumping fuel so in case that ever happens again I have some insurance I can still race that weekend.
Russ
[Re: max_maniac]
#448532
08/30/09 08:19 PM
08/30/09 08:19 PM
Bob_Coomer
Rock Springs
were can I get one of those at Max? Or do you have two of them?
[Re: max_maniac]
#448533
08/30/09 08:22 PM
08/30/09 08:22 PM
Russ
Russ, i understand fully, these intakes are a little tricky at first but once you get the jetting, metering rods, and most importantly the fuel bowls correctly adjusted, fuel psi at no more than 6.5, your golden. i can understand being gun shy after exploding 2 but really look over your carbs thoroughly before firing it up. just 3 pumps at the beginning of the day to start it up after that i dont touch the gas again. hope this helps. Gary Jacobs talked me through a float level problem today and got me my best et ever with my NSS car. wheels came up so high today, i uncovered my primary jets totally giving me a wicked hesitation with wheels up, car came crashing down till the car leveled out and then picked back right back up.
[Re: Bob_Coomer]
#448534
08/30/09 08:28 PM
08/30/09 08:28 PM
It is the cheapest insurance that you can have. I use the Wilson valves. But many other setups work fine. Put it on and you know you won't blow the top off your intake...
#448535
08/30/09 08:28 PM
08/30/09 08:28 PM
Bob_Coomer
Rock Springs
Russ
Everyone sometime or another has a needle stick open, its just a matter of time...
Maxx I was thinking, the way this Cross ram is set up, It would probably need two, cause each side it kinda isolated.. Those Wilson's look trick, but $75 each, and I need two...
[Re: Bob_Coomer]
#448536
08/30/09 09:39 PM
08/30/09 09:39 PM
max_maniac
Aurora, Oh.
I have 2 on each intake. I suggest to pm Bob George as he is the one that put those together and installed them. He may be able to send you the parts or tell you where to get them.
Russ
[Re: Hemi Allstate]
#448539
08/31/09 12:40 PM
08/31/09 12:40 PM
Posts: 9,910 Eighty Four, PA
B G Racing
Eighty Four, PA
This is the first I've heard about this problem. Sounds like a good idea though.
Ask Russ or Kyle Reasbeck if it's a good idea.Kyle's explosion caused a fire that could have be very serious had he not been prepared with a extinguisher handy.
