Re: can someone school me on setting pinion angle??
[Re: 1/2 as nutT !]
#446858
08/23/09 09:52 PM
08/23/09 09:52 PM
NEVER had a 4 link ... but 7 degrees ?
On a suspension that should have ZERO change of pinion angle through the up and down movement.
That type of an angle is costing power.
In BOTH of my replies, I said LEAF SPRINGS.........
and with the pinion angle down 7* with a 4 link, it isn't losing an ET.......but that's for another thread.......
another thing, not many if any leaf cars have a motor/tranny centerline angle going up.. just something to think about before you condem the method.
What's that got to do with anything? What's the output shaft angle in a jacked up 4 wheel drive truck in relationship to the pinion???? UP???? ![](/ubbthreads/images/graemlins/whistling.gif)
[Re: moparniac]
#446861
08/23/09 09:56 PM
08/23/09 09:56 PM
I've seen that drawing here on Moparts a MILLION times and I understand it completely......but I did it that way, and it howled like a stuck hog when letting off the throttle.........so I'm not doing it that way ever again.........
[Re: 1/2 as nutT !]
#446862
08/23/09 09:59 PM
08/23/09 09:59 PM
B S ...I did not read each and every post in detail...I was responding to mm's topic ...and that several people were saying 7 degrees.
And I disagree ... 7 down will cost power(maybe not much) ...on something that does-not need-it.
I said it wouldn't lose ET.......and that's all that matters........as long as it doesn't go above zero, you're peeing in the ocean to raise the tide and it's not even measureable.........
#446863
08/23/09 09:59 PM
08/23/09 09:59 PM
Quicktree
have no idea, never drag raced a 4 wheel drive. I hear that brought up a lot but don't know why it's mentioned when setting up a drag car. bottom line you have to do what works for you
[Re: Quicktree]
#446864
08/23/09 10:06 PM
08/23/09 10:06 PM
I compared it to them because you brought up me having lowered my K-frame which raised the tailshaft a few degrees......... ![](/ubbthreads/images/graemlins/beer.gif)
That's what I'm saying........it doesn't necessarily work.......There's a window where either way will work fine and NOBODY would be able to measure any ET difference anyway........I found out where the way you guys do it wouldn't work and I wanted to let people know...... ![](/ubbthreads/images/graemlins/beer.gif)
#446865
08/23/09 10:08 PM
08/23/09 10:08 PM
Posts: 705 Michigan
Hemiroid
Like I'd mentioned.......that was with a leaf spring car, and it does have slicks, and it does make close to 600HP, and I does launch like I stole it......and I doesn't want the driveshaft to smack the floor pan when I do........been there, done that..... ![](/ubbthreads/images/graemlins/laugh2.gif)
The thing you're forgetting is that a LOT of places recommend 6 to 7* pinion angle with a leaf spring car that's making some poop, and my car would not work doing it that way.............that's all I'm saying........
I'll face the firing squad with ya Big I've kept my mouth shut while this subject has been debated here, but for 25+ years I've done it your way and never had a problem. For a leaf spring car, I line up the driveshaft with the pinion, then push the nose of the pinion down around 5 degrees. I just leave the u-bolts loose and push the rear end where I want it, then weld the perches.
Theory-craft and books are nice, but what works in practical application in the field and what the book says don't always jibe.
[Re: Quicktree]
#446866
08/23/09 10:08 PM
08/23/09 10:08 PM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
my way, Monte's way amd Wolfe race cars way http://www.wolferacecraft.com/pinionangle.aspxenough said. The Joker
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
[Re: sixpackgut]
#446867
08/23/09 10:14 PM
08/23/09 10:14 PM
Quicktree
enough said.
The Joker
enough said if you buy into that, you can also find just as many who set it the other way. really I don't care how anybody sets theirs. people have to decide for themselves and learn the hard way I guess. now go make you another movie.
[Re: sixpackgut]
#446869
08/23/09 10:26 PM
08/23/09 10:26 PM
Quicktree
enough said.
The Joker
untill you build a 4.70 1/8th mile stock suspension car i will keep listening to the guys who do. no need for a movie
have at it. cause I have no desire to build a stock suspension 4.70 car.
[Re: Quicktree]
#446870
08/23/09 10:29 PM
08/23/09 10:29 PM
Posts: 6,295 U.S.
moparniac
U.S.
I have a dumb question as usual! ![](/ubbthreads/images/graemlins/biggrin.gif) What if a guy like me ![](/ubbthreads/images/graemlins/biggrin.gif) is putting in a dana 60 from previously having a 8 3/4 which I am ![](/ubbthreads/images/graemlins/biggrin.gif) and dont have a driveshaft yet to go off the driveshaft method cause I need to set the car on its suspension and roll the pinion down and weld in the perches and need the rear done to get actual measuremnet for a new driveshaft ![](/ubbthreads/images/graemlins/shock.gif)
Mopar Performance
[Re: Quicktree]
#446871
08/23/09 10:29 PM
08/23/09 10:29 PM
Posts: 2,872 CheddarHead till October
weedlayer
enough said.
The Joker
why not u sceeeeered ![](/ubbthreads/images/graemlins/drive.gif)
[Re: moparniac]
#446872
08/23/09 10:32 PM
08/23/09 10:32 PM
Quicktree
I have a dumb question as usual! What if a guy like me is putting in a dana 60 from previously having a 8 3/4 which I am and dont have a driveshaft yet to go off the driveshaft method cause I need to set the car on its suspension and roll the pinion down and weld in the perches and need the rear done to get actual measuremnet for a new driveshaft
pinion angle is the last thing you do no matter which method you use. so you will have a shaft by then or you wont be racing anyway ![](/ubbthreads/images/graemlins/laugh2.gif)
[Re: weedlayer]
#446873
08/23/09 10:34 PM
08/23/09 10:34 PM
Quicktree
enough said.
The Joker
no not really, you sponsor it and I will build and drive it. how does that sound? when can I expect the first sponsor check?
[Re: Quicktree]
#446875
08/23/09 10:40 PM
08/23/09 10:40 PM
sixpackgut
Charleston
enough said.
The Joker
so what do you desire? just pretending your a chassis guru?
wedgie's nonsensical chart
trans angle 2* down(like most mopars) set pinion angle 2* up. now the rear and trans centerline are in parallel. then what? what is the pinion angle at this point Mr Quicktree? is it ZERO? What if Calvert said to set pinion angle 2* down, ok, now the driveshaft is in a straight line with the pinion(a big no no on the chart) although not a big deal on a mopar because the engine is off center and there will still be movement inside the U joints BUT if the engine and rear are in line, this doesnt work. neither does setup on a stock suspension with just leaf springs.
i really wish you would explain your way better because the only lesson learned was big squeeze trying it your way and it doesnt work
[Re: sixpackgut]
#446876
08/23/09 10:45 PM
08/23/09 10:45 PM
Quicktree
enough said.
The Joker
I don't pretend to be anything, I am just an old bracket racer and do what works for me.
[Re: Quicktree]
#446877
08/23/09 10:47 PM
08/23/09 10:47 PM
sixpackgut
Charleston
enough said.
The Joker
car never make it off the starting line and you would be blaming all the horsepower you make to the guys cleaning up the gear oil
